Will A New Cabin Air Filter Prevent Exhaust Smell When Defrost Is On?
Old Feb 4, 2009 | 01:29 AM
cody6766's Avatar
I searched for this and I couldn't find an answer. I'm sick of the damned exhaust smell my 8 sucks in when I'm running my defrost. Will a cabin air filter fix, or at least help this issue?
Old Feb 4, 2009 | 01:40 AM
StealthTL's Avatar
Metatron
New filter won't help.
There is a Mazda filter option called an 'aldehyde filter' which can remove outside smells from the incoming, but it's expensive.....
(Your sig picture is WAY too big at 70k+, please resize)
S
Old Feb 4, 2009 | 02:08 AM
cody6766's Avatar
is the aldehyde filter a dealer only part or can it be found elsewhere? Will it filter the the smell enough to justify it's price?
I'll get on the sig asap
Old Feb 4, 2009 | 02:37 AM
Silver06's Avatar
Zoom Zoom....
The 'aldehyde' filter is indeed a OEM-only part.....
It is apparently a fairly special thing: it catalyzes certain pollutants (alcohol-based substances like Ethanol and formaldehyde, etc.) rather than relying on openings too small to let the particles through. This allows for much greater airflow thorough the filter.
It seems to sell for around $45 US at Rosenthal Mazda. (Mid-$50's on ebay, LOL.).
However, there is a DIY on making your own cabin air filter. You could use a HEPA filter, or whatever - note that airflow may well be restricted. YMMV. http: /www.rx8club.com/showthread.php?t=40815
IMHO, at only $15 more than a regular OEM filter, go with the aldehyde.
Whatever you do, change your filter every year.
Old Feb 4, 2009 | 02:49 AM
StealthTL's Avatar
Metatron
Fiberglass taped and heat-proof painted my midpipe, and it stinks when the car is stopped at a light.
Installed aldehyde filter set (comes in two halves).
Midpipe stench must not be an 'aldehyde', I'm guessing.....
S
Old Feb 4, 2009 | 03:05 AM
Silver06's Avatar
Zoom Zoom....
S.
Probably one of those annoying Esters. (I had a girlfriend once with a little sister named Esther - she was impossible to get rid of )
An ozone generator would probably get rid of the smell, but the downside is it may kill you....
If it is the pipe wrap, or paint, it should get better - in its own time.
ps. I'm NOT an organic chemist, but I did drive past a Holiday inn today....
Old Feb 4, 2009 | 03:40 AM
GaMEChld's Avatar
Registered Noob
I installed an aldehyde filter, it doesn't prevent the smell of engine fumes. I used to be really paranoid about it too, but it's really not going to kill you.... unless maybe you're just sitting there idling for like an hour for some reason. You'll get used to it eventually. I barely give it a second thought anymore.
^LOL
Old Feb 4, 2009 | 11:49 AM
cody6766's Avatar
So the smell is basically here to stay?
Is it normal to have exhaust fumes pulled through the air system when at idle? I guess that should have been my first question. It doesn't happen when the recirc is on, but it's IMMEDIATE when it's off. In my previous car I only noticed this where I had an exhaust leak at the rear exhaust mani, but there are no signs of a leak according to my ears.
Old Feb 4, 2009 | 12:48 PM
kersh4w's Avatar
Hit & Run Magnet
its normal if you have a catless midpipe.
if you have the stock exhaust, something is wrong.
Old Feb 4, 2009 | 12:57 PM
dozer's Avatar
on his 3rd rx8
its really bad if you have a leak...with catless the smell tends to "sneek up"
Old Feb 4, 2009 | 01:55 PM
cody6766's Avatar
it's not a catless smell, it's the same smell that comes from the tailpipes. It smells just like normal, everyday exhaust
Old Feb 4, 2009 | 02:10 PM
LPCOKIE's Avatar
you can use the DIY and make your own. use a carbon filter like is used with an air purifiers. like at home depot or lowes or sears. carbon is the only thing that will take out the smell. i have asthma and need this. the filter from mazda didnt work very well.
Old Feb 4, 2009 | 02:19 PM
Renesis07's Avatar
Vtak just kicked in yo!!
my stock exhaust didnt smell, maybe you should have your car looked at?
Old Feb 4, 2009 | 03:24 PM
GaMEChld's Avatar
Registered Noob
Yeah, it was only smelly after I went catless. If it is stinking the same as with the cat, then your cat mustve been dead or something.
Old Feb 4, 2009 | 04:39 PM
ken-x8's Avatar
It's not normal. I don't get a smell in mine.
You can have a toxic exhaust leak without any noise. I've had that happen on a couple of cars in the past. Muffler shop always found the leak. I recommend you have someone look at it.
Ken
Old Feb 4, 2009 | 04:48 PM
White_Shadows's Avatar
I just got my 05 and I don't smell nothing in every dial. Must say my cold is when on the hott setting and hott on the cold setting. Except when the moon is half way between a waining and waxing gibbus...... It's annoying, but smelling exhaust can't be good you sir have an exhaust leak or you're smelling burning coolant.
Old Dec 21, 2009 | 03:35 AM
zacknolden's Avatar
However, there is a DIY on making your own cabin air filter replacement. You could use a HEPA filter, or whatever - note that airflow may well be restricted. YMMV.
I totally agree with you. It's included in my regular maintenance list. I won't compromise my ride's performance with a busted air filter.
05TR1CH
Apr 18, 2023 04:56 AM
uZu
Dec 30, 2015 12:35 PM
GK1707
Dec 2, 2015 10:01 AM
cschoeps
Aug 6, 2015 12:44 PM
MrORAN6E
Jul 24, 2015 09:32 AM
