View Full Version : More observations about MS CAI in winter: Rough idling
Footman 01-29-2009, 09:03 PM Some may have seen this on my facebook name. Out of nowhere today, the car started to idle rough. Some key points:
- It never stalled.
- Drives perfectly smoothly as long as you are moving.
- Only occurs when you are slowing down and you shift to neutral to allow the RPM's to fall.
- It makes no difference whether the clutch is pushed in or not while in neutral (hence it's not a malfunctioning neutral sensor)
The observation:
As the RPM's fall, it dips below the idle RPM (between 750 - 900 rpm) as if it's trying to stall, and then it starts to idle hunt for 3 - 4 seconds before finally, the PCM automatically gives it gas to go to about 1200 rpm, stays there for 2 seconds, and then falls smoothly back to idle. While it's idle hunting, you can hear some hesitation and surging on the throttle.
Ambient temperature - 7 C. No precipitation. Roads are wet, from the salting of yesterday's snowstorm.
Theory:
1) It first happened after my fuel light came on for low fuel. I thought perhaps maybe the fuel lines got slushy so I filled it up. Still happening.
2) Coils/plugs came to mind, but I had these changed by the dealership in December 2007, and I know these last more than 22,000km that I have put on these coils/plugs; so this can't be it.
3) Clogged CAT, maybe clogging... but again this was also replaced for free by the dealership around February 2008 when I initially had my MS CAI issue at the dealership.
I decided the quickest thing I could do was, inspect for vacuum leaks, cracked/loose hoses or any sign of oil blowback into the intake area. No oil blowback.
Then, this thought came to mind, and was the only possible explanation I could come up with... dirty MAF sensor again! How? aggressive driving, high RPM's at highway speeds, in snow, or in presence of slush, backwash, essentially anytime after a snowstorm when the roads are salted/wet and cars are spraying it all over the front of your car at 100kph when you follow them.
I touched my CAI rainshield, it was kinda damp which is normal. I wiped that dry anyways with microfibre. poked my fingers behind the rainshield to touch the actual dry flow filter. That is also kinda damp too... couldn't dry that one really...
Found a 9/64" allen key at work and took the MAF sensor off. Also found some electrical contact cleaner (not CRC MAF). The MAF looked kinda dirty, with salt marks and some sort of green salt trail forming near the "bulbous" looking thing that hangs (I heard this is the temperature sensor, since the 2 resistive wires inside are the actual mass-air-flow sensor wires). Spray cleaned it. Stuck a microfibre cloth AGAIN inside the MAF hole, felt kinda damp inside along the walls too! Dried everything up. Inspected the two screens inside with a bent mirror (kinda like the one Dentists use). Everything checked out okay.
Proceeded to perform the NVRAM and KAM reset on the ECU (odometer TEST and brake pedal depress respectively). I think maybe the fuel maps for +20 C temperatures would be different for fuel maps when its -20 C outside. I think resetting it will help it re-learn the fuel-air ratio at these temperatures with more dense oxygen (Just a theory, I dunno about this one).
Started the car, and let it sort itself out. It did it's idle hunt thing for a bit, and then I drove it around to lunch and it seemed okay, but not perfect. I parked the car after lunch. Came back after work, started it, and everything was okay. No more RPM hunting at idle. It just falls to 1000 RPM, stops and then slowly does gown to 800 rpm or so as usual...
Problem appears fixed now. Will be on monitor for the next few days. The ECU probably still does not have sufficient data for it's fuel maps. I have not redlined it since the reset.
Footman 02-01-2009, 10:58 AM It's 3C today in Toronto. I cleaned the MAF again just to make sure.. Scrapped off this caked on green powder that was developing on the IAT sensor portion of the MAF sensor (the metal portion of the bulb sensor).
I don't know what this powder is..looks like salt corrosion.
Everything is now idling smoothly. The warmer temperatures also reduced a lot of rattling/odd noises too...
Leesha 02-01-2009, 11:39 AM I have experienced this also...
"As the RPM's fall, it dips below the idle RPM (between 750 - 900 rpm) as if it's trying to stall, and then it starts to idle hunt for 3 - 4 seconds before finally, the PCM automatically gives it gas to go to about 1200 rpm, stays there for 2 seconds, and then falls smoothly back to idle. While it's idle hunting, you can hear some hesitation and surging on the throttle. "
Only when it is cold though... Today I had no problems with it and it is bearly noticable on my car.
mysql 02-01-2009, 11:47 AM I've been noticing it myself recently. My idle is set to 900 rpm, so when it stumbles, it's only down to 850. So it's not as bad as it would be if I had a 750 idle. But it's just enough to be noticeable. No ill effects. I'm thinking about slapping the OEM intake on and seeing if it goes away.
tubingchamp 02-01-2009, 11:51 AM My MS CAI has not helped me one bit.
I've had massive issues with it.
I was told on here a while back to check the screens, etc.. Not long ago, I was driving to go to my brothers birthday dinner and the car freaking died on me, I had to leave it overnight about 30 minutes from my house because I had no 8mm with me.. I've tried messing around with the screens a ton, one out, none in, both in, etc. It will only idle at all if I have both screens in. What had happened when it died on me and I went there the next day to fix it, one of the screens was on a complete 90 degree angle to the screen nearest the MAF sensor. I straightened it up and had no issues driving home. Got home removed MS CAI and put in the stock one.
Not a problem since.
Ofcourse, now I need to tighten my belts because they're squeaking a bit... But I don't have the proper tools to do it. Could that make the idle abit gruff? Still having minor idle discrepancies..
mysql 02-01-2009, 11:54 AM the maf sensor is a wondrous thing. my turbo CAI intake setup was flawless, but the new owner of it is having a bit of stumbling at idle using it. I don't know what else to say besides make random adjustments or revert to stock and see if the issues go away. Trial and error to see what works for you.
tubingchamp 02-01-2009, 11:56 AM You only had one screen in your turbo MAF tube, correct?
mysql 02-01-2009, 11:57 AM Ofcourse, now I need to tighten my belts because they're squeaking a bit... But I don't have the proper tools to do it. Could that make the idle abit gruff? Still having minor idle discrepancies..
To adjust or remove the belts, you need a 10mm, 12mm and some large size that I forget off the top of my head. Just normal hand tools.. anyway, unless they're way over tightened, I don't see why they would hamper your idle.
Leesha 02-01-2009, 11:58 AM My MS CAI has not helped me one bit.
I had a rat chew a hole through the CAI filter and it needs to be replace! Sucks!!
mysql 02-01-2009, 11:58 AM You only had one screen in your turbo MAF tube, correct?
I had NONE in my turbo CAI. It worked well that way too. The piping and couplers had gradual curves and nothing abrupt.
tubingchamp 02-01-2009, 11:59 AM When you sold the car, did it have the ceramic coated AEM CAI, or was that with your turbo setup?
What I actually wanted to ask was: What intake setup did the guy who purchased your car have?
mysql 02-01-2009, 12:00 PM my car isn't sold :)
I don't need the cash, so I'm not overly worried about offloading the vehicle.
tubingchamp 02-01-2009, 12:01 PM I had a rat chew a hole through the CAI filter and it needs to be replace! Sucks!!
That's what you get for living in a place with -30 degree winters ;) Haha! Get over here to BC, it's nice and mild! I've never seen a rat in my life, they don't need to migrate indoors during the winter to survive.
tubingchamp 02-01-2009, 12:02 PM my car isn't sold :)
"The new owner is having a stumbling idle"
Dyuhh, confused me :)
Is his car N/A?
tubingchamp 02-01-2009, 12:05 PM To adjust or remove the belts, you need a 10mm, 12mm and some large size that I forget off the top of my head. Just normal hand tools.. anyway, unless they're way over tightened, I don't see why they would hamper your idle.
Haha, yeah, but try to get in there with the stock intake in... I guess I could remove it, but it's just such a PITA to squeeze it back on.. That, and theres a pile of snow ontop of my car right now. Should've parked her in the garage, it would be something to do today.
mysql 02-01-2009, 12:10 PM "The new owner is having a stumbling idle"
Is his car N/A?
ah, new owner of the turbo cai :) he's... turbocharged :) :lol:
tubingchamp 02-01-2009, 12:15 PM Ahh okay, then I have no clue..
Was gonna say, if he was using a MAF tube without screens and N/A, that could be the problem right there. I know my car won't idle without them.
Leesha 02-01-2009, 12:19 PM That's what you get for living in a place with -30 degree winters ;) Haha! Get over here to BC, it's nice and mild! I've never seen a rat in my life, they don't need to migrate indoors during the winter to survive.
LMAO... It happened in the summer time. My garage is outdoors not indoors...lol I'm a country girl now... City folks don't know what rats are...:)
I've been to BC...it's beautiful there...
tubingchamp 02-01-2009, 12:23 PM LMAO... It happened in the summer time. My garage is outdoors not indoors...lol I'm a country girl now... City folks don't know what rats are...:)
D'oh outdoor garages! Funny how a rat would get in there to do that, though.. :P
Check out a pic of the 8 by my lakeside :) <3 BC..
http://i536.photobucket.com/albums/ff326/tubingchamp/DSC_0010.jpg
[/threadjack]
Leesha 02-01-2009, 01:10 PM WoW~~~ So beautiful... Yeah wish I was there right now... :)
Footman 02-01-2009, 08:46 PM you have to watch the dry flo filter very carefully... and try to clean that rainshield sock and keep it dry.
The MAF also needs to be cleaned more often as proper maintenance if you have been in a place like what Toronto has gone through this winter so far... it's all that fine mist of SALT/DIRT that goes through everything and eventually lands on your MAF sensor and IAT sensor. As we all know, salt conducts electricity,and fucks up the readings.
With the winter we're having now, I would clean my MAF sensor again at the end of March just to be sure.... it's quick and easy. For me, it is a 9/64" allen key.
Leesha 02-02-2009, 07:33 AM you have to watch the dry flo filter very carefully... and try to clean that rainshield sock and keep it dry.
How do I do that? Is it easy?? Maybe you can show me?
Footman 02-02-2009, 08:24 AM There are DIY's on this forum, it's very easy. Just 2 screws to remove. The MAF sensor pops out, and you spray 10 - 15 blasts of genuine CRC MAF cleaner (available at Napa Auto parts).
If there is no Napa auto parts near your place, other people have used electrical contact cleaner and/or Brake cleaner. But I use the real stuff that's made for it... :)
REV-illusions 02-02-2009, 04:51 PM That's what you get for living in a place with -30 degree winters ;) Haha! Get over here to BC, it's nice and mild! I've never seen a rat in my life, they don't need to migrate indoors during the winter to survive.
lol.. they're all too scared to be hangin' out in Surrey.. that's why ;)
Razz1 02-02-2009, 04:58 PM I had a rat chew a hole through the CAI filter and it needs to be replace! Sucks!!
Are you sure it wasn't one of your minature Yorkies?
I hear they like to chew on everything.
tubingchamp 02-02-2009, 05:01 PM lol.. they're all too scared to be hangin' out in Surrey.. that's why ;)
I live on the good side of Surrey :)
Footman 02-02-2009, 05:03 PM Tubingchamp.... I'm coming to VNR on July 24, and leaving Aug 4. I'm gonna rollon over to your place in Surrey. you're gonna give me a ride in your HYMEE SUPERCHARGED RX8 right?
tubingchamp 02-02-2009, 05:12 PM Should be supercharged by then... For sure though, if it is..
Btw, nice avatar ;) GO DOOM2!
REV-illusions 02-02-2009, 05:25 PM I live on the good side of Surrey :)
haha... Whiterock? I use to live across the bay in T-Town...
tubingchamp 02-02-2009, 05:28 PM haha... Whiterock? I use to live across the bay in T-Town...
Opposite of Whiterock actually.. Fraser Heights.
Across the freeway from all that Guildford mumbojumbo.
REV-illusions 02-02-2009, 05:31 PM Opposite of Whiterock actually.. Fraser Heights.
ahhh.. alright then :)
Hopefully I'll get my ass back out that way some time soon... Ontario sucks. Hrmm... road trip... would only cost about 1k in gas...
Footman 02-02-2009, 05:35 PM Road trip out to VNR.. I would be interested.. but we gotta stop by in Montana to get some steaks though...
tubingchamp 02-02-2009, 05:36 PM Put some in the cooler for me too ;) I love my steak.
Footman 02-02-2009, 05:36 PM Tubingchamp, so if it's not Supercharged, then maybe if there is some BC RX8 club meet up that week, I'll show up for sure.
tubingchamp 02-02-2009, 05:42 PM I'm sure we can schedule up some kind of dinner event or something for some fellow Canadian rotorheads :D
Should probably be S/Ced by then though...
I hope :D
That is, if my engine doesn't blow :D
Footman 02-02-2009, 05:49 PM What program is that to generate your display pic? The one showing the car front, side, rear view customized to the way your car looks. I see a lot of people have that.
tubingchamp 02-02-2009, 05:58 PM It's Gyro_Bot, and he's not a program, he's a club member who puts out alot of his time for BCRX8 :).
I think he photoshopped each "active" members car individually :).
