Emblem Holes HELP!
Old Jan 29, 2009 | 07:53 PM
sjshark19's Avatar
Unhappy Emblem Holes HELP!
I just took off my front emblem thinking that it was just double sided tape underneath to find out that there were holes underneath it what is the easiest way to get these holes filled?
Old Jan 29, 2009 | 07:58 PM
Rotr8's Avatar
whines all the way home
thats why all noobs need to search, a five min venture would have revealed that answer...
Well theres the easy way and after a month it will look like hit **** or you can do it the right way.
Easy shitty- body filler, after a while it will sag and your bumper will have dimples,,,
Right way - is to plastic weld them shut and repaint, not all body shops offer this service...
Old Jan 29, 2009 | 08:02 PM
onyx8's Avatar
https://www.rx8club.com/rx-8-multimedia-photo-gallery-6/debadged-my-pb-165408/
Old Jan 29, 2009 | 08:08 PM
sjshark19's Avatar
would it be hard to do that plastic weld? because i am a welder and could maybe do it, depending on the machine that you need to use.
Old Jan 29, 2009 | 08:15 PM
Rotr8's Avatar
yup its pretty easy just need the equipment, you can pick up a cheapo machine for about $200
Old Jan 30, 2009 | 12:58 AM
sjshark19's Avatar
So would i just fill in the holes with the weld and then sand it down? so then I'd have to get it painted?
Old Jan 30, 2009 | 01:15 AM
05rex8's Avatar
sold the 8... :(
yes..fixing the holes in the front will require a repaint...whether it be filled with bondo, epoxy, plastic welded....etc.
there is no easy solution to this one.
Old Jan 30, 2009 | 06:36 PM
sjshark19's Avatar
anyone know how much it would cost to paint it?
Old Jan 30, 2009 | 06:51 PM
05rex8's Avatar
sold the 8... :(
Depends on where you go. VR is a hard color to match, since it is a tri-stage. Could be anywhere between $200-$500.
Old Jan 31, 2009 | 02:03 AM
hakuna matata!
since the holes are so small in front.. with some bondo/epoxy on the inside of the front bumper wouldn't vr touch up paint suffice?
Old Jan 31, 2009 | 12:01 PM
05rex8's Avatar
sold the 8... :(
you could, it won't be perfect though...it would be a quick and easy temporary solution
Old Feb 1, 2009 | 02:54 AM
hakuna matata!
^ right.. it wouldn't even be noticeable to the average passerby, no?
i mean if it's a show car yes, but a complete repaint for 3 pinhole size holes?
hell I got rid of my OEM spoiler and my trunk has 4 tiny pieces of electrical tape covering the holes!
Old Feb 1, 2009 | 05:45 AM
T-ReX-8's Avatar
Stormtrooper RX8??
lol sounds a little ghetto haha. But hey we all do what we gotta do right..
Old Feb 2, 2009 | 11:21 AM
notorque's Avatar
I bid thee farewell
put masking tape over the hole, fill with bondo from inside bumper, let dry, take tape off, and sand with q-tip (elmers glue, and hobby sand on cotton tip= ~150 grit) in that little area to smooth some more, should be pretty smoth just from tape covering. then use touch up. it will last till you can afford to take it to the dealer. another thread the guy said it cost 250 for all the badges to be taken off and repainted.
Old Feb 7, 2009 | 09:25 PM
madhatter1213's Avatar
Thumbs up Not to hard for shops anymore
Take your car to a shop they have plastic glues now and two part plastic filler that will fill it nicely welding is a waste of time but the bumper will need to be painted.
Old Feb 7, 2009 | 09:39 PM
05rex8's Avatar
sold the 8... :(
welding is just as easy as using the epoxies....I use both.
Threshermal
Apr 15, 2020 09:43 PM
arexatemate
Oct 28, 2019 08:16 AM
coolcars44
Sep 24, 2015 05:47 PM
