Lights Messed Up - tail & reverse
Old Jan 28, 2009 | 03:31 PM
SilverMiata's Avatar
2004 GT 6-speed
I've searched the forums and didn't see anyone having this problem, but I learned about alot of other lighting/electrical problems. :-)
My center brake light doesn't work, one of my reverse lights doesn't work, and the other reverse light is on when I brake (and when in reverse). Has anyone had this problem and figured out a solution?
Background: I just fixed the tail light fish-bowl problem, but that shouldn't be related, unless some of the water (or a fish or spider) got into the wiring and created a short.
I've already done the following:
- switched reverse bulbs from side to side. Its not the bulb or bulb-socket
- checked all fuses. Nothing's blown.
What I'll start with tonight:
- check/clean battery then disconnect/reconnect
- check center brake light bulb (but should be okay, since I recently replaced)
- check resistance/voltage in sockets & connectors
Any other suggestions?
vapor2
May 4, 2020 03:53 AM
200.mph
Dec 10, 2018 03:49 PM
vapor2
NW RX-8 Forum
Sep 17, 2015 07:43 AM
erikcamacho15
Sep 12, 2015 11:23 AM
Irvinb16
Sep 11, 2015 10:27 PM
