coolant level alarm
Old Jan 26, 2009 | 12:12 PM
hawkwind's Avatar
coolant level alarm
Just got my first RX8 and have a coolant level alarm, but coolant is full?
Old Jan 26, 2009 | 12:29 PM
cjkim's Avatar
^noob
relatively common. sensor going bad
Old Jan 26, 2009 | 01:30 PM
greg985's Avatar
The 337
what year and how many miles? may be fixed under warenty
Old Jan 26, 2009 | 01:32 PM
hawkwind's Avatar
is the sensor in the bottom of the water tank ? if so can it be cleaned from the filler cap, with say a tooth brush?
Old Jan 26, 2009 | 01:35 PM
greg985's Avatar
The 337
well if you would tell me how many miles then maybe Mazda will replace it for free
Old Jan 26, 2009 | 01:40 PM
hawkwind's Avatar
sorrry. 41K 55 plate. over 3 years old.
Old Jan 26, 2009 | 05:08 PM
04RX8man's Avatar
Rotary Powered Countryboy
bumper to bumper warrant is 4yrs 48,000 miles so it should b covered as for cleaning that's a big no the whole tank must b replaced!
Old Jan 26, 2009 | 06:24 PM
Socket7's Avatar
ಠ_ಠ
The sensor is integrated into the tank. There is no way to repair it. You can either have mazda replace it under warranty, or unplug the sensor from the tank and just keep an eye on the coolant from then on.
Old Jan 27, 2009 | 07:22 AM
PaPaBear's Avatar
PaPa Bear
When you say coolant "alarm" do you mean the little red light icon?????
Old Jan 27, 2009 | 07:48 AM
dillsrotary's Avatar
jersey fresh
Before you jump to the conclusion that the sensor is bad, just add a few ounces of coolant and see what happens, thats what fixed my light.
Old Jan 27, 2009 | 08:55 AM
Shinka_MJR's Avatar
SHKWAV
i've noticed my light would come on when i started the car and it was extremely cold outside. Once the car was running for about 30 seconds or so, it would shut off no problem.
Does your light go out within a minute? Is it below zero where you are?
Old Jan 27, 2009 | 09:59 AM
Socket7's Avatar
ಠ_ಠ
Good point. If the coolant is around the min mark on the tank, hard driving could set it off. It happened to me on I-5 halfway between SF and LA. Dealer topped off the coolant and no problems since.
Old Jan 27, 2009 | 10:14 AM
paulmasoner's Avatar
Asshole for hire
not undermining your case whatsoever. just telling my case
I experienced coolant level sensor failure a year or two ago. It started as very rare,very random coolant light under hard driving conditions(hidh rpm). Every time i noticed it getting a bit more frequent, i added just a touch of water and it went away, just like the above stories.
This continued until i had to have the coolant WAY overfilled to keep the light off. i wasnt ok with that so i removed the excess fluid. it got progressively worse until the point that i could not even cruise at RPM's above 3,500 or so without the light coming on.
i disconnected the sensor. its molded into the tank, so no replacing a sensor, you'll be replacing the tank. and no real way to clean it other than spraying contact cleaner in there once removed(which was tried).
Old Jan 27, 2009 | 04:25 PM
hawkwind's Avatar
thanks to you all. So its a new bottle then. where is the sensor disconection?
Azki23
Jun 27, 2018 03:48 PM
Learners_Permit
Sep 27, 2015 07:38 PM
drlubell
Sep 26, 2015 11:58 PM
nivong
Europe For Sale/Wanted
Sep 2, 2015 07:54 AM
