Brake Calliper Removal
10,000 Revs in the Air!
Hi,
I want to take off my brake callipers to refurbish them. I wanted to know is there a way of doing this without having to bleed the system? I was thinking about bending and clamping the fluid tubes but I don't know if it's safe?
Thanks in advance!
Thanks in advance!
Okay..............I'm not a mechanic, but I somewhat of a rocket scientist.
I would say you are asking for disaster and there is no way you should attempt to bend and clamp them off. You are just asking for major trouble(even after time has gone by) if you were successful. Do it right and bleed them and change the brake fluid......................please!
Do not clamp the hose. Rubber hydraulic hoses do not like to be bent sharply, crimped, clamped or otherwise mistreated. You may damage the hose fabric reinforcement and would be asking for trouble. You would be better of pluggling the end. Better yet, seal the master cylinder with a rubber glove under the lid to limit fluid loss and mess and take the opportunity to bleed and flush your brake fluid.
Jst4fun
Apr 17, 2021 07:43 AM
Road Cone
Nov 6, 2015 01:52 PM
