Grinding from 3rd to 4th
Old Jan 25, 2009 | 04:45 PM
Paul D's Avatar
So evertime Im in 3rd gear and I shift to 4th at over 4500 rpm it makes this grinding noise that doesnt sound too good. I just changed the transmission fluid thinking it would make it better but it didnt really help. Could it be my clutch going bad??
it is an 04 with about 34,000 miles on the clock, what could it be??
Old Jan 25, 2009 | 05:51 PM
04RX8man's Avatar
Rotary Powered Countryboy
is the fluid full? Synchro's possibly?
Old Jan 25, 2009 | 05:55 PM
Go48's Avatar
Does your clutch engage/disengage with the pedal very close to the floorboard? If so, check the clutch pedal bracket under the dash for cracking/breakage.
Old Jan 25, 2009 | 05:57 PM
mysql's Avatar
Doppelgänger
sounds like exactly what happened to me. I had grinding in 3-4 shifts over 6000 rpm or so. When I changed fluid, it got even worse, grinding at 4500 rpm. Mazda tore it down with the intent to change out the broken parts, but once it was apart they decided to give me a new unit. I believe the RP maxgear ate the brass synchros.
04RX8man's Avatar
^yes quite a few ppl are starting to have (and HAVE had probs with clutch brackeet(
Old Jan 25, 2009 | 07:20 PM
Paul D's Avatar
So should i just take it in to mazda?
Old Jan 25, 2009 | 07:22 PM
mysql's Avatar
Doppelgänger
if you have warranty, yes.
Old Jan 25, 2009 | 07:41 PM
Paul D's Avatar
^^ did they fix yours?
Old Jan 25, 2009 | 07:47 PM
mysql's Avatar
Doppelgänger
try reading this:
https://www.rx8club.com/showpost.php...75&postcount=4
Old Jan 25, 2009 | 07:56 PM
pking1122's Avatar
I have an 05, and notice the same thing. Guess I better get over to the dealership
Old Jan 25, 2009 | 07:59 PM
chancejat's Avatar
Drive it like u stole it!
i have this problem too....its the forks they bend relatively easily.......
Old Jan 25, 2009 | 09:11 PM
SilverHokie's Avatar
I'm Delaware Fast
If you search around for my threads, this thing kicked my *** too. 3rd to 4th was my issue too. Sychros was the issue. Replaced under warranty.
Wee...
Old Jan 25, 2009 | 09:23 PM
Paul D's Avatar
Thanks alot guys!!
Old Jun 8, 2009 | 02:51 PM
jimdiddy21's Avatar
ok i know this is old but it is the only thread so i gotta bring it back concerned and have questions.
ok so im gettting the same think in my 05 but, its only when i redline it from 3rd to 4th. someone told me stop redlining and im like i dont do it all the time but wtf its made to redline at 9 sooo? how would i explain it to the dealer? i mean what if i tell them its at 5000rpm and they bring it for a ride and it dont do **** cause its not? idk im lost and my warranty is almost up
Old Jun 9, 2009 | 11:18 AM
mazdaverx7's Avatar
RX-Heaven
i am experiencing the same issue.. the quicker i shift, the worse it is. if i shift slow then i experience no problem what so ever. its definatly synchronizer related. perhaps i shouldnt put the trip to the dealer off any longer than need be.
Old Jun 9, 2009 | 01:11 PM
pking1122's Avatar
I have an 05 model, and I'm experiencing the same thing. I even have a hard time getting the car into gear on a hot day after 30 minutes of traffic. Is my tranny still covered under factory warranty?
Old Jun 9, 2009 | 04:27 PM
mazdaverx7's Avatar
RX-Heaven
^^^whats your mileage??
theblinkof
Oct 4, 2023 05:24 PM
tbiggybig
35
Jul 14, 2022 06:14 PM
nowakm99
Oct 9, 2015 07:10 AM
Hiroshima_RX
Sep 21, 2015 06:28 PM
