lepichichi
01-24-2009, 04:37 PM
i need a fuc&*% up engine i wanna paint it and use it for display in my living room.
thanks guys.
thanks guys.
View Full Version : WTB used blown engine lepichichi 01-24-2009, 04:37 PM i need a fuc&*% up engine i wanna paint it and use it for display in my living room. thanks guys. lepichichi 01-25-2009, 01:22 PM it could be a 12a too, :) WhiteSnowflake8 01-25-2009, 01:32 PM try rx7club lepichichi 01-25-2009, 03:26 PM i try there too :) thanks whitesnowflake8 WhiteSnowflake8 01-25-2009, 06:47 PM No problem man, so you just want a plain short block? Im sure you can talk to rebuild shops and buy all their scrap parts. thejew89 01-25-2009, 09:42 PM ive got a rotor and housing from a second gen rx7 if you would like that tunerwannab 01-25-2009, 11:00 PM why not by the powder coated ones from rotaryresurection? http://www.rx8club.com/showthread.php?t=162167 lepichichi 01-26-2009, 01:19 PM ive got a rotor and housing from a second gen rx7 if you would like that THANKS BUT I WOULD LIKE THE WHOLE ENGINE :) RotaryResurrection 01-26-2009, 11:45 PM yes, because you can tell a lot more about how the engine works by having a complete one, versus disassembled parts. .. :dunno: lepichichi 01-27-2009, 04:31 PM exactly :) yes, because you can tell a lot more about how the engine works by having a complete one, versus disassembled parts. .. :dunno: peregrinus 01-27-2009, 04:35 PM exactly :) i honestly couldnt tell if he was being serious, or sarcastic lol RotaryResurrection 01-27-2009, 08:45 PM sarcasm, actually. You can't tell jack about the inside of the block, by having an assembled block. At most you want half of a block, a cut-in-half eshaft, rotor, housing, iron, and stat gear, with a piece of plexiglass on the front...maybe with a crank on the shaft to rotate the rotor inside the housing. At least you'd want a rotor and rotor housing, to look at. With the block assembled, you can't even SEE the rotor at all...and what good would that do? On a renesis you cannot even see inside the exhaust ports. peregrinus 01-27-2009, 09:28 PM sarcasm, actually. You can't tell jack about the inside of the block, by having an assembled block. At most you want half of a block, a cut-in-half eshaft, rotor, housing, iron, and stat gear, with a piece of plexiglass on the front...maybe with a crank on the shaft to rotate the rotor inside the housing. At least you'd want a rotor and rotor housing, to look at. With the block assembled, you can't even SEE the rotor at all...and what good would that do? On a renesis you cannot even see inside the exhaust ports. agreed, the halfcut with plexi seems like a kickass idea though ^^ |
