New to RX-8 Got a few ?'s
Old Jan 21, 2009 | 10:53 AM
xtreme velocity's Avatar
Only wish I owned a RX-8
Well first of all. We really love the car!!! But have a few questions. We have a 06 RX-8 Shinka model(I think) Auto 6 speed with slap shift. 1in. lowering springs.
First. We bought the car with a GReady Exhuast system on it. Therefor we have no O2 sensors hooked up. I believe. This is cause REALLY BAD gas mileage. Anything I can do to improve that??
Second. When you put the car in Drive. It takes a sec before the gear really engages. Is that normal?
Thanks much for help.
Old Jan 21, 2009 | 11:29 AM
bose's Avatar
Reginald P. Billingsly
Don't know anything about auto's on the 8 I never even considered one. But on the autos I have driven they a typically slow reacting. But hell don't know, wait for someone with an auto to chime in.
Did they just not hook it up? Is there a cel? How bad is 'REALLY BAD' to you, I usually see 14-16 mpg, cause I do a lot of city driving. If I do a lot a freeway driving I average 18ish mpg. Is yours worse than that?
Old Jan 21, 2009 | 11:55 AM
Atilla's Avatar
I am THAT guy
whoa whoa whoa - no O2 sensor hooked up?? why would that happen? the sp2 doesn't come with a midpipe so the O2 sensor should still be hooked up to the OEM cat.
p.s.- congrats on the car
Old Jan 21, 2009 | 12:00 PM
Not sure on the numbers but. We can fill up. Drive 50 miles and the gas gauge moves about 3 notches. Highway miles at that.
Old Jan 21, 2009 | 12:05 PM
Not sure. Like I said it was on when we bought it. Ill have to find a way to jack up car and look under ther. I get the felling he just straight piped it and let O2 sensor hanging. Kids around here dont think straight. And thanks We love the car. If we could afford 2 we would get 2 of them.
Old Jan 21, 2009 | 12:16 PM
tubingchamp's Avatar
What mawd bug?
I get 250KM to a tank with a cat on. It's a rotary engine, that's your problem (on the fuel consumption issue).
Old Jan 21, 2009 | 12:28 PM
So I might just be screwed when it comes to gas mileage?
Old Jan 21, 2009 | 01:32 PM
EDZRIDE's Avatar
2005 White GT
Sounds like mine! Try refilling it after 50 miles then do the math; I average 21 mpg on the highway.
Old Jan 21, 2009 | 01:56 PM
I just dont feel we are getting 21 mpg though.
Old Jan 21, 2009 | 02:05 PM
Atilla's Avatar
I am THAT guy
check it out on your 'trip' - it should give you a read out -
also - definately check out and see what's going on w/your o2 sensor - that's no bueno to leave it hanging there - poke around there when you have the car jacked up - i'm sure if that thing is hanging, there's a good chance some other things might be as well - do you know if the sparkplugs were recently changed out?
Old Jan 21, 2009 | 02:22 PM
The car was serviced when we bought it. And the dealer said the O2 senso might not be hooked up. He could not remember. But I will check onto that!!
Old Jan 21, 2009 | 02:28 PM
Transam kid 01's Avatar
The anti-ricer
Anywhere from 17 to 21 is good for highway.
How many miles on the car? Slow reaction in shifting could be tranny. The car is modified, which means that there is a good chance it was "abused" or pushed hard.
Old Jan 21, 2009 | 02:48 PM
REsuperD's Avatar
zoom zoom
the dealer, as in mazda dealer, didn't know if the o2 sensor was hooked up? they're pretty easy to check...visually...
maybe you also have a straight pipe in place of the cat, in addition to the catback? is your cel on?
Old Jan 22, 2009 | 01:55 PM
em1turbo's Avatar
I have a straight pipe to the stock catback. No O2 sensor. I took it out. Is that bad? what could it do? besides my CEL light which i don't care about.
Old Jan 23, 2009 | 02:39 AM
AJ's Shinka's Avatar
Enthusiast
I have not seen or heard of an auto Shinka before... Yeah 50 miles and you should be down 1/4 of a tank. That is normal, I get 200+ mpg to the tank depending. It's a sports car. If you mean 3 ticks as you are 3/4 empty after 50 miles then something is definitely wrong with your car, as a matter of fact that is the worst gas mileage I have ever heard of on the 8.
[QUOTE=xtreme velocity;2827875]The car was serviced when we bought it. And the dealer said the O2 senso might not be hooked up. He could not remember. But I will check onto that!!
Man don't believe them when they say they "serviced it" I found my spark plugs in my dash when I bought it, they were supposed to change them out.
Old Jan 23, 2009 | 09:51 AM
RX8-Frontier's Avatar
FYI:
The front O2 sensor has engine controls associated with it. If it isn't there/hooked up/problems, then your engine won't run anywhere close to resembling normal. AKA, you'd KNOW it!
The rear O2 sensor is emissions controls, only. It doesn't effect engine control, mileage, or anything. This is the sensor most likely not working, and to be honest, unless you've got an emissions test requirement where you are, you don't need this O2 sensor for anything.
BUT... Your O2 sensor may be working just fine. It may actually be telling you something useful... If you've got a check engine light, former owner and/or shop said O2 sensor not working right, I'd pretty much assume you've got a catalytic converter issue, aka, it's probably clogged up. That'll cause some extremely bad fuel mileage...
Go to your local auto parts store, and ask them to read the codes for you. Most places will do this for free. Then look online for Mazda OBII codes and lookup what the error is. This should get you started in your troubleshooting. Until you know what the stored fault code is, you can't begin to figure out what the problem is.
Old Jan 25, 2009 | 11:14 AM
[quote=AJ's Shinka;2831068]I have not seen or heard of an auto Shinka before... Yeah 50 miles and you should be down 1/4 of a tank. That is normal, I get 200+ mpg to the tank depending. It's a sports car. If you mean 3 ticks as you are 3/4 empty after 50 miles then something is definitely wrong with your car, as a matter of fact that is the worst gas mileage I have ever heard of on the 8.
It may not be a shinka. Just when we ran the vin on car fax it said that it was. and when i said 3 lines. I meant the little bitty lines on the gas gauge. not the bigger ones. we had it serviced anyway as well just in case. Only thing found was AC belt was really bad. And its hard to find anyone who knows anything about these cars to have it worked on. Some guys we took it to did not even know where the oil filter was. and even I knew that. So we took it to many people till we finally found someone who knows about them. Still have not been able to get under car and check for O2 sensor yet. Do I need the back one hooked up?
Old Jan 25, 2009 | 03:13 PM
04RX8man's Avatar
Rotary Powered Countryboy
my mileage with stock cat and catback exhaust is about 16 or 17 in mostly city with 6-8oz of premix.....
BillBertelli
NE For Sale/Wanted
Mar 19, 2016 03:01 PM
Brokegang
Jan 3, 2016 12:45 PM
arexatemate
Oct 9, 2015 06:23 PM
Chapsy
Sep 22, 2015 09:57 AM
Tsurugi
Sep 7, 2015 08:27 PM
