OMP calibration / flow
Old Jan 17, 2009 | 07:03 PM
m4f1050's Avatar
FL OMP calibration / flow
Is there a way to change the OMP injection other than reflashing? Can the sensor be adjusted towards either way to increase/decrease flow?
Old Jan 17, 2009 | 08:05 PM
Easy_E1's Avatar
Cobb Accessport from Mazdamaniac is the easiest way.
Old Jan 17, 2009 | 09:02 PM
m4f1050's Avatar
I consider that reflashing... Besides reflashing there is no other way then?
Old Jan 17, 2009 | 09:06 PM
ShellDude's Avatar
weeeeeeeeee
I'm sure there is but it's beyond me. The flow rate to the pump itself is probably voltage or pulse rate based. figure out the protocol that increases the flow rate to the pump and you can trick it into doing whatever you want.
FWIW, it'd be a whole helluva lot easier to just buy an AP
Old Jan 17, 2009 | 09:11 PM
m4f1050's Avatar
Well I wanted to know if there was an alternative since I am using MAP instead of MAF, maybe I can load stock map with higher OMP flow and use Int-X over that to manage my fuel. I have an SFR turbo kit installed, don't have the MAF appropriate config. to have ECU control my fuel.
Old Jan 17, 2009 | 09:14 PM
Easy_E1's Avatar
Has this been done to the car?
MAZDA SPECIAL PROGRAM (MSP16) - ENGINE LACK OF POWER - PCM REFLASH
Old Jan 17, 2009 | 09:20 PM
ShellDude's Avatar
weeeeeeeeee
what's the point of having an ECU if you're going to bypass it for the things that are inherent, arguably innate, functions? You're already well beyond something "trivial" like flashing your ECU.
This thread is hurting my brain lol
Old Jan 17, 2009 | 09:23 PM
m4f1050's Avatar
Originally Posted by Easy_E1
I don't know, I swapped my hood with a CF hood and sold my old hood.
Would that reflash (MSP16 or whichever) have more or good enough oil injection?
What would be the best for FI?
Old Jan 17, 2009 | 09:25 PM
Easy_E1's Avatar
Take the car to the dealer and ask them if it's been performed on the car. They can look under the VIN # and find out easily all the warranty records of your car.
The reflash is Mazda's fix for an engineering error. Inadequate Oil Metering
If you have Forced induction, You need an Accessport!
ShellDude's Avatar
weeeeeeeeee
MSP16 increases the flow rate considerably and richens your AFR, particularly during warm up.
Old Jan 18, 2009 | 03:44 PM
04RX8man's Avatar
Rotary Powered Countryboy
for FI the AP is def the way to go from what i hear that's bout what everyone around here is using!
Old Jan 18, 2009 | 04:27 PM
paulmasoner's Avatar
Asshole for hire
for FI you definately need the AP. otherwise if you're refusing to flash i think Richard Sohn makes an adjuster as well as his famous adapter
Old Jan 18, 2009 | 10:20 PM
m4f1050's Avatar
Thanks for the info. I was checking but would the "adjuster" go in between the adapter and the motor? If so that would not work for me since I have a top-mount turbo and I already had to modify my OMP sensor to make the exhaust downpipe fit...
Brettus
Series I Engine Tuning Forum
46
Apr 19, 2024 06:28 AM
05rx8mazda
Nov 28, 2015 09:42 AM
XianUnix
Sep 29, 2015 03:48 PM
Devil Doge
Sep 23, 2015 02:47 PM
RAE008
Sep 20, 2015 01:32 PM
