agency power exhaust question
Old Jan 17, 2009 | 01:48 PM
jacky888's Avatar
the hangar for the middle pipe that connects first to the exhaust is like less than a cm from the crossmember and the hangar that holds it is at an angle and is the lowest it goes, anyone know if this is a worry or if its no big deal. so far no rattling but just wanted to be sure
thanks,
jacky
Old Jan 17, 2009 | 02:23 PM
Jon316G's Avatar
Grasshopper
I never had rattling issues with my AP (except when the rivets on the tips came loose)
Old Jan 17, 2009 | 07:52 PM
jacky888's Avatar
how long did it take for it to get loose?
oh curious do you notice if your ap fitment is a little crooked
i think im blind or something it keeps looking like the left exhaust sticks out more than the right
Old Jan 17, 2009 | 10:20 PM
Jon316G's Avatar
Grasshopper
It took a couple years to notice the rattle from loose rivets.
No fitment issues and the exhaust tips look equal distance coming out the shrouds.
Old Jan 18, 2009 | 06:54 PM
jacky888's Avatar
damn i think i fucked up or something, the hangar in your middle pipe to exhaust canisters is it at a angle?
Old Jan 18, 2009 | 08:33 PM
Jon316G's Avatar
Grasshopper
I don't recall the hanger itself being at an angle, though I can't say for sure.
I'll have to look under the car later to see for sure.
Old Jan 18, 2009 | 08:47 PM
toneskii707's Avatar
suck my smog
R u talking about the hanger next to the differential? Cuz if its that then it will rattel against it, what I did was cut off the little piece right after rubber garment works great no issues.
Old Jan 19, 2009 | 10:40 AM
nuke0907's Avatar
Never Blend In
those rivets always come loose.
you aren't blind. mine was crooked and i've heard several other with fitment issues.
Old Jan 19, 2009 | 10:52 AM
gh8st's Avatar
STiMPACK
hm i must've gotten lucky with mine
but my tips seem to be resting on the bottom of the rear bumper guards.. anyone else have this issue?
Old Jan 19, 2009 | 10:54 AM
nuke0907's Avatar
Never Blend In
yes i had to remove mine completely or they would melt.
Old Jan 19, 2009 | 11:07 AM
gh8st's Avatar
STiMPACK
damn for real.... how did you refit the exhaust? it seems to just settle that way.
Old Jan 19, 2009 | 03:40 PM
two zero two's Avatar
Unregistered User
mine was resting on the bumper guards, i just attached one of these around the rubber garment and tightened it to lift it off of them.
Old Jan 19, 2009 | 09:14 PM
gh8st's Avatar
STiMPACK
that's a good idea. I think imma go to ACE hardware to get me some of those
Old Feb 5, 2009 | 07:27 PM
gh8st's Avatar
STiMPACK
worked like a charm
Old Feb 9, 2009 | 11:30 PM
did you keep your shrouds on?
Old Feb 10, 2009 | 11:09 AM
gh8st's Avatar
STiMPACK
the rubber mounts? Yeah i just put the worm gear clamp around it and tightened it
Old Apr 9, 2009 | 06:53 PM
gh8st's Avatar
STiMPACK
does anyone know how to ground the agency power exhaust? I have no idea where to put it
Old Apr 9, 2009 | 07:01 PM
Jon316G's Avatar
Grasshopper
There is no where to ground it on the AP exhaust.
I just removed my ground wire.
Been running fine for several years now.
Old Apr 9, 2009 | 07:03 PM
gh8st's Avatar
STiMPACK
Really? One of the guys at a local meet told me that if you don't ground it, it's dangerous. Are you running a midpipe? Or stock cat?
Old Apr 9, 2009 | 07:10 PM
Jon316G's Avatar
Grasshopper
I've ran the same cat-back with the stock cat, the AP mid-pipe, and the MazSport mid-pipe.
I can't see how the concentration can be THAT bad to where a static discharge can ignite it.
But if you're worried about it, just attach it to the clamp between the "mid-pipe" and the muffler pipe (might need to use a larger ring terminal and probably longer wire).
Old Apr 9, 2009 | 07:22 PM
gh8st's Avatar
STiMPACK
ok cool man, thanks for the info! If you ran ok, i'm sure i'll be fine. appreciate it!
Billy Marcial
Mar 1, 2018 06:50 AM
Jazzmeson
Aug 6, 2015 04:34 PM
Jazzmeson
Aug 6, 2015 04:32 PM
N0P1st0ns
Jul 30, 2015 09:45 AM
