While car is cold, cranking wheel creates a shaking and knocking sound...
Old Jan 16, 2009 | 03:33 PM
CyberPitz's Avatar
Huge hole is huge
I really don't think something is wrong...hopefully.
I get out of work, the temperature is around 20 degrees F. I start my car up, and in order to get out of the parking lot, I need to crank the wheel 100% either way. While doing that and moving, I get a rocking/shaking feeling in the steering wheel and car. A very audible "KNOCK" is coming from the front end of the car. It does not happen when car is warmed up.
At first I thought it was the tires, being cold...maybe a slight flat spot...but the tire doesn't even do a full revolution when this happens. Also doesn't happen in a straight line. My idea is power steering....anybody else?
Also, a search rendered nothing, but then again, cold, knock, steering, noise brought up a bunch of non-helpful threads....
Old Jan 16, 2009 | 06:31 PM
04RX8man's Avatar
Rotary Powered Countryboy
I thought i had the same thing however it just happens that it was the way the tires were grabbing the pavement at my particuar apt. complex...when cold coming out of anywhere else it does not do it just on this pavement when the ouside temp is (yeah not cold) aroudn 45 or so or lower
Old Jan 16, 2009 | 07:18 PM
CyberPitz's Avatar
Huge hole is huge
I plan on getting my camera out maybe tomorrow to see if I can get it on tape...maybe see something specific on the tires or something. *Shakes fist at cold weather*
Old Jan 16, 2009 | 08:27 PM
Rotary Xperiment's Avatar
I have the same problem and still get it from time to time, either in car parking lots---slow turns from rest, or on certain roads. I think it's a combination of the wheels on road surface and maybe the brake pads rubbing against the wheels? I don't know...
Old Jan 16, 2009 | 10:51 PM
04RX8man's Avatar
brake pads would not just do it around turns but all the time if u were having drag on the pads.....
Old Jan 17, 2009 | 12:04 AM
if you are just starting to move. the knock is likely the pads separating from the rotors..
the rest i would think is cold flat spotted tires..
cold is bad.
Old Jan 17, 2009 | 01:15 AM
Marklar's Avatar
Temp was in the 20s this morning, and I noticed a really strange sound when backing out of the driveway. I turned off the radio because I was concerned.
It kept up as I drove down the road a bit then it quit. So in my case I'm guessing cold flat spots on tires, especially since the tire pressure sensor idiot light was on due to the drop in temperature.
Old Jan 17, 2009 | 09:06 AM
04RX8man's Avatar
yeah if it was sort of like a thump for a bit then after a few miles it stopped prob some flat sports on the tires! I get that too every once and awhile
Old Jan 19, 2009 | 03:45 PM
CyberPitz's Avatar
Huge hole is huge
I had the idea of flat spots, but it doesn't seem to be happening with a revolution of the tire...more like every 1/4 to 1/2 revolution. I still have yet to get my camera on this...I just stop taking turns too tight when leaving. After driving for less than 10 seconds, the noise/knocking stops, so weird...
Old Jan 20, 2009 | 03:57 PM
corners's Avatar
An RX ate my baby
I suspect your tires are scrubbing a bit while at full lock. It can be normal or it can mean you need an alignment. It all depends on the steering geometry. All the cars I've ever owned do this to one degree or another, and wide tires make it worse. Its more noticeable in cold weather because the rubber is cold and hard and it doesn't grip as evenly.
Old Jan 20, 2009 | 05:12 PM
CyberPitz's Avatar
Huge hole is huge
That does sound like a good answer. The tires aren't horribly bad yet, but they definitely aren't great. I'm going to be getting a round of new tires in the next few months. Gotta be safe when I finally go to a track
Old Jan 20, 2009 | 05:40 PM
04RX8man's Avatar
^yeah that does sound like a possibility
Old Feb 19, 2009 | 09:46 AM
dmc27's Avatar
doin' the bull dance
Are your lugs torqued to 108?
Old Feb 19, 2009 | 11:07 AM
CyberPitz's Avatar
Huge hole is huge
Buuuhh, iunno. Haven't touched the tires since I got it last year.
Old Feb 19, 2009 | 11:34 AM
dmc27's Avatar
There's a TSB for clicking sounds, but I don't remember anything about shaking.
Old Feb 19, 2009 | 12:52 PM
CyberPitz's Avatar
Huge hole is huge
That's not really clicking, more like someone kicking my tire full force...
Old Feb 19, 2009 | 04:13 PM
rx8mod83's Avatar
Lifting Rx8 Society
i have that same problem i think its the pads rubbing.
Old Feb 19, 2009 | 04:26 PM
CyberPitz's Avatar
Huge hole is huge
As long as I'm not alone! \o/
Old Feb 23, 2009 | 10:17 AM
dmc27's Avatar
Noticed this while looking through the TSB list, and it might apply to your problem --->> TSB for "NOISE FROM FRONT OF VEHICLE / STABILIZER CONTROL LINK BROKEN"
(yes, I did repost from the other thread. )
Old Feb 23, 2009 | 10:37 AM
CyberPitz's Avatar
Huge hole is huge
Hummmm...that does seem interesting. It's so weird, this problem hasn't happened in a while, since it's not been so cold...we've been getting 40 degree F recently at night...silly cold.
Old Feb 23, 2009 | 10:39 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
cold is bad.
This is especially true if you've just washed the car and/or been in there wiping down the calipers. But.....will only make noise one time as they release.
Skyl3r
Dec 2, 2019 04:51 PM
SUKIEE
Oct 9, 2017 09:41 PM
Mr.Durden
Aug 12, 2015 02:21 PM
dbarber
Jul 25, 2015 01:34 PM
AussieGray
Jul 16, 2015 03:58 AM
