bugbear
01-16-2009, 02:47 PM
I just spent an hour trying to find out what the flashing airbag warning light code meant. Well I found a manual with all the codes. Here's the link to the workshop manual and repeated below are the airbag codes for anyone else.
http://user-manual.org/Automotive/Mazda/Mazda-RX-8-2003-Service-Manual.html
The first two digit code eg 18 is the given by the flashing sequence of the airbag light.
eg 18 is 1 flash, pause, 8 flashes.
Hope it helps someone else.
DTC
System malfunction location
Page
WDS display
Air bag system warning light
Flashing pattern
Priority ranking
B1231 13
3 SAS unit activation (deployment) control freeze (See DTC B1231.)
B1342 12
2 SAS unit (See DTC B1342.)
— Continuously illuminated 1 SAS unit (DTC 12 detection circuit malfunction)
B1426 57
21 Seat belt warning light circuit short to power supply (See DTC B1426, B1427.)
B1427 Seat belt warning light circuit open
B1869 — Continuously illuminated 1 Air bag system warning light circuit open (See DTC B1869, B1870.)
— Does not illuminate — Air bag system warning light circuit short to body ground
B1870 — Continuously illuminated 1 Air bag system warning light circuit short to power supply
B1877 33
13 Driver-side pre-tensioner seat belt circuit resistance high (See DTC B1877, B1878, B1879, B1885.)
B1878 Driver-side pre-tensioner seat belt circuit short to power supply
B1879 Driver-side pre-tensioner seat belt circuit short to body ground
B1881 34
12 Passenger-side pre-tensioner seat belt circuit resistance high (See DTC B1881, B1882, B1883, B1886.)
B1882 Passenger-side pre-tensioner seat belt circuit short to power supply
B1883 Passenger-side pre-tensioner seat belt circuit short to body ground
B1884 18
20 Passenger air bag deactivation (PAD) indicator circuit open or short to body ground (See DTC B1884, B1890.)
B1885 33
13 Driver-side pre-tensioner seat belt circuit resistance low (See DTC B1877, B1878, B1879, B1885.)
B1886 34
12 Passenger-side pre-tensioner seat belt circuit resistance low (See DTC B1881, B1882, B1883, B1886.)
B1890 18
20 Passenger air bag deactivation (PAD) indicator circuit short to power supply (See DTC B1884, B1890.)
B1913 19
11 Driver-side air bag module (inflator No.1) circuit short to body ground (See DTC B1913, B1916, B1932, B1934.)
21
10 Passenger-side air bag module (inflator No.1) circuit short to body ground (See DTC B1913, B1925, B1933, B1935.)
B1916 19
11 Driver-side air bag module (inflator No.1) circuit short to power supply (See DTC B1913, B1916, B1932, B1934.)
B1921 14
4 Activation (deployment) inhibited due to configuration setting (See DTC B1921.)
B1925 21
10 Passenger-side air bag module (inflator No.1) circuit short to power supply (See DTC B1913, B1925, B1933, B1935.)
B1932 19
11 Driver-side air bag module (inflator No.1) circuit resistance high (See DTC B1913, B1916, B1932, B1934.)
B1933 21
10 Passenger-side air bag module (inflator No.1) circuit resistance high (See DTC B1913, B1925, B1933, B1935.)
B1934 19
11 Driver-side air bag module (inflator No.1) circuit resistance low (See DTC B1913, B1916, B1932, B1934.)
B1935 21
10 Passenger-side air bag module (inflator No.1) circuit resistance low (See DTC B1913, B1925, B1933, B1935.)
B1992 22
15 Driver-side side air bag module circuit short to power supply (See DTC B1992, B1993, B1994, B1995.)
B1993 Driver-side side air bag module circuit short to body ground
B1994 Driver-side side air bag module circuit resistance high
B1995 Driver-side side air bag module circuit resistance low
B1996 23
14 Passenger-side side air bag module circuit short to power supply (See DTC B1996, B1997, B1998, B1999.)
B1997 Passenger-side side air bag module circuit short to body ground
B1998 Passenger-side side air bag module circuit resistance high
B1999 Passenger-side side air bag module circuit resistance low
B2228 19
11 Driver-side air bag module (inflator No.2) circuit short to body ground (See DTC B2228, B2230, B2232, B2234.)
B2229 21
10 Passenger-side air bag module (inflator No.2) circuit short to body ground (See DTC B2229, B2231, B2233, B2235.)
B2230 19
11 Driver-side air bag module (inflator No.2) circuit short to power supply (See DTC B2228, B2230, B2232, B2234.)
B2231 21
10 Passenger-side air bag module (inflator No.2) circuit short to power supply (See DTC B2229, B2231, B2233, B2235.)
B2232 19
11 Driver-side air bag module (inflator No.2) circuit resistance high (See DTC B2228, B2230, B2232, B2234.)
B2233 21
10 Passenger-side air bag module (inflator No.2) circuit resistance high (See DTC B2229, B2231, B2233, B2235.)
B2234 19
11 Driver-side air bag module (inflator No.2) circuit resistance low (See DTC B2228, B2230, B2232, B2234.)
B2235 21
10 Passenger-side air bag module (inflator No.2) circuit resistance low (See DTC B2229, B2231, B2233, B2235.)
B2296 42
9 Crash zone sensor (communication error, internal circuit abnormal) (See DTC B2296.)
B2434 51
18 Driver-side front buckle switch circuit short to ground (See DTC B2434, B2435, B2691.)
B2435 Driver-side front buckle switch circuit resistance not within specification
B2438 52
19 Passenger-side front buckle switch circuit short to ground (See DTC B2438, B2439, B2692.)
B2439 Passenger-side front buckle switch circuit resistance not within specification
B2444 43
8 Driver-side side air bag sensor (internal circuit abnormal) (See DTC B2444, U2017.)
B2445 44
7 Passenger-side side air bag sensor (internal circuit abnormal) (See DTC B2445, U2018.)
B2477 54
5 Configuration error (See DTC B2477.)
B2691 51
18 Driver-side front buckle switch circuit open or short to power supply (See DTC B2434, B2435, B2691.)
B2692 52
19 Passenger-side front buckle switch circuit open or short to power supply (See DTC B2438, B2439, B2692.)
B2773 24
17 Driver-side curtain air bag module circuit resistance low (See DTC B2773, B2774, B2775, B2776.)
B2774 Driver-side curtain air bag module circuit resistance high
B2775 Driver-side curtain air bag module circuit short to body ground
B2776 Driver-side curtain air bag module circuit short to power supply
B2777 25
16 Passenger-side curtain air bag module circuit resistance low (See DTC B2777, B2778, B2779, B2780.)
B2778 Passenger-side curtain air bag module circuit resistance high
B2779 Passenger-side curtain air bag module circuit short to body ground
B2780 Passenger-side curtain air bag module circuit short to power supply
B2867 31
6 Poor connection of any SAS unit connectors (See DTC B2867.)
U2017 43
8 Driver-side side air bag sensor (communication error) (See DTC B2444, U2017.)
U2018 44
7 Passenger-side side air bag sensor (communication error) (See DTC B2445, U2018.)
DTC
Page
WDS display
Flashing pattern
Priority ranking
B1231 13
B1342 12
B1426 57
B1877 33
B1881 34
B1884 18
B1885 33
B1886 34
B1890 18
B1913 19
21
B1916 19
B1921 14
B1925 21
B1932 19
B1933 21
B1934 19
B1935 21
B1992 22
B1996 23
B2228 19
B2229 21
B2230 19
B2231 21
B2232 19
B2233 21
B2234 19
B2235 21
B2296 42
B2434 51
B2438 52
B2444 43
B2445 44
B2477 54
B2691 51
B2692 52
B2773 24
B2777 25
B2867 31
U2017 43
U2018 44
