swoozie
12-12-2003, 12:18 PM
Even if volume is set to say "7" the driver's side window seems to vibrate. Most annoying. Any thoughts?
Thanks in advance.
Thanks in advance.
View Full Version : Speakers and Window Vibration swoozie 12-12-2003, 12:18 PM Even if volume is set to say "7" the driver's side window seems to vibrate. Most annoying. Any thoughts? Thanks in advance. TownDrunk 12-12-2003, 12:20 PM I found that when I hear the vibration, I can press my hand on the middle of the door panel and a it goes away. Maybe it's not the same vibration you're talking about, but I hear it when my window is up. Spinny 3ngls 12-12-2003, 01:14 PM there is another thread on this which may be what you are referring to do a search under "cold weather door rattle" it has to do with the glue holding the foam blocks against the panel swoozie 12-12-2003, 04:11 PM spinny 3ngls- thanks-checked that thread. Don't see anything specific with the speakers and rattle but will have it checked out. tribal azn2 12-12-2003, 05:05 PM i have the same problem. the driver side speaker in the window vibrates and rattles. very annoying |
