How to pull out the stock stereo???
Old Jan 15, 2009 | 11:18 AM
smitht0789's Avatar
2004 RX-8 Nordic Green
OH How to pull out the stock stereo???
Ok..so i ordered a system for my car online, and got it in. Me and a buddy were tryin to get out my stereo for over an hour, and it just wouldnt come out! Does anyone know how to? Or is there a trick to it? We found directions online and went by them, but still no luck. I would just take it to Best Buy or somewhere like that, but they're gonna charge about $200. Soo if anyone knows of anywhere to take it, or anyone that'd do it for less let me know! thanks.
Old Jan 15, 2009 | 11:21 AM
Socket7's Avatar
ಠ_ಠ
Theres a trick. Theres a bolt you have to remove that you can only reach by dropping the panel underneath the steering wheel and reaching up there with a long socket wrench. Theres a DIY in the interior/audio section of the forum. You should probably memorize the stickies in that section before you begin tearing your system down. It could save you from considerable headaches.
Old Jan 15, 2009 | 11:22 AM
L337fpc's Avatar
ლ(ಠ益ಠლ)
Search....search...search....
DIY: MP3/Factory Head unit removal/install
Old Jan 15, 2009 | 11:24 AM
dynamho's Avatar
This will show you how to remove your factory stereo.
I forgive you this time. Try searching next time.
http://whatsmyip.org/ipodrx8/1.php
Old Jan 15, 2009 | 03:22 PM
04RX8man's Avatar
Rotary Powered Countryboy
SEARCH remove the bolt and it comes right out with a little loving talk and a nice shove (after the bolt is removed) really can't see the bolt to easy just have to get it loose!!!
NOTE: DO NOT LOSE BOLT
Old Jan 15, 2009 | 04:25 PM
04blue8's Avatar
zoom zoom
just got finished (30 minutes ago) putting in an ipod adapter and had to remove the stereo. when your up under the steering column you will look to your left and see two bolts right next to eachother...right behind that metal bar is where that bolt is. good luck
Old Jan 15, 2009 | 08:49 PM
smitht0789's Avatar
like i said before ppl, i did SEARCH and found the directions online, but that didnt help. we undid all of the bolts, and one side of the stereo would come out, the other wouldnt budge. soo anyway i just decided to take it to an audio place, and had them install everything. they didnt even have to pull out the radio? odd.
Old Jan 16, 2009 | 08:26 AM
Shinka_MJR's Avatar
SHKWAV
so how did they remove the radio without pulling out the radio? ya, i'd say that would definitely be "odd".
Old Jan 16, 2009 | 09:10 AM
Renesis07's Avatar
Vtak just kicked in yo!!
What did you install?!
If you didnt change the headunit than all you needed was a line out converter that splices into your rear speaker.......
Now Im confused, it took me like 3 hours and a 12 pack of beer to install mine...
Old Jan 16, 2009 | 11:37 AM
smitht0789's Avatar
haha.."shinka" they didnt have to pull out my radio unit at all..renesis is correct, im assuming they just spliced into the wires in the rear speakers then? It works well and sounds good. Renesis i like your setup alot! Is that a 10 or 12? I just have 2 tens. i had trouble fitting the box into my trunk, had to remove a piece of plastic to get it in. And also when i turn on my key, my subs come on real quick, like "errrr" for a split second, which is odd but w/e!
Old Jan 16, 2009 | 11:50 AM
Shinka_MJR's Avatar
SHKWAV
that "err" in the beginning could mean you aren't grounded properly. I had a powered sub in a previous car of mine that did that. turned out the ground wire was bad. Might want to check it. if the wire is good, check to amke sure the ground point is tight and is indeed a true ground point... for instance, i've seen people put ground wire kits in their engine bay and they've run some of the ground wires to radiator... BAD spot to ground because there are rubber gromits between the radiator and chassis making it not a "true" ground point.
Old Jan 16, 2009 | 12:03 PM
Renesis07's Avatar
Thank you for the compliments!
It is a 10, and I also have another 10 in the trunk as well. My old system (2 10 audiobahns and Kenwood amp) used to make that noise. Then when I bought my new system ( all JL ) it stopped. I didnt change the ground or wiring or anything, just got kinda lucky I guess.
Just for ***** and giggles, I attached a couple pics of my setup.
Attached Thumbnails How to pull out the stock stereo???-rx8club11.jpg   How to pull out the stock stereo???-rx8club10.jpg
Old Jan 16, 2009 | 01:20 PM
04RX8man's Avatar
oh damn if we would have know u were just installing a system and not a head unit we def could have told u that it did not need taken out!!!!
Renesis 3 hours and a 12 pack?? I think the 12pack is what made it take 3 hours haha
Old Jan 16, 2009 | 04:37 PM
Renesis07's Avatar
Yea I dont remember much of that install
EDIT: for the OP, I found a pic on my computer that shows the line out converter. This is what you use to connect your stereo, this doesnt involve going behind the head unit, incase you were wondering how they installed it.
Attached Thumbnails How to pull out the stock stereo???-rx8clublineoutconv.jpg
Old Jan 16, 2009 | 06:34 PM
04RX8man's Avatar
^my line out converter i connected to my rear speaker wires behind the head unit but now that i think i guess u didnt' have to !!!! haha maybe it was the 12 pack that had me thinking wrong too!!!
Old Jan 16, 2009 | 08:20 PM
moete87's Avatar
Ohio State
Smith, I could of done it for you. Its easy.
Old Jan 17, 2009 | 12:57 AM
smitht0789's Avatar
haha well thanks moete! I would have bought yours! but u pm me like a day too late!! ah..oh well. but ya thanks eveyrone for commenting. renesis love your setup, seems really nice!
Old Jan 17, 2009 | 06:48 PM
Renesis07's Avatar
Thank you kind sir
Old Jan 19, 2009 | 10:34 AM
dynamho's Avatar
The line of sight to the correct bolt on the driver's side that holds the stereo is elusive. The bolt you removed from the metal dash brace(?) is incorrect. That bolt does not seem to be fastening anything. It's just there.
Brettus
Series I Engine Tuning Forum
46
Apr 19, 2024 06:28 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
WranglerFan
Nov 5, 2017 09:35 AM
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
