broke mazsport ppf
Old Jan 13, 2009 | 04:18 PM
cflrx8's Avatar
broke mazsport ppf
Bad wheel hop caused this but i want opinions on the design and maybe how to make it stronger
Attached Thumbnails broke mazsport ppf-picture011.jpg   broke mazsport ppf-picture014.jpg   broke mazsport ppf-picture015-1.jpg
Old Jan 13, 2009 | 04:24 PM
Red Devil's Avatar
Maybe ditch that piece and go to a solid, non-welded piece of bar stock and machine the ends. Would be heavy but strong.
Approximately how much power were you putting to the ground when this happened?
Old Jan 13, 2009 | 04:29 PM
bse50's Avatar
#50
Put on the stock one for a while and see how long it lasts. Machining a new one that will meet above-stock specs is very hard.. so better go back to stock and see what happens before thrashing money again
Old Jan 13, 2009 | 04:31 PM
Red Devil's Avatar
It's probably for the FD tranny in the Rx-8, so the OEM ppf won't mate to his application...
Old Jan 13, 2009 | 04:33 PM
bse50's Avatar
#50
That's a whole different story then.
Old Jan 13, 2009 | 04:50 PM
cflrx8's Avatar
I'm n/a but also when it broke, my driveshaft rubbed on the exhaust and its scratched pretty bad with fibers sticking out do you think its ruined?
Old Jan 13, 2009 | 05:37 PM
cflrx8's Avatar
The problem with this particular design is that; 1) it is using thin-wall tubing, and, 2) it doesn't control the oscillating forces generated by the transmission's output shaft, which occur at the same time as vertical forces from the rear diff are also present. I have had this idea in my head for 5 years and............
The other part connects the transmission to the frame does that take care of the oscillating forces?
Old Jan 13, 2009 | 05:39 PM
mysql's Avatar
Doppelgänger
i think the AT solid driveshaft is a direct replacement. if so, get that. it'll weight a little more though.
Old Jan 13, 2009 | 08:38 PM
cflrx8's Avatar
can i safely drive without it?
Old Jan 14, 2009 | 08:53 AM
RX8-Frontier's Avatar
Back to your original questions...
If you're just planning on re-welding it, is add more bracing at the point of connection on the right-hand side of that photo. Put in a web brace, welded to the two tubes and again to the bracket. That will make it a whole lot more solid at that connection; essentially those tubes weren't broken off by shear; they were twisted off. A good web brace in there will prevent the twisting at that point and prevent that from happening.
However, the twisting motion is still pretty severe, it seems, and you may not really be able to prevent another failure without going with a thicker tube, or a stronger metal. These particular tubes show they can't withstand the twisting, and even if you firm up the connection at the bracket, that twisting is still happening; the failure point will just move farther down the tube away from the bracket, eventually. Start thinking about either a thicker tube (say 3/16" wall) or a stronger metal (DOM or Chromoly)
Old Jan 14, 2009 | 03:36 PM
cflrx8's Avatar
I'll have it re-welded for now so i can drive it at least, and see about getting extra bracing like you described.
Could the diff just be connected to the frame nearby instead?
Old Jan 14, 2009 | 09:30 PM
olddragger's Avatar
no
OD
Old Jan 15, 2009 | 11:21 AM
bse50's Avatar
#50
Haven't you got your stock one? even with the extra braces you could buy it would still be a weak\garbage PPF.
Looking at the pictures i don't really know how this could be meant and sold as a "performance" upgrade.
Old Jan 15, 2009 | 04:26 PM
04RX8man's Avatar
Rotary Powered Countryboy
GO SOLID no welds...it's alot tougher
Shankapotamus3
Mar 14, 2021 03:53 PM
extreme_rotary
Jan 22, 2019 11:53 AM
Crazy.8
Apr 18, 2017 03:17 PM
Forevermore
Sep 20, 2015 01:04 PM
PTQLam
Sep 5, 2015 01:14 PM
