Redlining and Rotors problem
Old Jan 13, 2009 | 09:00 AM
bballboi948's Avatar
So, I just got my 8 and I had a few questions:
When we refer to "redlining", does that mean flooring it, or just gradually gasing up to the redline? As far as the saying "One redline a day, keeps the carbon away", does it matter which gear you redline to clear out the carbon in order to prevent flooding?
Also, I have an issue when braking relatively hard from speeds over 50. The back of the car would shake somewhat significantly when this happens. I asked my friend about it and he said it is most likely the rotors not being smooth and even. Any insights?
Old Jan 13, 2009 | 09:02 AM
drive it hard, and u'll be fine.
Old Jan 13, 2009 | 10:04 AM
zoom44's Avatar
you could have them checked but you are probably feeling the ABS. Have you had a car equipped with ABS previously?
Old Jan 13, 2009 | 10:37 AM
JRichter's Avatar
Void Where Prohibited
"Redlining" is simply allowing the engine to reach rpm's at which the "redline" is designated regardless of gear or the rate at which you get there. As far as driving the RX-8, just be sure to hit (or even almost hit) redline every once-in-while at wide open throttle once the engine is fully warmed up. I probably do it at least once a drive as I don't need much convincing to do this.
Old Jan 13, 2009 | 11:22 AM
CyberPitz's Avatar
Huge hole is huge
I try to do it once every time I drive...but since it's so freaking cold, it takes longer to get my engine fully warmed up, so by the time it IS warmed up, I have no place to floor it, as if I floor it in first gear, I'm already 5 over the speed limit... bah!
Old Jan 13, 2009 | 11:32 AM
warwickben's Avatar
welder/bender/machinist
can you do the redline trick while coasting ie out of gear?
Old Jan 13, 2009 | 11:43 AM
CyberPitz's Avatar
Huge hole is huge
No, there is no load on the engine. The big point of the 'redline a day' is doing it while in gear. It forces open every inch of the intake and helps to blow off that carbon...
Old Jan 13, 2009 | 11:51 AM
Welcome to the club.
Use 2nd gear as it peaks at 68 mph. Then you won't get a ticket.
Old Jan 13, 2009 | 12:45 PM
Renesis07's Avatar
Vtak just kicked in yo!!
I get my daily redline in 5th gear.
jk...kinda
Old Jan 13, 2009 | 07:44 PM
newguy's Avatar
zoom fuckin zoom
^now thats a nice commute
Old Jan 13, 2009 | 07:57 PM
JGR4444's Avatar
GR
haha i am entertained by this thread... mostly from the one that says... the redline trick.... this is not an extreme sport.. drive your damn car like it should be.. you bought a sports car for a reason... no go out and drive!
and redline in 5th gear.. damn man i think i found someone to finally keep up
Old Jan 13, 2009 | 08:03 PM
kersh4w's Avatar
Hit & Run Magnet
jk...kinda
thats 148mph.
Old Jan 13, 2009 | 08:13 PM
Renesis07's Avatar
Originally Posted by kersh4w
thats 148mph.
Actually its 147 at 9000 rpms.
and I was kidding
Old Jan 14, 2009 | 11:01 AM
And one hell of a long straight a way.
Old Jan 14, 2009 | 02:56 PM
04RX8man's Avatar
Rotary Powered Countryboy
^yes definately quite a straight away!
Old Jan 14, 2009 | 03:08 PM
bose's Avatar
Reginald P. Billingsly
Redlining keeps the engine healthy but it must be done under a load (in gear) and is better to do WOT, than partial throttle.
The vibration could easily be abs does it have any noises along with it. Could be warped rotors but I would highly doubt it. Especially ion the rear brakes.
Old Jan 14, 2009 | 03:12 PM
Sorry, but what do you mean by WOT and partial throttle?
As far as the shaking goes, it's pretty significant and noticable, but is this normal if it is the ABS? As far as noises, there isn't any screeching or anything like that. It just shakes from side to side.
Old Jan 14, 2009 | 06:33 PM
04RX8man's Avatar
WOT is Wide Open Throttle...partial throttle well is Part throttle i.e. not WOT
Old Jan 15, 2009 | 03:57 PM
Hey guys,
When redlining, is it bad to go so high that you hear the beep? Is that bad for the engine? Also, when do you guys add more engine oil, when the dipstick is @ low? or what?
Thanks for the help!
Old Jan 15, 2009 | 04:04 PM
czar's Avatar
Almost boosted
>_> not bad for it read above,
i check the oil and top it off every other gas station trip
Old Jan 15, 2009 | 04:15 PM
always.anthony's Avatar
is looking for his torque
Originally Posted by bballboi948
Hey guys,
no, rotaries love to rev, the reason for the 9.3k limiter, is cause at that high of revs, the engine loses its effiency, therefore losing power.
you dont litterally have to redline once a day, but its good for the engine, atleast 7.5ks a day, that opens all the exhaust ports so there is no carbon buildup
Old Jan 15, 2009 | 04:46 PM
04RX8man's Avatar
take the RPM's up in the higher range above 6500 to open the last valve and injectors up.....the beep is just there to tell u that ur getting close to rpm's becasue this car rev's so easily you can lose track of where u are...
as for oil i fill up when i'm about halfway between full and low that is about a qt...unless going to the track or a long drive i make sure it's at full before i go
Old Jan 15, 2009 | 05:00 PM
bose's Avatar
Always add oil before you get to 'low' try to keep it as close to 'full' as possible, mine generally rests at about 3/4 to full. Still not sure on the brake issue, you make need to take it somewhere, kinda difficult to get an idea of what's wrong w/o seeing/hearing.
xAgyex
Jun 3, 2026 03:47 PM
uZu
Dec 30, 2015 12:35 PM
TJSiegrist
Sep 10, 2015 09:29 AM
GracefulShanks
Aug 18, 2015 11:40 AM
Belalnabi
Jul 17, 2015 07:48 PM
