tailsmoke removal?
Old Jan 12, 2009 | 07:58 PM
Jeromie's Avatar
tailsmoke removal?
Anybody know how to remove spray on tail smoke/tint? I tried a paint remover... Do I just rub it on there or is there something else I need to do?
Old Jan 12, 2009 | 08:02 PM
Fathead_03's Avatar
VRX8
That may work, but will most likely leave your tails hazey. Probably need to sand it off, then keep sanding and buff them out. Most likely ALOT of work. I used to polish out wrx headlights. Big pain. Start with 1000, 1500, 2000, 2500, then buff the hell out of it. Might be better off getting another pair.
Old Jan 12, 2009 | 09:51 PM
Jeromie's Avatar
I c. I was kinda thinkin I might just have to get new ones.. Suks tho...
Old Jan 12, 2009 | 10:00 PM
briann's Avatar
Try trading it in the FS/FT section of the forum?
Old Jan 13, 2009 | 01:25 AM
Fathead_03's Avatar
VRX8
There are a set here near me for $70 for the pair on craigslist.
Old Jan 13, 2009 | 01:52 AM
cfm251's Avatar
maybe gasoline?
Old Jan 13, 2009 | 02:26 AM
kersh4w's Avatar
Hit & Run Magnet
pretty much the only way.
Old Jan 13, 2009 | 10:40 AM
Jeromie's Avatar
Yea ima try this out first... If not ill just but new ones...
Old Jan 13, 2009 | 10:46 AM
shakeyourbrakes's Avatar
waitt, dont go buy new ones...go get a can of acetone from autozone and a rag, and just soak the rag and wipe the smoke off. Trust me, I take off my red tint spray and clear coat on my taillights every year for inspection (5 or 6 times so far). It hasnt hazed the plastic or damaged the taillights yet. Good luck
Old Jan 13, 2009 | 08:51 PM
Jeromie's Avatar
acetone huh.. ill give it a try. thanx for everyones help!
Old Jan 14, 2009 | 10:29 PM
Jeromie's Avatar
ACETONE..... WOW..... i didnt know that i could buy over the counter ACID!
so i read all the warnings on the bottle and man there were a lot.....
i applied to my left headlight and slowly but surely it came off with a little bit of haze im sure i can get out by buffing it, or polishing it....
i got just a little impatient with how long the first one took...................
i started my second taillight..............
i poured the bottle on the light.......
then i started to hear noise from the light? i was like wtf!?
anyway it ate the seals around the light, cracked the crap out of it and soooo much fog inside..... i need a new passenger light
acetone is baaaaad (for newbs)
Old Jan 14, 2009 | 11:58 PM
kersh4w's Avatar
Hit & Run Magnet
bwahahah.
you didnt think that a substance that can eat away paint will do wonders to glue?
Old Jan 23, 2009 | 12:46 AM
Jeromie's Avatar
doode it didnt just eat the glue..... it ate some of the plastic! telling you this stuff is like acid! but whatever..... im posed to get new lights tommorow....
Old Jan 23, 2009 | 01:23 AM
hakuna matata!
sounds like an easier way to get the tailights open instead of baking them!
Old Jan 23, 2009 | 02:27 AM
wow not sure your process, or what acetone you were using..but ive been using the acetone in the green bottle in the paint section of autozone, and it works everytime. Ive literally taken my red tint off about 5 times with no fogging or anything your talking about. I never poured it over the lights, but a little on a paper towel and wiping always took it right off. Sorry to hear though, i tried giving my advice
Old Jan 23, 2009 | 05:56 AM
Ryan2008's Avatar
Registered Paratrooper
Hahaha, and now you know, the power of acetone.
mdl0209
May 23, 2019 05:46 PM
Racingjunkie
Sep 29, 2015 05:05 PM
xAgyex
Sep 28, 2015 08:54 AM
Learners_Permit
Sep 27, 2015 07:38 PM
