Running over boulders is not good!!
Old Jan 11, 2009 | 01:44 AM
budracer2000's Avatar
Whatever!!
So Yesterday I was traveling on a winding road and I came around a corner doing about 65 an there were boulders across both lanes. So I got on the brakes hard but they were to close to avoid and I tried to go over the smallest one. I went over it under the middle or more to the driver side of the car and dragged it a little ways as I pulled over to the side of the road to a gravel area, when I went onto the gravel the boulder caught the ground and I drove over the rest of the way. It made my car jump at least a foot in the air. The only ill affects I can tell is when my car is just idling it is kinda rough and vibrates where is didnt before hand.. Any ideas before I take it into the dealer?
Old Jan 11, 2009 | 01:45 AM
tubingchamp's Avatar
What mawd bug?
You broke your motor mount I think :P
Old Jan 11, 2009 | 02:03 AM
G3tR3DDY2GR3DDY's Avatar
id say you busted your cat, get it checked out. Thats the only real bad thing or you could have hit a fuel line or brake line. check it out for sure
Old Jan 11, 2009 | 02:05 AM
What mawd bug?
If he went up in the air and landed, it would cause enough impact to damage a motor mount, would it not? I damaged mine when I curbed my car last winter..
Old Jan 11, 2009 | 03:44 AM
staticlag's Avatar
The Professor
Ouch. That sounds nasty.
Theres a bunch of stuff that could be potentially wrong. Maybe dented oil pan, shattered cat, blown shock, damaged A/C condenser damaged radiator, dented fuel tank, crushed fuel line, messed up alignment.
Old Jan 11, 2009 | 05:49 AM
mazdaverx7's Avatar
RX-Heaven
i would also think that the engine mount would have taken quite a beating. if the converter were damaged i would think it would be mostly plugged due to it crumbling and plugging the exhaust pipe and remaining converter element.
Old Jan 11, 2009 | 12:54 PM
04RX8man's Avatar
Rotary Powered Countryboy
like staticlag said lots of things could b wrong
Old Jan 11, 2009 | 05:07 PM
greg985's Avatar
The 337
take it to a shop
Old Jan 12, 2009 | 12:53 AM
Maaz's Avatar
i also think you broke your engine mounts
Old Jan 14, 2009 | 10:41 AM
Renesis07's Avatar
Vtak just kicked in yo!!
motor mounts
+1 on taking it to the shop.
Old Jan 14, 2009 | 10:47 AM
Phi's Avatar
Phi
Phi
where do these boulders come from?? this happened to me couple weeks ago... i was apply to dodge it though.
Old Jan 14, 2009 | 10:49 AM
ah.... sorry, but do not take it to a shop unless they let you look underneath the car to see the damages.
A muffler shop might be good for this or small automotive shop.
Otherwise they will sell you a bill of goods.
This is serious. Need to check it out.
Old Jan 14, 2009 | 10:50 AM
07RX8CHICAGO's Avatar
damn!
Old Jan 14, 2009 | 10:51 AM
ferg's Avatar
you have boulders, and we have old peaple driving and stoping on the roads and peaple end up running them over lol
Old Jan 14, 2009 | 11:00 AM
You need to be careful in the mountains and hilly areas during winter spring and rainy conditions.
Even summer can pose problems as many of these roads are not cleaned by the state.
Old Jan 14, 2009 | 06:24 PM
04RX8man's Avatar
^you need to be careful anywhere u drive!
escapedan
RX-8 Racing
58
Feb 10, 2020 06:11 PM
uZu
Dec 30, 2015 12:35 PM
9krpmrx8
Nov 5, 2015 11:45 PM
TheWhiteAce
Series I Engine Tuning Forum
Aug 6, 2015 02:26 PM
