My car was towed with a missing motor mount!
Old Jan 9, 2009 | 03:49 PM
turborx8's Avatar
Boost 4 Life
I was working on removing the turbo from my car in the underground parking of my condo and I guess I am not allowed to work on my car in my building so they towed it!
How much damage do you think they caused?
Old Jan 9, 2009 | 03:52 PM
gregs's Avatar
Pull My Finger
ouch... i would think just damaging the opposite side engine mount mostly?
was the opposite side mount completely tight?
Old Jan 9, 2009 | 03:55 PM
Kane's Avatar
Senior Member
That might be bad..... your passenger side one huh?
Old Jan 9, 2009 | 03:57 PM
lepichichi's Avatar
I LuV mY Rotary....
damn that sucks!
Old Jan 9, 2009 | 04:06 PM
Renesis07's Avatar
Vtak just kicked in yo!!
DId they try contacting you? wow, I didnt think they would just tow it like that. I would flip out.
Old Jan 9, 2009 | 04:14 PM
turborx8's Avatar
Boost 4 Life
The drivers side mount was never touched. The passenger side mount and bracket was removed completely.
The passenger front wheel only had two lug nuts hand tight.
Old Jan 9, 2009 | 04:15 PM
turborx8's Avatar
Boost 4 Life
No attempt was made to contact me.
Old Jan 9, 2009 | 04:16 PM
Kane's Avatar
Senior Member
Was the turbo in there?
Old Jan 9, 2009 | 04:17 PM
CyberPitz's Avatar
Huge hole is huge
That's pretty shitty. I hope no dmg was done!
04RX8man's Avatar
Rotary Powered Countryboy
i think that they would have had to try and contact u before towong
Old Jan 9, 2009 | 04:26 PM
turborx8's Avatar
Boost 4 Life
The only step left was to remove the downpipe, turbo and manifold. Everything else was done.
Old Jan 9, 2009 | 04:28 PM
turborx8's Avatar
Boost 4 Life
Yeah, no kidding!
I was told I am not allowed to do oil changes in the underground parking. This is a brand new building and there is no condo board so no rules are set in stone yet.
Old Jan 9, 2009 | 04:34 PM
Kane's Avatar
Senior Member
Yeah that is bad news man - thinking of the 4-6 inches of movement you have there; and how rough the tow truck was / was not... you can have turbo, WG actuator, piping, oil filler neck damage..... oh man the list goes on!
Now the crank pully will sit on the front crossmember when the engine gets low enough (don't ask); so if it just dropped straight and then rested - you might luck out.
Old Jan 9, 2009 | 04:47 PM
DOMINION's Avatar
I don't buy Kool-Aid
Dam. I would burn that place down
Old Jan 9, 2009 | 04:48 PM
Kane's Avatar
Senior Member
Wait a minute - did you have just the mount off or the braket too?
If it was JUST the mount.... you lucked out big time.
Old Jan 9, 2009 | 05:00 PM
04RX8man's Avatar
above he said mount and bracket!!!
Old Jan 9, 2009 | 05:01 PM
Kane's Avatar
Senior Member
You're right my bad - I didn't read all the way.
Yeah dude - my previous doom and gloom post still applys.
Renesis07's Avatar
I would ****** move out.
That is BS bigtime.
Old Jan 9, 2009 | 05:03 PM
czar's Avatar
Almost boosted
o gezz, why i miss having a garage
Old Jan 9, 2009 | 05:11 PM
turborx8's Avatar
Boost 4 Life
Holly ****!
Old Jan 9, 2009 | 05:12 PM
Kane's Avatar
Senior Member
Pray for a dented crank pulley only.... all else would be mo- worser-er-est.
Old Jan 9, 2009 | 05:21 PM
mauriipince's Avatar
omg that sucks. there should not be any major problems. just check your motor mounts
Rhawb's Avatar
Has the whole shit.
I showed up to an empty garage/driveway when I lived with 3 roomies one day, only to find one of the roomies home. I asked him if his car was in for service and he said it was. We just talked about what had gone wrong for a while, finally he goes "wait, are you being serious?" Turns out the asshats with our HOA had his car towed from our driveway without even telling us it was being taken. We nearly called the police since we couldn't find any confirmation that it was actually towed.
In short: No, they apparently don't have to notify you.
Old Jan 9, 2009 | 05:48 PM
mryoshi's Avatar
Pyscho Dad
Try and find out who called it in.
Then call in middle of night to have theirs towed. Make up some reason that sounds official.
Repeat this until you think they have incurred as much cost as the damage they caused your car. Use different towing companies each time.
Old Jan 9, 2009 | 05:55 PM
Bunique's Avatar
Ground Assault
wow that sucks.....flood the apt and just walk out. haha j/k
