anyone know how to change oil on the new 09 rx8???
Old Jan 8, 2009 | 09:34 PM
93'roadwarrior's Avatar
Red face anyone know how to change oil on the new 09 rx8???
hey guys I'm in the middle of changing the oil on my r3... Just wondering where is the oil drain plug for this thing? I already took off the underside cover and I can see the oil filter at the bottom but I can not seem to find the drain plug.... All I see is a sensor there, anyone? Any help will be appreciated thanks!
-dru
Old Jan 8, 2009 | 09:37 PM
04RX8man's Avatar
Rotary Powered Countryboy
uh I'm not positve about the 09's but the older ones have the drain plug on the direct oposite of the sensor!!!! You should not b able to miss it!
Old Jan 8, 2009 | 09:40 PM
LPCOKIE's Avatar
you have a flat hex nut about four inches from the oil filter . of courses all of the pan must be off to get to both of them you need to learn to use the search
Old Jan 8, 2009 | 09:55 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Huh? What?
Old Jan 8, 2009 | 10:03 PM
MikeTyson8MyKids's Avatar
wat?
Old Jan 8, 2009 | 10:09 PM
04RX8man's Avatar
what y wold he take the oil pan off to change oil??? Do i do it wrong by just taking off the oil drain plug
Old Jan 8, 2009 | 10:23 PM
ASH8's Avatar
Super Moderator
-dru
It's probably too late..
But as an 09 owner yet to change their oil.
1. You need to remove the hard silver (metal) sump guard (I think 7x 10mm bolts)
2. You then need an 8mm HEX (allan) Key with a long handle as the sump plug has changed to a recessed FLAT Looking type.
3. You have also seen the new oil filter (longer).
Old Jan 8, 2009 | 10:25 PM
ASH8's Avatar
Super Moderator
NO , the Series II RX-8's have a different Sump Guard that has to be removed to find the Drain plug/filter.
Old Jan 9, 2009 | 04:26 AM
Thanx guys I found it... I removed the sump guard, found the flat hex nut, and changed my oil. What a pain in the a$$ to remove the filter for the first time though let me tell you. I had to punch a screw driver through the side of it just to get it loose enough to twist it off by hand. Anyway Thanx to everyone who contributed your advise really helped.
-dru
Old Jan 9, 2009 | 04:33 AM
ASH8's Avatar
Super Moderator
-dru
Great news, tell me please, is there much room to get your hand around the filter so you can loosen it to unscrew the filter...
I some how don't think so..
That is why I have ordered the genuine oil filter tool (from Mazda Australia, only $8.85AU), those wrench caps that goes on the end of the filter to remove it.
Genuine Mazda Part # 49 G014 001
Just be careful the ones US Mazda Dealers sell (well some) are non genuine and for 76mm Cap Oil Filters, you need a 66mm one that will fit, for the OEM Filter.
I guess Mazda USA have the genuine ones?
Old Jan 9, 2009 | 04:49 AM
There was barely enough room to get my hands in and twist the filter off. I'm sure the oil filter tool from mazda would have helped though. Good luck changing your oil. Hopefully this thread helped. And thanx for the part number.
Old Jan 9, 2009 | 05:04 AM
mazdaverx7's Avatar
RX-Heaven
first i've ever heard of the oil filter facing towards the bottom of the car on a rotary engined car. mazda must have made some major changes that i overlooked in my readings of the S2 RX-8..
Old Jan 9, 2009 | 05:35 AM
Sleepy-z's Avatar
It was lost in translation in my training but how many qts. did it take? Our trainer said some like 7 or 9 qts. , I forgot but honestly I had trouble understading him in a 15 min. training and I wasnt sure if that was right.
Old Jan 9, 2009 | 05:40 AM
you sure be didn't say 3.7 or 3.9 qts of oil? That's how much I put in.
Old Jan 9, 2009 | 06:04 AM
ASH8's Avatar
Super Moderator
Yes, check out my sticky thread on the Mechanical Changes to the S2 RX-8, there are so many and I am slowly getting through all of them, well I am trying...
Mazda have just about replaced every component (mechanically) on this car...it is almost ALL new!
https://www.rx8club.com/series-ii-technical-trouble-shooting-160/mechanical-changes-rx-8-series-i-ii-161665/
Old Jan 9, 2009 | 06:12 AM
heyarnold69's Avatar
Rotary wanabee
oil filter relocation what?
Old Jan 9, 2009 | 07:19 AM
Sleepy-z's Avatar
Yeah maybe thats it, honestly they use different measurements in japan so he might have meant that or something. Dont worry we havent made any yet, if any 09's go bad we have about 8 brand new AT's and MT's to ship out before we rebuild any.
Old Jan 9, 2009 | 08:44 AM
Huey52's Avatar
Registered Zoom Zoomer
Part of the '09 redesign (all variants). The oil filter is now on the bottom.
Old Jan 9, 2009 | 08:51 AM
ys2003's Avatar
So, what difference are there between the new version and the previous one as far as the oil change procedure is concerned?
Old Jan 9, 2009 | 08:59 AM
-dru
Ywa air~ That's pretty much standard on all new cars. Use the screw driver.
After that ..... never take it in as they will use an air impact gun.
Old Jan 9, 2009 | 09:30 AM
Tim Tim Tim's Avatar
auto suckkssssss
Originally Posted by ys2003
So, what difference are there between the new version and the previous one as far as the oil change procedure?
change your oil then read this.. your question will be answered. Old version, jack up car, unscrew dain plug, put plug back in, change filter, fill with oil
Old Jan 9, 2009 | 10:58 AM
06shinka06's Avatar
John James
take it to the dealership for a oil change u get a free car wash
Old Jan 9, 2009 | 01:08 PM
mazdaverx7's Avatar
RX-Heaven
all rotaries up until now had the oil filter pedestal on the rear iron facing upwards on the RX-7 and at a slant on the RX-8. the 83-85 RX-7's with the 12A's are the only odd man out with the beehive water to oil oil cooler on the rear iron. all other years incorporated a front mount oil cooler(s).
Old Jan 9, 2009 | 03:10 PM
04RX8man's Avatar
yeah i think tht the cars getting oil changes done at mazda the oil filters are on CARZY tight i have noticed that before!!
Skyl3r
Dec 2, 2019 04:51 PM
foxyRoXy8
Aug 18, 2015 10:26 PM
dohon
Aug 1, 2015 01:46 PM
RotaryRider
Jul 20, 2015 07:05 AM
