window stuck down
Old Jan 8, 2009 | 02:47 PM
mikeb's Avatar
100% Italian
window stuck down
my passenger side window is stuck down and wont come up
its the third time this has happened
the master switch i need from mazda is not in stock in CA
does anyone know how to manually pull the window up for the time being????
Old Jan 8, 2009 | 02:55 PM
Renesis07's Avatar
Vtak just kicked in yo!!
take the door panel off?
Old Jan 8, 2009 | 02:57 PM
mikeb's Avatar
100% Italian
yes i took the door panel off already
mazda doesnt have the part in stock so im stuck with a window down
im not sure how to pull it up manually
Old Jan 8, 2009 | 03:21 PM
04RX8man's Avatar
Rotary Powered Countryboy
it should have an electric motor with a coil spring asist and you should b able to push fro the bottom to get it up
Old Jan 8, 2009 | 03:26 PM
expo1's Avatar
He's as bad as Can
Since you have the panel off are you able to tell it the motor works, issue with the switch or is the window off the track?
mikeb's Avatar
100% Italian
hmmm
i can touch the top of the window but i cant get to the bottom
Old Jan 8, 2009 | 03:28 PM
mikeb's Avatar
100% Italian
since the master switch has been replaced twice already i assume its the switch again
Old Jan 8, 2009 | 03:33 PM
expo1's Avatar
He's as bad as Can
Then you should be able to short the switch in order to get the window back up till you can get an new switch.
Old Jan 8, 2009 | 03:36 PM
mikeb's Avatar
100% Italian
^^ ill have to try that
just kinda pissed it goes out every year or so and mazda doesnt even have 1 in stock
Old Jan 8, 2009 | 03:39 PM
expo1's Avatar
He's as bad as Can
Try Paul @ Mazmart, he should have a few around.
Old Jan 8, 2009 | 03:43 PM
Silver06's Avatar
Zoom Zoom....
Any idea why your switches are failing?
Are they getting moisture, or are they melting from over-voltage?
I haven't heard of the bypass switch failing before. Have you tried to take the switch(es) out and clean with some contact cleaner?
Old Jan 8, 2009 | 03:44 PM
bose's Avatar
Reginald P. Billingsly
If the same part keeps failing something else may be going on. There is only so much that can fail on a switch.
Old Jan 8, 2009 | 04:43 PM
mikeb's Avatar
100% Italian
how would i short the switch ???
Old Jan 8, 2009 | 04:49 PM
zoom44's Avatar
you must be getting water in there somewhere
try these mike
Old Jan 8, 2009 | 04:52 PM
expo1's Avatar
He's as bad as Can
I do not know how that back of the window switch looks but it can't be too far off from a standard light switch. Find the two contacts on the switch and connect them with a small section of wire or a screw. You would be replicating the same thing depressing the switch would do, completing the circuit.
Old Jan 8, 2009 | 04:54 PM
zoom44's Avatar
^^ paperclip
Old Jan 8, 2009 | 07:05 PM
04RX8man's Avatar
^yeah u are jumping the switch from power before the switch to power after the switch! a paperclip will work but may get warm ahah a short piece of wire is ideal!
Old Jan 10, 2009 | 02:34 AM
mikeb's Avatar
100% Italian
got the master switch for 150.00 and installed it in like 5 minutes
window is up now
i think it keeps getting shorted from water hitting it when i wash my car
Old Jan 10, 2009 | 04:50 AM
DOMINION's Avatar
I don't buy Kool-Aid
@ Zoom44 post oh man.
My passanger side windo just went down one day and never came back up. I could hear the motor but the window would just rock up and down. As if it wanted to go up but something was stopping it. It was going out. I guess over time and all he sand out here in Vegas got all over the grees that was on the rail preventing it from rolling up and down smoth.
So one hot summer day i rolled the windows down and heard my passanger window fall. Took the door panel off and went to the dealer with everything wraped up in my trunk. They replaced it under warrenty and told me this is the 3rd on they seen that month.
Turns out it was not the motor but the plastic that holds the window on the rail broke and thats why the window fell out of place.
Old Jan 10, 2009 | 08:05 AM
04RX8man's Avatar
yeah tape that switch and everything up with electrical tape if u think it's water getting in there. is your inside of ur door panel getting wet? Is it wet?
Old Jan 10, 2009 | 01:36 PM
mikeb's Avatar
100% Italian
i have noticed after i wash my car and open my driver door a ton of water comes down thru the bottom--honestly i never really cared
but the switch has gone out three times and obviously that is why
ill try electric tape
thanks guys
ESPECAILLY ZOOM for your input LOL
Jst4fun
Mar 5, 2021 07:16 PM
BillBertelli
NE For Sale/Wanted
Mar 19, 2016 03:01 PM
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
Steve Dallas
RX-8 Racing
10
Oct 7, 2015 10:30 AM
nferguson88
Oct 6, 2015 12:45 PM
