Vendor Request: Intake straightener
Old Jan 7, 2009 | 02:30 PM
mysql's Avatar
Doppelgänger
AEM makes these for the Mazda3 CAI only. It's too small for our CAI.
It would be great if someone picked up this project and mass produced them for us. This setup would allow us to straighten out the air in a shorter distance. Just need something that won't slip out of place when secured with a coupler.
Any vendors here able to produce them?
Attached Thumbnails Vendor Request: Intake straightener-dsc03646.jpg   Vendor Request: Intake straightener-dsc03647.jpg   Vendor Request: Intake straightener-dsc03651.jpg
Old Jan 7, 2009 | 02:58 PM
rotary.enthusiast's Avatar
The Local Idiot
Interesting. I wonder how something like this would compare to the job that the OE screens do?
Old Jan 7, 2009 | 03:00 PM
mysql's Avatar
Doppelgänger
mazda3 guys had lots of issues till aem made this for them. Apparently there's a bend nearby or something. I didn't pay much attention other than the fact that this isn't a screen and it forces the air to line up.
Old Jan 7, 2009 | 03:08 PM
mysql's Avatar
Doppelgänger
I was thinking if the X shapes were made out of metal, they could be cut in a criss cross shape and assembled like this:
Then maybe one or two welds to secure it
Attached Thumbnails Vendor Request: Intake straightener-ex_002.jpg
Old Jan 7, 2009 | 04:27 PM
04RX8man's Avatar
Rotary Powered Countryboy
so something like this wold take care of some of the problems with the MAF sensor on turbo'd cars?
Old Jan 7, 2009 | 04:30 PM
mysql's Avatar
Doppelgänger
No, it's strictly for MAF bling!
Old Jan 7, 2009 | 04:33 PM
04RX8man's Avatar
haha oh cool!!!!!! haha I'm gonna take that as sarcastic but i'm sure may nooooobs will b like oh damn look at that what does that give u anextra 20 HP?
Old Jan 7, 2009 | 04:34 PM
mysql's Avatar
Doppelgänger
OK, this is why the MS3 guys need it.
They have an elbow immediately before the sensor.
Attached Thumbnails Vendor Request: Intake straightener-44474_20_11_08_3_04_28.jpg
Old Jan 7, 2009 | 04:35 PM
mysql's Avatar
Doppelgänger
They sell the straighter separate:
http://www.therpmstore.com/product_i...roducts_id=826
http://www.streetunit.com/AEM_Mass_A..._p/9-21070.htm
too bad they aren't the right size for us.
Old Jan 7, 2009 | 04:39 PM
mysql's Avatar
Doppelgänger
Cobb also sells an intake for the WRX, and MS3 with this built in.
Cobb uses a CFD-designed velocity stack leading to an unique air flow straightener grid. This straightener grid is specifically designed to smooth the incoming air flow as it passes the Mass Air Flow sensor for precise readings. This eliminates the "dead spots" that can be experienced by poorly designed aftermarket intakes due to turbulence.
Attached Thumbnails Vendor Request: Intake straightener-sn1205_guide_18.jpg   Vendor Request: Intake straightener-771500-2.jpg
Old Jan 7, 2009 | 04:40 PM
04RX8man's Avatar
I'm sure something will b rigged up shortly for us! Hell maybe i'll do it haha
Old Jan 7, 2009 | 04:41 PM
mysql's Avatar
Doppelgänger
one more company.
The cp-e™ XCel™ intake on the other hand has several features that ensure an accurate mass air meter reading. We not only machine out mass air housings from aluminum blanks to tolerances of +/- 0.002” (about the width of a human hair), but we also include a stock-style airflow straightener, which our competitors delete, yet greatly improves sensor precision. The resulting fuel trims are nearly stock, and the vehicle drivability is unchanged from stock…save for the extra horsepower of course! Please check out the dyno graphs.
It looks like they might have one before and after the maf.
Attached Thumbnails Vendor Request: Intake straightener-airflow_straight_big.jpg
Old Jan 7, 2009 | 04:45 PM
mysql's Avatar
Doppelgänger
sales page for the previous intake:
http://www.cp-e.com/2101.html
intake design:
http://www.cp-e.com/imgs/MazdaSPEED3_Intake_Design.pdf
Old Jan 7, 2009 | 04:48 PM
mysql's Avatar
Doppelgänger
apparently the oem intake for the 3 comes with air straighteners stock.
Old Jan 7, 2009 | 04:49 PM
bse50's Avatar
#50
We have metal nets on the Aem\mazdaspeed intakes so this would be useless for us, or for any other NA rx8. Maybe for a turbo set-up with a very short or custom intake. Setting up production has costs and these probably wouldn't be large scale sellers, just niche products imho
Old Jan 7, 2009 | 04:52 PM
mysql's Avatar
Doppelgänger
I'm going to assume the intake screens are not as effective as these, otherwise mazda would have used them on the ms3 too. The RX-8 doesn't need them because the intake had enough space for the flow to not be as disrupted. However, there's quite a few people who have had issues with screens, or limited space and this would be something we'd welcome.
BTW, I'm going to be using the AEM intake on my setup, but due to space, the screens wouldn't be usable nor sufficient to make proper airflow.
Old Jan 7, 2009 | 05:00 PM
bse50's Avatar
#50
That's the point mysql, they have limited use. Building them should be easy though, let's wait and see what happens.. given that they are useless for most applications
Old Jan 7, 2009 | 05:01 PM
mysql's Avatar
Doppelgänger
^ talk about a downer.
Worse case, I make one for myself.
Old Jan 7, 2009 | 05:49 PM
r0tor's Avatar
to work, the straightener needs to be engineered specifically for how the intake is setup.... with everyone having a customized intake, its not a one-size-fits-all application
Old Jan 7, 2009 | 05:51 PM
mysql's Avatar
Doppelgänger
the pipe the maf sensor is in is usually the same regardless of application - at least if they're choosing the correctly sized inner diameter. The rear of it might change, but usually it's a 6" pipe or so, and then couplers are used to secure it.
Old Jan 7, 2009 | 06:16 PM
alienRX8's Avatar
Boosted!!!
Im with mysql on this. I have the AEM intake with the greddy setup and I have 0 screens, why? Well because the only way I could make it fit was usin just the maf housing piece and the one with the bends, and the coupler that will join these two is the one with the hump which means it wont hold the screen.
Old Jan 7, 2009 | 07:48 PM
04RX8man's Avatar
yeha i'm sure one cold b made for yourself pretty easily now i just need the turbo and i can make one for MY self haha
Old Jan 9, 2009 | 09:26 AM
I believe you need to weld a screen on that to make it work for an RX 8.
Maybe Daddy Rat Fink can look into that. Differant design so... no patent infingement.
Old Jan 9, 2009 | 02:38 PM
r0tor's Avatar
size is only part of the problem... the larger part is whats upstream and downstream
Old Jan 9, 2009 | 09:20 PM
04RX8man's Avatar
so does the greddy kit come with the screens?
