The smell of Gas
Old Jan 7, 2009 | 06:04 AM
DOMINION's Avatar
I don't buy Kool-Aid
Exclamation The smell of Gas
Hi guys. I have a MT 2004 8 and from time to time I will smell gas. I know its not from my race pipe cuz it smells just like when I spill a little on my had when I fill up, then get in my car and smell gas. This is not fumes from the race pipe. Its way to strong but only last for a short time like a few seconds, then its gone
Anyone have a illistruation of the fuel lines so I can check them? or can point me in the right direction under the hood?
Thanks,
-Gil
Old Jan 7, 2009 | 06:17 AM
Jon316G's Avatar
Grasshopper
Attached is a fuel line illustration.
Under the hood you'll see a fuel line near the master brake cylinder with a red disconnect.
You could start by checking that line for any cracks or feel for any liquid.
Old Jan 7, 2009 | 06:42 AM
DOMINION's Avatar
Thanks man I'm going to snoop around under my hood when I get off work at 7am
Old Jan 7, 2009 | 10:26 AM
Time for me to put another dead fish in your car.
Mu ha ha..............
No really check the filler tube. Generally speaking .... Most cars get holes in the filler neck.
Old Jan 7, 2009 | 10:43 AM
AJ's Shinka's Avatar
Enthusiast
Alright, I guess the jig is up...
I cut the fuel lines just a little bit last time I saw you, just to give me that edge when you try to race me. I wanted to have a nice story to tell the rest of the guys about how I beat Gil.
Old Jan 7, 2009 | 01:03 PM
04RX8man's Avatar
Rotary Powered Countryboy
^haha
Old Oct 17, 2010 | 10:54 PM
CDiver's Avatar
Thumbs up No more gas smell!
Ok so I fixed it!!!!
My 04 rx8 has the "high power" engine and therefore has 4 yellow injectors on the manifold and 2 red injectors on the center cast iron, able to be seen after removal of the air box, throttle body and black plastic manifold tubes, you might as well pull the oil filler assy too!! In my case the rear red injector was leaking. For about 10 bucks I got the upper and lower insulator (rubber seal) and an O-ring for the top at the local dealer. Clean injectors, replace seals, keep dirt out of fuel rails and engine entry points, carefully position injectors and fuel rails on install. Dont forget how everything goes back together!! Tools 10 & 12 mm wrench & sockets. Have fun!
Old Oct 18, 2010 | 06:47 AM
paimon.soror's Avatar
Hope it is nothing serious, although I am sad because I thought this thread was going to be a discussion about how gasoline smells great and how i love pumping gas because of it
theblinkof
Oct 4, 2023 05:24 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
Zube6115
Sep 30, 2015 12:57 PM
XianUnix
Sep 29, 2015 03:48 PM
Jb4ker96
Sep 27, 2015 10:06 PM
