What the CRAP is this?
Old Jan 6, 2009 | 08:04 PM
Never L8's Avatar
Hey crew. I recently changed my oil from Royal Purple fully synthetic (5W20) to conventional Castrol GTX (5W20) and noticed after driving that my dipstick looked like this! I've never experienced anything like this and was wondering if you guys have any insight to WTF this might be. After discovering this, I immediately drained the oil and did my best to flush the system, replacing the oil ultimately with Royal Purple again. I also changed the filter both times with an OEM replacement from Mazda. The car isn't experiencing any changes in performance. The residue lacks any suspicious odors that would suggest some kind of seal leak somewhere...although I don't claim to be an expert of any sorts.
Oh, and I know the whole synthetic vs. conventional arguement, as well as the weight arguement. I never experienced anything like this before I changed it to conventional. Thanks in advance!
Old Jan 6, 2009 | 08:08 PM
staticlag's Avatar
The Professor
white foam. Its a common problem on some 8's
Could be nothing.
Is your antifreeze getting suspiciously low?
Old Jan 6, 2009 | 08:09 PM
staticlag's Avatar
The Professor
http://www.finishlineperformance.com...50-06-1664.pdf
Old Jan 6, 2009 | 08:14 PM
Never L8's Avatar
^Wow...you're good! Thank you so much. You, staticlag, once again prove why this crew is the best out there!
I originally suspected a coolant leak, which is why I mentioned that the residue lacked any suspicious scents that would suggest just that. So, I'm certain this is probably what I'm encountering, being that I'm rocking an '04. Thanks again, bro. I really appreciate the info!
Old Jan 6, 2009 | 08:24 PM
hakuna matata!
recently with my UIM off..
Old Jan 6, 2009 | 08:26 PM
ShellDude's Avatar
weeeeeeeeee
yummy... and to think in a couple months all the milky substance threads will be a distant memory. my wife would be jealous.
Old Jan 6, 2009 | 08:30 PM
I8U's Avatar
I8U
These threads are getting to be common place...getting tired of seeing hundred threads of the same question.
expo1's Avatar
He's as bad as Can
Then the " My fans run 10 minutes after I turn off the car " threads will return.
Old Jan 6, 2009 | 08:32 PM
ShellDude's Avatar
weeeeeeeeee
lol... to then be followed by the "when should I install my winter tires" ones.... I admit it... I am guilty for one of those last year.
Old Jan 6, 2009 | 08:34 PM
I8U's Avatar
I8U
^to then be followed by "what is this foamy stuff all over my dipstick?" Oh wait...we made a complete circle. hehe
Old Jan 6, 2009 | 10:31 PM
mrinno's Avatar
Haha guilty
Old Jan 6, 2009 | 10:34 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
That's all I got! It is a vicious circle!
Old Jan 7, 2009 | 02:44 AM
DOMINION's Avatar
I don't buy Kool-Aid
Exclamation
Could be nothing.
Yea if your antifreeze keeps going low then you need a rebuild and thats likley due to your 8 over heating.
Old Jan 7, 2009 | 02:45 AM
DOMINION's Avatar
10? i thought it was 30
Old Jan 7, 2009 | 10:31 AM
What the hell!
Did you have a coolant leak?
I would say this is not normal.
My Buick looked like this for 4 years before the block cracked completely.
Old Jan 7, 2009 | 11:07 AM
hakuna matata!
Originally Posted by Razz1
What the hell!
Nope my coolant level hasn't budged in months.
Old Jan 7, 2009 | 11:18 AM
bose's Avatar
Reginald P. Billingsly
Is that one of the intake ports the the combustion chamber? That looks gnarly, good thing it's pretty much harmless right.
Old Jan 7, 2009 | 11:45 AM
Nubo's Avatar
Lubricious
Motor Mayonaisse
Old Jan 7, 2009 | 12:02 PM
alienRX8's Avatar
Boosted!!!
^^^^lolz made my day
Old Jan 7, 2009 | 12:59 PM
04RX8man's Avatar
Rotary Powered Countryboy
UR ENGINE IS ABOUT TO BLOW!!!! search before the ?'s start! anyways it's just condensation build up in the oil once the weather up ur way gets warmer(spring) it will go away! Remember this for next year!
Old Jan 7, 2009 | 01:41 PM
zoom44's Avatar
read the stickies thread closed
IamFodi
Series II Interior, Audio, and Electronics
28
Oct 31, 2018 06:37 AM
#1Hoochie
Oct 16, 2015 10:35 PM
jackslao
Sep 8, 2015 01:50 PM
HMSS013
Aug 28, 2015 03:08 PM
Belalnabi
Jul 17, 2015 07:48 PM
