oil pan
Old Jan 6, 2009 | 02:42 PM
Ceez76's Avatar
Ceez76
oil pan
Hey folks, I was changing my oil today and I noticed that there is oil residue around the oil pan ( not so much leaking). Is it true that there is no oil pan gasket on our cars? Is it some type of sealant? If so what kind of sealant? Do I just remove the pan and scrap off the old seal, clean it and replace it with new sealant? Is it a complicated project, from the looks of it , it does seem too painful.
Old Jan 6, 2009 | 02:46 PM
G3tR3DDY2GR3DDY's Avatar
you are right. Its pretty simple.. but because of sealant used, pulling the pan off is a little difficult if you are just using jack stands. Make sure you have a rubber mallet to knock it loose. do NOT pry between the pan and block with a screwdriver :P
Old Jan 6, 2009 | 03:01 PM
Ceez76's Avatar
Ceez76
Thanks, do you know what type of sealant should be used?
Old Jan 6, 2009 | 03:08 PM
black rtv sealant i believe. might be blue. not sure the difference. Gasket maker i think is the blue stuff
Old Jan 6, 2009 | 03:09 PM
staticlag's Avatar
The Professor
http://www.permatex.com/products/Aut...sket_Maker.htm
Should be able to find it at any autoparts store
Old Jan 6, 2009 | 03:21 PM
Ceez76's Avatar
Ceez76
thanks fellas i see they also make a gasket remover solution.
Old Jan 7, 2009 | 07:21 PM
04RX8man's Avatar
Rotary Powered Countryboy
Permatex is nice stuff any local parts store is good autozone advance auto pep boys napa places like that
Old Jan 7, 2009 | 07:24 PM
I8U's Avatar
I8U
It's called a razor blade...haha. Once the pan is off you can scrap off the gasket remnant with a razor, works perfectly.
Old Jan 7, 2009 | 07:27 PM
04RX8man's Avatar
razor blade and some brake cleaner with a rag work good....liek someone said above do not bend oil pan by using screwdriver
Old Jan 7, 2009 | 07:30 PM
heyarnold69's Avatar
Rotary wanabee
I remember there is a spray you can use.
Old Jan 7, 2009 | 07:34 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Gee Patrick......why would you not want to use a screwdriver to pry it?
You say that like you had experience with that?????
Just kidding
Old Jan 7, 2009 | 07:36 PM
04RX8man's Avatar
that's one of those "trust me when i say DO NOT DO IT" comments haha...i think he must know...
Old Jan 12, 2009 | 06:03 PM
eh more or less.. replaced my front cover and now have an oil leak out of that section.. thankfully i have parts cars
WranglerFan
May 31, 2022 07:51 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
WranglerFan
Nov 5, 2017 09:35 AM
Tsurugi
Sep 7, 2015 08:27 PM
