View Full Version : 12V outlet
Cvzrx8 01-05-2009, 10:07 PM I know this isnt serious but the outlet in the center console (the one inside the sliding arm rest) in my 8 isnt working is there any ideas out there how this can be fixed or what it could be?? I would really appreciate it thank you
04RX8man 01-05-2009, 10:10 PM check your fuses first off!!! make sure there isn't a penny in the hole(trust me i've seen it) if all the above is good prob time to take it apart and check the wires are tight!!! My guess is probably a fuse
dannobre 01-05-2009, 10:10 PM Check the fuse.....
laythor 01-05-2009, 10:18 PM if you find a penny make sure not to lick it while it's still in the socket.
9krpmrx8 01-05-2009, 10:20 PM Fuses first. Has anyone added an additional socket to their 8?
Cvzrx8 01-05-2009, 10:22 PM I remember checking all the fuses i went on a fuse hunt a couple days ago
since i bought the car it hasnt worked, so how can i get to the wires?
laythor 01-05-2009, 10:23 PM you can take off the center area starting at the shifter, then taking out the ash tray, then working back... the whole unit can be removed. Use a volt meter and keep tracing forward from the socket till you find power.
Cvzrx8 01-05-2009, 10:27 PM yeah i can do the area of the shifter but working back is where i would have trouble
guess im scared im ripping something off lol, can anyone tell me or show me a diagram how to remove the center going back?
dannobre 01-05-2009, 10:31 PM You can actually remove the socket without removing the console...look around it..there is a little gap at the bottom...pop it forward and the plug comes out
Cvzrx8 01-05-2009, 10:38 PM Is it really that simple :D! if it is i will try it!
alz0rz 01-06-2009, 12:00 PM Is it really that simple :D! if it is i will try it!
yes. the socket molding pops out.
04RX8man 01-06-2009, 12:29 PM yeah the socked just pops out get a DMM and check voltage at the socket and make sure it's there if not power at the socket you need to work your way back to ur power source!
Cvzrx8 01-06-2009, 06:41 PM Thank you soo much everyone! You guys wont believe this lol i was shocked
when i saw that the plug wasnt connected to anything :lol: so i just conected it and it worked i dont know why it was disconnected, i bought the car like that so i guess i'll never know, thank you so much for your help :) Special thanks to dannobre i didnt know there was a tab there lol Everyone was a big help for my small issue
ShellDude 01-06-2009, 06:47 PM someone before you probably popped it off to see what they could see and inadvertantly disconnected it.
Cvzrx8 01-06-2009, 07:10 PM Yeah could be lol someone more curious than me lol
Tim Tim Tim 01-06-2009, 08:48 PM hey i dont have an outlet there.. no fair
Cvzrx8 01-06-2009, 10:51 PM tim tim are you serious?? What year do you have?? N model?? I thought something like that would come in every 8 lol
04RX8man 01-07-2009, 03:54 PM yeah i also thought they all had one
ShellDude 01-07-2009, 04:04 PM If he doesn't have an outlet then what exactly is there?
04RX8man 01-07-2009, 04:24 PM yeah tim what exactly do you have there just nothing? I have never seen an 8 without one!
Cvzrx8 01-08-2009, 07:07 AM This is interesting lol, I wonder if it's just a hole there or like blank, or 4 sum odd reason did mazda mess up on something so little??? Or tim were you just playing?? Idk it seems really wierd that your 8 doesn't have that plug
Tim Tim Tim 01-09-2009, 11:07 AM inside the armrest where the cupholders are???? I have a cig lighter in front of the shifter under that little door thing but thats the only thing I have. I Guess that could be what your refering to and im just retarded haha, wouldnt be the first time. its an 04 grand touring
StealthTL 01-09-2009, 11:13 AM Tim, Tim, Tim - slide cupholder lid open, then LIFT!
Voila! second secret compartment, with 12 volt outlet!
S
04RX8man 01-09-2009, 03:12 PM ^exactly...haha he prob never knew that the thing Opened up when slid back haha i didn't know mine did that for like 2 weeks until i accidentially bumped it and thought i broke it
Tim Tim Tim 01-09-2009, 05:07 PM im going to check on this now. just got back on to read this!!!
Tim Tim Tim 01-09-2009, 05:11 PM no shit, you guys are actually right!!! thanks stealth haha never knew that opened
04RX8man 01-09-2009, 08:14 PM haha^how long have u had ur car tim?? haha don't fret i didn't know for the first few weeks haha...
Tim Tim Tim 01-09-2009, 10:18 PM about a year :lol:
heyarnold69 01-09-2009, 10:39 PM is the clip on... wires ok? voltage getting there?
04RX8man 01-10-2009, 08:34 AM ^^haha wow i guess i prob wouldnt have known yet if i accidentially wouldn't have bumped it and thought i broke it!
ShellDude 01-10-2009, 09:33 AM heh... after you've taken your console out a couple times, hijacked the positive lead to it as an ignition signal, and cut out a few "accessories" around it, it is hard to miss...
http://www.shellware.com/images/rx8/nav/3.jpg
Tim Tim Tim 01-10-2009, 11:29 AM is that a usb plug?
Silver06 01-10-2009, 11:39 AM ShellDude, nice setup!
Are you using a plug-in OBDII extension cable, or did you tap the wires behind the dash plug? (apologies if you've already answered this, I only searched your last 50 posts).
TIA.
ShellDude 01-10-2009, 11:52 AM I have an OBDII cable (scanalyser) that runs from my OBD port through my console to the RS232 port on my carputer.
That is a USB plug that is ran into the rear pass-thru where my carputer lives. If I want to hook up my AP to my OBD, I disconnect scanalyser cable and plug in the AP in place of it using its dongle. If I want to do live monitoring with Street tuner I smply plug my AP dongle into the OBD and run it to the USB port.
There's a 3.5mm stereo port right next to the USB port that I use for standard audio-in to my carpc.
On the other side of the USB port is my "dead man" switch that resets my carpc in the event of a Windows lockup (infrequent but does happen on rare occasion).
ha.. I can only imagine what you learned about me from my last 50 posts lol. I've been meaning to document my carpc build to some extent but haven't found the time.
Silver06 01-10-2009, 12:01 PM ShellDude,
Thanks! Nice setup.
Let's just say that the appropriate authorities have been notified. ;)
Tim Tim Tim 01-10-2009, 01:34 PM sorry, I know im a noob but wtf is that stuff.. RS232 , carputer, AP,dongle,
ShellDude 01-10-2009, 01:40 PM and I was wondering why you didn't have a 12V adapter :) :) :)
j/k ... too hard too resist.
RS232 = computer communications protocol and connector
carputer = car + computer
AP = Cobb AccessPort
dongle = doodad that connects your AP to your car
