Throttle Adjustment
Old Jan 5, 2009 | 11:23 AM
Semiazas's Avatar
The Dark Carnival
Throttle Adjustment
Seeing how the Rx8 gas pedal is all electronic and such unlike my 3000GT thats cable ran. Is there anyway i can adjust my idle to be a little higher without messing with the ECU or anything?
Maybe adjusting the pedal to not come out as far or anything such as a potentiometer i can adjust or anything?
Old Jan 5, 2009 | 11:26 AM
Easy_E1's Avatar
Easiest way is with the Accessport. I know of no other adjustments that can be made. It's all electronic.
Old Jan 5, 2009 | 11:34 AM
DeViLbOi's Avatar
The devil made me do it
What do you see as the possible benefit of this?
Old Jan 5, 2009 | 12:12 PM
Semiazas's Avatar
The Dark Carnival
The Possible Benefits will be that my car wont idle so hard right now.. Feels like its dropping to low or shuddering and its either idling to hard right now or the Borla Exhaust is causing it.
Old Jan 5, 2009 | 12:19 PM
bse50's Avatar
#50
Wouldn't it be stupid to cure the effect and not the cause? Doing some search for rough idles might help a lot for depending on your car's miles etc you can find the exact cause.
Old Jan 5, 2009 | 12:21 PM
cjkim's Avatar
^noob
well, even I wouldnt mind a slightly higher idle, even though my car runs perfectly fine. idle is smooth, but another 100 -150 rpms would be nice
Old Jan 5, 2009 | 12:34 PM
Semiazas's Avatar
The Dark Carnival
Thats what im tryign to achieve a solid idle of 1000.
Old Jan 5, 2009 | 12:37 PM
bse50's Avatar
#50
Yes but a rough idle might mean a tons of things that an electronical adjustment will not cure.
Before doing anything to a car we have to be sure that it is in perfect conditions.
Old Jan 5, 2009 | 12:39 PM
cjkim's Avatar
^noob
well either way, the question has been answered. no throttle cable, so it's got to be done electronically
Old Jan 5, 2009 | 12:42 PM
if your car is idling rough, it is most likely a bad motor mount or it's the A/C cycling on.
What year is your car?
Old Jan 5, 2009 | 12:43 PM
Check out this TSB, might be what you're sensing in your car.
http://www.finishlineperformance.com...21-06-1559.pdf
Old Jan 5, 2009 | 01:07 PM
Semiazas's Avatar
The Dark Carnival
Its a 2004 6 Speed MT and its only while im at a light i get a little car vibrations and sometimes the car like puts once or twice and its fine but i was wondering what it might be. seems like at 1000 it is prefectlyt sound only 60k miles on it
Old Jan 5, 2009 | 01:10 PM
does it do that with the A/C on and off?
Mine's an 05 M/T and I experienced similar symptoms related to a bad motor mount. I got it replaced under warranty, which is why I bring it up
Old Jan 5, 2009 | 01:17 PM
cjkim's Avatar
^noob
last time you changed out plugs/coils? cleaned your maf?
Old Jan 5, 2009 | 01:28 PM
Semiazas's Avatar
The Dark Carnival
ill clean the MAF and everything today actually ill check it all out again i cleaned the intake filter and **** thinking maybe something of enormous mass may have gotten in there but its not and its normally with AC off. More when its on too tho
Old Jan 5, 2009 | 01:35 PM
DeViLbOi's Avatar
The only thing 100 rpms will do you is burn more gas. Fix the problem...not the symptom.
Old Jan 5, 2009 | 01:43 PM
Semiazas's Avatar
The Dark Carnival
. . . i like my car idling at 1000 i prefer that. ill make it idle at 1000 and call it a day.
Old Jan 5, 2009 | 01:52 PM
DeViLbOi's Avatar
It's your car and your money. Good luck on your adventure.
Old Jan 5, 2009 | 07:13 PM
04RX8man's Avatar
Rotary Powered Countryboy
i think that is normal for the 8's if the drop down they will get a little rough mine does it every once and awhiel but the accessport is the only way (that i know of) to change idle speed!
Old Jan 5, 2009 | 08:15 PM
Semiazas's Avatar
The Dark Carnival
Im gonna save up for the AP from MM.
cliffkemp
Dec 24, 2024 10:48 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
D13
Oct 1, 2015 07:55 AM
