How to change thermostat?
Old Jan 5, 2009 | 10:58 AM
silverbullet04's Avatar
Hey guys wondering if you can help.
I have a 04 and it doesnt seem to be blowing hot enough air from the vents. Could this be a thermostat issue or something else? If it is... Where abouts do I find it on these cars?
Any help or thoughts would be helpful
thanks
Old Jan 5, 2009 | 11:33 AM
DeViLbOi's Avatar
The devil made me do it
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-no-heat-repair-heater-control-158200/
DIY Sticky
Old Jan 5, 2009 | 11:35 AM
Easy_E1's Avatar
Could be the temp adjust dial on the dash. They have been known to go bad. As a matter of fact mine went bad the other day.
Try this,, Turn the radio on and then hold the On/Off button down and then hold the top (up arrow) of Scan button down for at least a second. Should display the dial temp setting in the radio station display.
Turn the Temp selector **** and see if it changes the numbers. 0 is coldest and 16 is hottest position.
Old Jan 5, 2009 | 07:55 PM
Thanks alot
It has seemed to help..
Old Jan 5, 2009 | 10:13 PM
04RX8man's Avatar
Rotary Powered Countryboy
Never knew that our carsdid that!!!
fistofmeat
Oct 7, 2016 12:15 PM
05rx8mazda
Nov 28, 2015 09:42 AM
FubarI33t
Sep 28, 2015 08:45 PM
MolsonB
Sep 11, 2015 12:24 PM
