Whats going on here
Old Jan 4, 2009 | 09:20 PM
VS8's Avatar
VS8
4 Cylinder Rotary
Whats going on here
okay i was driving and my car shut off...at first the ignition fuse was blown and i replaced it and all lights came on and the car would turn but not turn on...
i have 04 mt rx8 48k miles
Old Jan 4, 2009 | 09:36 PM
staticlag's Avatar
The Professor
Is it cranking at all?
Is the battery charged?
Are the battery connections loose?
Old Jan 4, 2009 | 09:40 PM
VS8's Avatar
VS8
4 Cylinder Rotary
its cranking
battery is charged i believe and the connections arent loose
Old Jan 4, 2009 | 09:42 PM
Do you have a lot of things wired to the Ign fuse............gauges etc?
May have overloaded it....as for the not starting...check stuff like Staticlag said.... check to see if something came loose and is shorted...doess the new fuse blow again?
Look for another blown fuse or relay
Old Jan 4, 2009 | 09:43 PM
VS8's Avatar
VS8
4 Cylinder Rotary
no it doesnt blow the fuse and the only thing wired is a ignition button because i have had relay problems
Old Jan 4, 2009 | 09:46 PM
staticlag's Avatar
The Professor
Check the fusebox under the hood, if you had a short it may have taken out other fuses in there also.
Old Jan 4, 2009 | 09:47 PM
staticlag's Avatar
The Professor
Have you done anything to it recently? Plug changes? other modifications?
VS8's Avatar
VS8
4 Cylinder Rotary
spark plugs and ignition coils were replaced recently
Old Jan 4, 2009 | 09:50 PM
staticlag's Avatar
The Professor
At this point I'm thinking that a few of the plug wires have fallen off.
Old Jan 4, 2009 | 10:02 PM
Stock ignition?
Old Jan 4, 2009 | 10:03 PM
VS8's Avatar
VS8
4 Cylinder Rotary
Originally Posted by dannobre
Stock ignition?
yes i have stock ignition
Old Jan 4, 2009 | 10:13 PM
Did you check the ignition button that you wired in...that would be my guess....it shorted..blew the fuse...and now the switch has failed and won't work ??
Old Jan 4, 2009 | 10:37 PM
VS8's Avatar
VS8
4 Cylinder Rotary
the switch makes the car turn and it is wired fine
Old Jan 5, 2009 | 07:16 PM
04RX8man's Avatar
Rotary Powered Countryboy
I also say check the plug wires good possibility they came loos i know the ones on my front rotor are never really snapped in good compared to the rear rotor!
Old Jan 6, 2009 | 11:00 PM
VS8's Avatar
VS8
4 Cylinder Rotary
ok turns out it was a fuse after all but this time it is multiple fuses...why do they keep going out is it a short?
Old Jan 6, 2009 | 11:13 PM
Logic states that you start looking where you modified it.......
Old Jan 6, 2009 | 11:15 PM
greg985's Avatar
The 337
what fuses went out?
Old Jan 6, 2009 | 11:18 PM
VS8's Avatar
VS8
4 Cylinder Rotary
...well it happened be4 i modded it but it was once
fuel pump and ignition
starter relay was acting screwy too
Old Jan 7, 2009 | 08:37 PM
04RX8man's Avatar
well blowing a fuse is a short or drawing more amperage through a circuit than allowable ...for example wiring 2 HUGE foglights inthe same circuit as ur headlights...The fuse for your headlight is say 10A that means at 10A the fuse blows your headlights use 8A so thats roughly 2A leeway....ur Fogs take 5A of current draw....8+5=13A 13A>10A=Blown fuse....so if you wired extra things on that circuit then most likely causing more amperage to b drawn.......
EXTRA INFO: that example would b for a series circuit not paralllel which headlights would b wired in but just explains how electrical circuits work somewhat!
Old Jan 10, 2009 | 03:18 PM
I'm with Charles, eliminate the button for a while and see if it happens again.
Old Jan 10, 2009 | 05:33 PM
VS8's Avatar
VS8
4 Cylinder Rotary
i had this problem be4 the button i had to hook wire to old relay switch
