What tire pressure are you running
Old Jan 4, 2009 | 08:11 PM
mryoshi's Avatar
Pyscho Dad
I have tried searching but results are not very good... so maybe we can put this in one place.
I am trying to figure out what pressures are yeilding the best results.
I understand that on a track you dial in your pressure by the percent of pressure increase once the tires are hot, or ideally by measuring the tire temperatures. On the street they never/rarely really get hot though. So what are you finding works best.
I am running 34psi currently 99% normal street use.
Potenza RE960 AS
Old Jan 4, 2009 | 08:47 PM
Aipex8's Avatar
X e p i A
34 also. If I go much higher or lower I get that annoying TPMS light.
Old Jan 4, 2009 | 08:50 PM
paulmasoner's Avatar
Asshole for hire
I tend to run 32.
Old Jan 4, 2009 | 09:09 PM
Totally depends on the tire...
Stock tires...run the suggested tire pressures in the manual...or in Canada and USA..look on the drivers door panel for tire pressures
Usually 32-36 is the norm
Old Jan 4, 2009 | 09:25 PM
yale02's Avatar
Still plays with cars
usually 32 - 34. Falken 452's 18/275
Old Jan 4, 2009 | 09:36 PM
risky business's Avatar
IRC Founder
i run 40psi in my nitto invo's 245/40/18
Old Jan 4, 2009 | 09:58 PM
ZumnRx8's Avatar
RX8 & RX7 owner
I also run 40 psi in my Nitto Neo Gens 235/35/20, and they suggest 50 psi in colder weather.
Old Jan 5, 2009 | 12:13 AM
just for the facts.
tpms. hi is 56 psi. low 26 psi.
Old Jan 5, 2009 | 01:13 AM
MazdaManiac's Avatar
Nitto 555 235/35r19 in front: 38 on the street, 44 on the track.
Nitto 555 275/30r19 out back: 38 on the street, 40 on the track.
Pressures are "hot".
Old Jan 5, 2009 | 06:14 AM
ZumnRx8's Avatar
RX8 & RX7 owner
^^^^25 r 19 and 30 r 19? pics? that must be little tire sidewalll, i wanna see, are the 555--- Z rated in speed? Z rated= 150mph+ (my neo gens are)
Old Jan 5, 2009 | 08:05 AM
longpath's Avatar
Pressure: 38PSI
Winter: Pirelli 240 SnowSports
Remaining 3 seasons: OEM Bridgestones
Old Jan 5, 2009 | 10:01 AM
justjim's Avatar
justjim
34 psi front and rear cold street Nitto 225/45/18. 39 psi front and rear hot track 245/45/17 Hankooks R-compounds.
Old Jan 7, 2009 | 08:11 PM
04RX8man's Avatar
Rotary Powered Countryboy
35psi 225/45/18 in front and abut 36 or 37psi in rears 245/40/18
Old Jan 8, 2009 | 05:54 AM
ryke12's Avatar
I have Nitto 555s, 225/45-18 all around and I keep them at about 33 psi cold, they heat up to around 40 psi.
Old Jan 8, 2009 | 07:13 AM
ATL-GP's Avatar
Speed is all you FN NEED
225/45/18 all around, I run 36psi (cold temp pressure)
Audio Concepts ATL
Sep 26, 2021 01:59 PM
drebbrnator
Dec 27, 2018 07:02 PM
uZu
Dec 30, 2015 12:35 PM
MolecularConcept
Jul 26, 2015 09:09 PM
