worm power low
Old Jan 4, 2009 | 03:40 AM
corrado73's Avatar
worm power low
My English is very bad
I am a 74,000 km RX8 2004
The car has this problem
Motorway reaches the 235 km now, but if I do roads in or mountain 10-20 km climb after the car lost power, more and more to stop.
The noise engine is light detonation before the stop
After five minuts the car start and go.
I have a OBDII scan apex but i don't parameter controller
I have already checked catalyst, and replaced all the ignition with BHR.
No light on
This flaw existed 36.000 Km to 74.000Km never change.
I bought the car at 36.000km and I have always noticed this flaw
thanks
Corrado
Old Jan 4, 2009 | 04:16 AM
StealthTL's Avatar
Metatron
Sounds like a fuel sock plugging problem.
Mine has been repaired twice for this. The plastic housing has little one-way rubber valves to hold gas in for the fuel pump suction. This concentrates any scale etc. around the fuel inlet sock until it plugs off completely.
I repaired it myself last time. The symptoms were exactly like yours - after a run or climb using a steady high amount of gas, the car would slow to a complete stop, with no 'check engine light' or ECU code stored!
I found if I shook the car from side to side, sloshing fuel around the tank, the car would go another 5 kilometers....that told me the sock was plugging with loose material. The fuel pump is under the left rear seat, I took out the assembly and pulled out the pump and its sock, cleaned it and it was good as new.
Good luck, hope this helps.
S
Old Jan 4, 2009 | 12:00 PM
corrado73's Avatar
S
Thanks for your help.
I forgot this case
If i go the rpm to 9000 and over whit neutral the engine it gains power.
Succesful the engine returns slow after 3 - 4 minutes of mountain road
Old Jan 4, 2009 | 12:39 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeah i would also say fuel sock!
Old Jan 4, 2009 | 04:05 PM
AAChaoshand's Avatar
Rotary Powered
mmmmm fuel sock puppets...
Old Jan 4, 2009 | 04:59 PM
04RX8man's Avatar
sock puppets???? lol
Sakebomb Garage
Sakebomb Garage
Oct 10, 2018 03:36 PM
uZu
Dec 30, 2015 12:35 PM
JakeKaminskisRacing
Aug 23, 2015 01:10 AM
harithac
Aug 17, 2015 09:14 AM
