cold weather warm engine starting issue
Old Jan 3, 2009 | 01:35 AM
Shippy's Avatar
Hi all, I have a velocity red 04 with about 55000kms on it and I'm having an weird issue when I start it back up shortly after I turn it off where it seems like the engine is flooded, I've always managed to get it running by going through the flooded engine procedure but I'm trying to find out if this is a warning sign to a more serious issue before I take it to the dealer. So far this has only happened during the winter when it is around -25 C, and the engine is warm, it also happens if I do the cold engine shut down procedure.
Old Jan 3, 2009 | 05:23 PM
halimsteven's Avatar
make sure you "dont turn it off while it's still cold". once you start it, you have to let it warm, and you shut it off. if you shut it off immediately after you turn it on you will flood it
steven
Old Jan 3, 2009 | 05:33 PM
PSTNLSS's Avatar
The Former PSNTLSS
Welcome to the world of Rotary engines Shippy
Old Jan 3, 2009 | 05:35 PM
greg985's Avatar
The 337
wow, read your owners manual
Old Jan 3, 2009 | 05:43 PM
VezRX's Avatar
No more RX :(
I seem to be reading something different than yall. Seems to me like he did let it warm up. Well sir I have been having similar temps here in Ohio and know that some folks in my neck of the woods have the same trouble. Is it parked outdoors? It might just be too cold if that is the case. The rotary is a different engine for sure, but when spring comes your car will be sure to please.
Old Jan 3, 2009 | 07:12 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeah these rotaries seem to not like crazy cold temp when i lived in tthe north i always got her fired up but didn't want to some of the neg temp days!
Old Jan 4, 2009 | 10:25 AM
secret8gent's Avatar
the enemy in the mirror
original starter and battery? try a new battery...
starting compression is lower once the engine is warmed up... right guys? maybe a little premix to offset that...
good luck, and keep them rotors spinning~!
SUKIEE
Oct 9, 2017 09:41 PM
rotorsnsaabs
Aug 26, 2015 08:21 PM
JPCZONE
Jul 21, 2015 12:02 PM
ironj221
Jul 16, 2015 10:16 PM
