View Full Version : RX8 Gears grinding-Clutch?
jdmtunerguy 12-31-2008, 05:25 PM My dad's RX8 has about 65K-70K miles on it and everytime he tries to shift into 4th, 5th, and sometimes reverse it does not go into gear and it grinds. Is this the clutch worn out(he is a good stickshift driver)? or Does the transmission shifting need to be adjusted? Please let me know if it is somethind else or what not.
staticlag 12-31-2008, 05:28 PM My dad's RX8 has about 65K-70K miles on it and everytime he tries to shift into 4th, 5th, and sometimes reverse it does not go into gear and it grinds. Is this the clutch worn out(he is a good stickshift driver)? or Does the transmission shifting need to be adjusted? Please let me know if it is somethind else or what not.
Its likely the syncos are worn out. This will most likely require a transmission rebuild at the very least.
jdmtunerguy 12-31-2008, 05:29 PM well we have the extended warranty from the dealer, and the one issued from mazdausa.....it better be covered.
staticlag 12-31-2008, 05:32 PM Is it a 2004? Some early transmissions 04s and some 05's i think had a poorly designed shift fork which would increase the problem.
Usually the fix is to dismantle the tranny put in the updated shift fork and new syncros
staticlag 12-31-2008, 05:35 PM Here:
http://auto.howstuffworks.com/transmission3.htm
http://auto.howstuffworks.com/transmission.htm
jdmtunerguy 12-31-2008, 05:36 PM yes its a 2004!!! haha..when all the recalls existed haha...i can take it to the dealer and they will fix it under warranty right?
also, iits been grinding for a month maybe and is progressively getting worse..how badly do you think the transmission may have been affected by this?
jdmtunerguy 12-31-2008, 05:42 PM oh wow, thats interesting links. Thanks, i hope there is not too much damage and i hope the mazda dealer is honest if they have to replace the transmission. Galpin Mazda in Van Nuys is horrible for all who live near there. I have had a bad experience with my wheels and tires with the. Horrible.
staticlag 12-31-2008, 05:43 PM yes its a 2004!!! haha..when all the recalls existed haha...i can take it to the dealer and they will fix it under warranty right?
Yeah it does that.
The only way I would think it was the clutch was if the clutch disengaugement point was significantly different that the factory spec. try to wiggle the clutch pedal up and down with your hand. It should only have maybe 2-3mm of play, if there is any more then it may be your clutch is mis-adjusted. I'm skeptical of this and pretty positive its the syncros though.
Well the gears dont actually grind, its the syncros that are grinding. Worst case scenario the syncros would shatter and lodge in the gears destroying the whole transmission, as it stands right now I think only syncros 4 & 5 and the reverse collar are affected.
jdmtunerguy 12-31-2008, 05:50 PM will this be covered under warranty?
staticlag 12-31-2008, 05:56 PM will this be covered under warranty?
Yeah it will most likely be under the 04's extended powertrain warranty.
It will most likely go like this:
1. They will probably ask you for their diagnostic fee of around $100 just for them to personally find out what the problem is :lol:
2. They will find out its the syncros
3. They will call mazda regional headquarters and ask them if they will honor your warranty.
4. mazda regional will ask you or the dealership for poof that you performed at least 1 manual transmission fluid change on the car.
5. They fix your car (takes about a week maybe two if they cant get the parts right away)
dozer 12-31-2008, 05:56 PM it should be...if it just the clutch, then no...thats wear and tear
staticlag 12-31-2008, 05:57 PM Yeah it will most likely be under the 04's extended powertrain warranty.
Oh and:
6. They will try to sell you a clutch and probably some other replacement stuff.
jdmtunerguy 12-31-2008, 06:14 PM Alright. Well I hope the dealer will fix it. They better give us a rental car too haha.
jdmtunerguy 12-31-2008, 06:15 PM Alright. Well I hope the dealer will fix it. They better give us a rental car too haha.
Also how often does the clutch wear out? We drive it hard every now and then but not every day or something like that.
staticlag 12-31-2008, 06:28 PM Alright. Well I hope the dealer will fix it. They better give us a rental car too haha.
It really depends, on the clutch, on how good of a driver the person is, on if they drive city or highway a lot, if they race it. I've seen anywhere from 12K to 120K miles.
Honestly if they offer you to replace the clutch for like $400 I would do it, the labor should be covered under the warranty transmission replacement, usually clutch replacement is $1000 to $1300 with labor.
jdmtunerguy 12-31-2008, 06:46 PM would a worn out clutch make the grinding noise only for 4th and 5th gear all the time. And to restate about the reverse, its not the fact that it grind going into gear, it slips into the spot but misses the gear so when you accelerate you dont move and it makes a wseird noise., sorry for the misunderstanding. also the grinding has substantially gotten worse over the last 2 weeks. A clutch cant wear out that fast can it? by the way, we mainly do city driving to downtown la
marsredr100 12-31-2008, 06:58 PM My dad's RX8 has about 65K-70K miles on it and everytime he tries to shift into 4th, 5th, and sometimes reverse it does not go into gear and it grinds. Is this the clutch worn out(he is a good stickshift driver)? or Does the transmission shifting need to be adjusted? Please let me know if it is somethind else or what not.
It sounds to me more like a worn out clutch/pressure plate based on the mileage and city driving. Have the clutch/pressure plate/release bearing/pilot bearing replace and flywheel resurface. :eyetwitch
jdmtunerguy 12-31-2008, 07:41 PM but with a worn clutch why would the gears grind when trying to shift ONLY into 4th and 5th. As my dad says the transmission in 4th and 5th is "grind em and find em".
jdmtunerguy 01-01-2009, 04:42 PM Bump
04RX8man 01-01-2009, 05:25 PM I don't think driving with the "grind em and find em" attitude is the best to do
jdmtunerguy 01-02-2009, 01:45 PM um its not an attitude. Its the fact that, that is the only way you can drive the car unless you skip to 6th gear.
climacus 01-02-2009, 01:59 PM It's probably the clutch pedal bracket tearing itself apart (do a search in this forum). It's kind of hard to destroy the 4th, 5th and reverse synchro all at the same time unless you just drove the 24-hr of Lemans.
