Air pump relay access
Old Dec 29, 2008 | 04:42 PM
Has anyone had to access the air pump relay...can you get at it without removing the ECU case??
Old Dec 29, 2008 | 06:01 PM
No body
Old Dec 29, 2008 | 06:08 PM
MazdaManiac's Avatar
Originally Posted by dannobre
No body
Hold on. I'll go look at it.
Old Dec 29, 2008 | 06:14 PM
I don't see any practical way to get at it with the PCM in place.
Its under the power steering filter.
Old Dec 29, 2008 | 06:15 PM
Great...I would look at mine but it's in a foot of slush right now
Old Dec 29, 2008 | 06:22 PM
When you lift the PS electrical filter out, the air pump relay will be clipped to the same plastic "rail".
Old Dec 29, 2008 | 06:35 PM
So it's under the ECU in the case??
That sucks if it is The guy I'm trying to help has a UK car with the stupid break off bolts holding it in....
Old Dec 29, 2008 | 06:40 PM
Yes.
You remove the PCM and it is in the front/bottom of the case.
Why would anyone need access to that, anyway?
Old Dec 29, 2008 | 06:49 PM
Air pump not working...and it works when the pump is jumped...so it is either the ECU signal to the relay...or the relay. Hoping it is the relay
Old Dec 29, 2008 | 06:54 PM
Well, you can test the relay through the harness.
Old Dec 29, 2008 | 07:05 PM
04RX8man's Avatar
Rotary Powered Countryboy
Yeah just test the relay through the harness! Alot easier than tearing **** apart!
Old Dec 29, 2008 | 07:32 PM
That's OK for me...not sure how it will work out in this case...we will give it a try.
RevMeHarder
Jun 1, 2026 02:30 PM
JimmyBlack
273
Feb 10, 2020 10:23 PM
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
Shumster
Sep 10, 2015 11:05 PM
