ethanol and premix
Old Dec 27, 2008 | 08:43 AM
olddragger's Avatar
ethanol and premix
as the title says--this opens up a whole new discussion. what is everyones thoughts. I will say this---you better be thinking about this!
OD
Old Dec 27, 2008 | 09:50 AM
tdiddy's Avatar
Finally Boosted!!!!!!!
I am in the process of doing this conversion.
So far, here is a list of parts I can think of that you would need.
1. Fuel Rails.
2. Fuel Pump.
a. Seals and hoses?
b. Dual pump setup?
3. Fuel Pressure Regulator.
4. Fuel Lines and fittings.
a. Size. AN-6, -8, -10?
b. Feed line vs return line.
5. Fuel Filter.
a. In-tank.
b. In-line.
6. Injectors.
a. Primary.
b. Secondary.
c. P2.
7. Engine Management.
My plan is to run E85 (which is quite available in IL) with increased premix volumes. My proposed setup is as follows.
1. Fuel Rails. - Keiths rails annodized for corrosion defense.
2. Fuel Pump. - Mazsport primary pump (walbro 255lph)
a. Seals and hoses? - whatever comes with the kit for now.
b. Dual pump setup? - looking into using the OEM pump in place of the Venturi(sp?)
3. Fuel Pressure Regulator. - Aeromotive A1000.
a. Size. AN-6, -8, -10? - AN-10 feed line. AN-6 return line.
5. Fuel Filter.
a. In-tank. - Removed?
b. In-line. - AN-10(100 micron) located between the pump and regulator.
6. Injectors.
a. Primary. - 720cc Low Impedance
b. Secondary. - 720cc Low Impedance
c. P2. - 1000cc Low Impedance
7. Engine Management. - Interceptor-X and Cobb AccessPORT.
Old Dec 27, 2008 | 05:57 PM
olddragger's Avatar
Damn--you have thought a lot about this. I have to ask why?
Converting to a return system will be a pain, but you plan is good although the stock pump will be more than adequate for your flow.
You will have to replace all the fuel lines as ethanol doesnt like some stuff?
You may also want a water separattion capable filter as with e85 and premix you are going to have water.
good luck with this.
But why?
OD
Old Dec 27, 2008 | 06:03 PM
Alcohol and Aluminum parts are a no-no...Methanol is really corrosive....I think ethanol is a bit better. Otherwise the E85 will just need more fuel for the same load.
-8 should be lots for feed...and you could use the stock lines for a return.
You will have to use a alcohol safe fuel pump...and if you are not tracking the car you should be OK with the stock venturi returning fuel...just plumb the return from the FPR to the venturi...and plug the stock FPR inlet....
I would remove the stock filter..and use a canister style pump in the engine compartment..easy access to change the cartridge
Old Dec 28, 2008 | 10:51 PM
MAZDADIKE's Avatar
ive been on this idea for a while now for the 8. i am working on it for my talon right now just waiting for sring to come..
need a WB02 sensor i would think also. and remeber your A/F ratio on ethonal is different than gasolina
OnebaddRx8
Aug 25, 2019 11:34 PM
Digitz0070
55
Jul 25, 2017 08:40 PM
R3Dream
48
Mar 12, 2016 01:44 PM
tommy26Germany
Sep 29, 2015 10:33 AM
