just my luck, help plz
Old Dec 26, 2008 | 05:54 PM
skhmund's Avatar
THE BITCH IS DEAD
my 8 isnt starting, i havent driven her in about 3 days. so I walk to her, hit my unlock button and nothin happens, try it again, car wont even blink the lights. So then i use the key to unlock her, get in, put the key in ignition, press clutch and she wont start, nothing happens, no noise nothing!.......my guess is somethin with the security system, since it wont unlock, it wont let me start then, or no??
Old Dec 26, 2008 | 06:27 PM
tubingchamp's Avatar
What mawd bug?
Battery?
Old Dec 26, 2008 | 06:29 PM
dshiznit1489's Avatar
Formerly Polak Graphics
I'm gonna say battery issue as well.
Old Dec 26, 2008 | 06:35 PM
What mawd bug?
Might wanna get your battery checked, for sure. Have you screwed around with the negative pole on it?
Old Dec 26, 2008 | 06:43 PM
CyberPitz's Avatar
Huge hole is huge
open hood and unplug the bat and hook it all back up, see if that works. If not, your bat might be bad, and you'll have to take it in to Autozone or something to test it.
I know one time that happened to me. I just unplugged the battery and hooked her back up and she was good to go!!!
Old Dec 26, 2008 | 07:32 PM
Renesis07's Avatar
Vtak just kicked in yo!!
def a battery, happens to me all the time. Cables may be loose.
Old Dec 27, 2008 | 01:38 PM
skhmund's Avatar
THE BITCH IS DEAD
thank you guys, god knows what I would do w/o this forum
yeah u guys were right, jump started her n she ran fine........im curious tho, im on 65k miles, daily drive of 80 miles, do u think a new a battery at 65k is legit/expected? and do you have any suggestions for any particular battery brand?
Old Dec 27, 2008 | 01:40 PM
Renesis07's Avatar
Ive been through 3 batteries in the past 2 years/ 50000 miles.
So it wouldnt surprise me if you need a new battery
Old Dec 27, 2008 | 02:13 PM
skhmund's Avatar
THE BITCH IS DEAD
ok thanx man........so on the instrument cluster, the DSC light is blinking. I think I need to do the steering wheel calibration to get rid of that. And also the engine light is blinking, I'm assumin its cuz of the battery? I have yet to go n get a new one, gonna go later on today
Old Dec 27, 2008 | 02:39 PM
Renesis07's Avatar
check engine light isnt caused by the battery.
Mine would blink for a second then go off once it started; if it continues to blink as you drive, that means your car is misfiring.
Old Dec 27, 2008 | 03:30 PM
Never L8's Avatar
Glad you figured out it was the battery. That was classic battery symptoms. Get a new one. You're due. Be happy it was an easy fix!
Old Dec 27, 2008 | 03:32 PM
skhmund's Avatar
THE BITCH IS DEAD
misfiring? so in layman's terms, am i SCREWED?
Old Dec 27, 2008 | 03:36 PM
Hardly...make sure you have a good charge in the battery...and drive it. It's unlikely that your battery died and your ignition just happened to pick that instant to totally screw up..........If it continues after you have driven it for a day or so...reset the ECU..and you will likely be OK. If the battery was weak your plugs might be crapped up a bit...and that should go away with a bit of a run
Old Dec 27, 2008 | 04:31 PM
CyberPitz's Avatar
Huge hole is huge
Ding ding ding ding.
The only time you'll be screwed at this time is if you're car explodes....
or catches on fire D:
Old Dec 28, 2008 | 09:27 AM
04RX8man's Avatar
Rotary Powered Countryboy
battery
Old Dec 29, 2008 | 06:40 PM
skhmund's Avatar
THE BITCH IS DEAD
put a new battery in her today, she runs fine. THANK YOU all for ur help
Old Dec 29, 2008 | 07:26 PM
Renesis07's Avatar
No problem, just send 50 bucks to my paypal we're good
Old Dec 29, 2008 | 07:31 PM
CyberPitz's Avatar
Huge hole is huge
I'll take $10, just for posting in the thread.
Old Dec 29, 2008 | 07:32 PM
Renesis07's Avatar
Ill take $9.85
Screw you cyberpitz!
Old Dec 29, 2008 | 08:46 PM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
Thanks. Next time replace your battery earlier. That'll be 9.99 please.
Old Dec 29, 2008 | 08:53 PM
Renesis07's Avatar
ha, I still have you guys beat.
Old Dec 30, 2008 | 12:28 PM
dozer's Avatar
on his 3rd rx8
ill take 5 cus im late
Old Dec 30, 2008 | 03:59 PM
CyberPitz's Avatar
Huge hole is huge
4.95, cause my avatar is sexy.
Old Dec 30, 2008 | 04:01 PM
Renesis07's Avatar
1.07 becuase Im hungry and want a mcdouble.
Old Dec 30, 2008 | 04:04 PM
db_8's Avatar
DSC light blinks everytime you disconnect the battery. just turn the wheels all the way to the left and right after starting the car and that should get rid of it. no need for steering wheel calibration. CEL light... not sure.
