View Full Version : WTB greddy oil drain plug
czar
12-26-2008, 02:16 AM
wanted to buy the plug for the oil drain line from turbo, annoying little peice i am trying to find instead of buying a oil pan with a adapter included.
refering to fitting that plugs into the oil plug for the oil drain from the turbo to clamp on to
mysql
12-26-2008, 06:11 AM
it's the same exact drain plug that you used on the OEM oil pan. Buy an oem one or anything aftermarket.
nuke0907
12-26-2008, 08:14 AM
are you talking about a fitting to screw in to attach the hose?
czar
12-27-2008, 01:42 AM
yea the one you clamp the hose on to, sorry ^_^
nuke0907
12-27-2008, 10:40 AM
they have one on ATP (http://www.atpturbo.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=tp&Product_Code=ATP-OIL-023&Category_Code=BCS), but i'm not sure if its the right size. you might also want to check an autoparts store for something. try looking for heater hose connectors. here's a pic of mine that came with my Greddy kit. if you notice, the threaded part is somewhat narrower than the nipple part.
http://img145.imageshack.us/img145/5561/dsc0481kv4.jpg
By nuke0907 (http://profile.imageshack.us/user/nuke0907), shot with NIKON D40X (http://profile.imageshack.us/camerabuy.php?model=NIKON+D40X&make=NIKON+CORPORATION) at 2008-12-27
NgoRX8
12-27-2008, 12:37 PM
it's tough to find. i ended up ordering a set of fittings from ray to hook up and combine.
the oil drain is a M14x1.5 and in this case to a 5/8" barb
czar
12-27-2008, 03:34 PM
awsome, exactly the info i needed,
i can use the barb above with the
http://www.atpturbo.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=ATP-FTG-031&Category_Code=ATP-OIL2
weld in bung for the oil pan, i may have to go this way if i cant find it.
lol all these little things ~_~ for a turbo
