View Full Version : Rx8 torque
HUSSAIN
12-24-2008, 03:54 AM
According to spec sheet rx8 has a torque of 165, hp of 235 and 0-60 time of 6.1 second while a honda accord 2000 cc has hp of 160, torque of 156 and does 0-60 in 10 second.
So i am sort of consfused; because how can i car with meagre 165 torque do 0-60 in 6.1 seconds while the other car with the same torque does it in 10 seconds.
Any explanation without flaming me would be nice.
Flashwing
12-24-2008, 04:07 AM
Simply put, Torque and Horsepower do not determine the overall performance of a vehicle. A honda accord is a family sedan designed to move people from point A to B.
Just because one car has more or less torque does not mean it's faster. You have to factor in things such as drivetrain, vehicle weight etc.
HUSSAIN
12-24-2008, 04:22 AM
The weight does not add a difference of 4 seconds.
The gear ratio's actually do make a difference because in all probability accord owner has to change to third gear to reach 60 mph and that might account for the difference.
But this means that if we install both car with similiar gear ratios both would be very compatative in a drag race.
Furthermore what more doesn't make sense is that for what little physics i know:
Torque = Force X Displacement = Work
Power= Work Done per Second
So the Torque and power should always be propotional but here :
Accord = 160hp and 160lb-ft
Rx8 = 230hp and 160lb-ft
ryke12
12-24-2008, 04:38 AM
Torque and horsepower measurements advertised by manufacturers are the peak measurements, taken from a dyno (not at the wheels, mind you, but the... flywheel I think?).
Also, horsepower is determined by torque * RPM / 5252. This is why horsepower = torque at 5252 RPMs. You cannot simply assume a direct ratio because they tend to be measured at very different RPMs (if you look at specifications for vehicles they tend to say something like "250 peak hp at 5.5k RPM" or something similar.)
As Flashwing said, several things determine acceleration. Weight is very important (the Accord is somewhere in the neighborhood of 3600 lbs while our RX-8 is roughly 3000 lbs. Those 600 lbs make a big difference.) The torque/horsepower curve is also important (an engine making 50-100 hp from 0-5k RPM but with a peak of something like 300 hp at 7k RPM is going to be much slower starting out than an engine with a smoother power curve.) You also have to consider drivetrain losses. The Accord could have a much more inefficient transmission that loses far more power than the RX-8 (parasitic loss).
nvrfalter
12-24-2008, 04:48 AM
rx-8 torque is teh sex....
....around 6k rpm heheheh
Flashwing
12-24-2008, 05:00 AM
The 5.9 to 6.1 second 0-60 time I think is a bit of a quicker time than what the typical RX8 is capable of. You'd have to be power shifting that transmission.
Either way, examining torque numbers alone isn't going to tell you the total performance of a vehicle.
9291150
12-24-2008, 06:58 AM
THIS is why I stopped coming onto forums...
-"You'd have to be power shifting that transmission" to get a 5.9 0-60.
-the 4 cyl. Accord "is somewhere in the neighborhood of 3600 lbs"
Hussain; you're better off searching on the web, the subject is well covered, and you'll find out it isn't just about torque, kinda like it isn't just about trap speeds - two areas where forums often get it wrong...
Shinka_MJR
12-24-2008, 08:10 AM
better question:
Why does it matter? Like the car? drive the car. Don't like the car? sell the car.
plain. simple. period.
RX8-Frontier
12-24-2008, 08:47 AM
It's a relatively easy explanation, and was basically touched on but not directly stated.
It's the GEARS!! Engine numbers are nice things that marketers can key on, but the GEARS are what makes it get up and go, almost regardless of how much the engine puts out...
Gears are torque multipliers. This is why when you hook up to a dyno, you want to measure it based on the gear that is a 1:1 ratio in the transmission, otherwise, you've got to introduce a calculation to get the torque back to what the engine is really putting out.
Examples:
If your engine puts out 200 lb-ft of torque, and your transmission is a 2:1 ratio, you're actually putting 400 lb-ft of torque to the rear axle. Say you have 3.0:1 gears in the rear axle, and now you're actually putting down 1,200 lb-ft of torque to the ground through the wheels. (not including all the losses that occur due to friction).
But change that transmission ratio a "small" amount to 2.2:1, and now you're actually applying 1,320 lb-ft to the ground, an increase of 10%!!
Better yet, leave the tranmission alone, and change the rear axle ratio from a 3:1 to a 3.7:1, and you've increased torque the ground a whopping 280 lb-ft, to 1,480 lb-ft, an increase of 23%!
In other words, torque ratings at the engine really don't have a whole lot of meaning as far as the acceleration goes, because the GEARS in the transmission and the rear axle are much, much more directly responsible for torque that makes it to the ground, and resultantly, are much more directly responsible for the acceleration of the vehicle.
EDIT:
If you're having a hard time wrapping your head around this concept, picture yourself with a wrench in hand. Say you are strong enough to put out 50 lb of force, straight up (this is your "engine"). Your wrench is 1 ft long (this is your "gear") so you can exert a "whopping" 50 lb-ft of force on that bolt to turn it (this is your total torque to the ground including engine force, transmission & axle ratios).
But say that bolt is stuck as a mutha'...needs 400 lb-ft to move it (this is your car's weight) You can either go work out for a few months so you can increase the force comin' out your arm to 400 lbs (turbo, baby!), and get the job done. OR, you can go get a wrench that's 8' long (change the gear ratios) and you get the same 400 lb-ft of torque to the bolt (your wheels on the ground).
There's lots of different ways to get an increase of torque; different car manufacturers do it different ways. Just measuring 1 of the values (engine torque and related horsepower) don't give you an overall picture of how much torque actually gets exerted to the ground by the tires. You gotta' look at it all as a whole. The torque/horsepower rating is virtually meaningless by itself.
chancejat
12-24-2008, 08:55 AM
the rx8 is faster because of the rotary's ability to hold its torque for a longer period of time(9k rpms) which equals more power ....so while in gear it can continue to accelerate to 9k rpms while the honda accord is limited o 6.5k rpms....if the honda accord engine were able to hold torque longer then it too would accelerate faster...... like the honda s2000 which aslo has ~160 ft lbs of torque but a higher rev limit and does 0-60 in 5.5 sec
Socket7
12-24-2008, 08:58 AM
Everyone knows that, Torque is a measure of rotational energy, and we all know piston engines only go up and down. So really, only rotary engines make torque at all, as piston engines make up and down motions.
People who talk about piston engines having torque are just ignorant.
/why so serious?
tubingchamp
12-24-2008, 09:06 AM
It's because all RX8s are made in Japan, where the mad JDM ki is imbued into each rotary engine.
Joose
12-24-2008, 09:29 AM
So if you stopped coming to the forums, how in the world are you posting this?
:Eyecrazy: :Eyecrazy:
fastlaneracing
12-24-2008, 09:40 AM
Because its Horsepower that accelerates the car.
DarkLord7854
12-24-2008, 10:09 AM
the rx8 is faster because of the rotary's ability to hold its torque for a longer period of time(9k rpms) which equals more power ....so while in gear it can continue to accelerate to 9k rpms while the honda is limited o 6.5k rpms....if the honda engine were able to hold torque longer then it too would accelerate faster...... like the honda s2000 which aslo has ~160 ft lbs of torque but a higher rev limit and does 0-60 in 5.5 sec
I don't know what S2000 you're looking at, but the ones I've seen redline at 8,500-9,000RPMs..
http://en.wikipedia.org/wiki/Honda_S2000#Specifications
RIWWP
12-24-2008, 10:11 AM
If you are serious about wanting to know why, then I seriously suggest that you read this thread: http://www.rx8club.com/showthread.php?t=152449
The subject is regarding making more power in the 8, but in the process there are many good explanations about what power actually means.
Simply put however, it isn't the peak HP/TQ numbers that you quote, but how long each of those cars can hold near those numbers, as well as the gearing involved. The RX-8's torque curve is very flat, which means that it is producing close to the same amount of torque the entire time spent across the rev range. The Accord's torque curve is likely very bubbled, so it is only getting it's published peak torque for a portion of the time. So we can hold our torque for most of every gear, and our RPMs are higher which means we can hold our gears longer, where-as the Accord can only hold it's torque briefly, the rest of the time it is pushing significantly less torque. It is the "Area under the curve" way of looking at it.
For a simple layman's experiment to feel the difference, pay attention to how long you feel the pull in the 8 under full acceleration, and then take a ride/drive in an accord or other car of similar numbers, and pay attention to how long you feel the pull in those cars.
Though you have the wrong car if you are paying attention to acceleration times. That isn't what this car was designed for, and although it does it respectably, it will never do it well enough to really draw attention. Unless maybe Mazda designs a 5 liter rotory engine...what's that? 8 rotors? :uhh: :lol:
tubingchamp
12-24-2008, 10:14 AM
The AP1 (older models) had their redline set to 9000, whereas the others I believe are 8250-8500..
That is what Chance was saying, because of the higher redline, they have a faster 0-60 than the accord which has nearly the same amount of torque. He wasn't implying that the S2K redlined at 6500.
Marklar
12-24-2008, 10:39 AM
What people tend to forget is that the torque numbers are *peak* torque.
Most piston engines have a narrow power band with a torque curve that spikes up at one point. Rotary engines have a much flatter torque curve: it's fairly linear and increases all the way to the redline.
A piston engine will snap your head back, briefly. A rotary engine will push you back a little, and then keep on pushing you back all the way to the redline. They accelerate in different ways, which is why the 8 can be quick with a peak torque number that would be horrible for a piston engine.
Tim Tim Tim
12-24-2008, 11:00 AM
the rx8 pushes you back??? lol jk
Also factor in the fact that its a rear wheel drive vehicle with limited slip vs. a front wheel drive with an open differential. There is a second right there
delhi
12-24-2008, 12:01 PM
Answer is simple. Any honda product's hp must be divided by 2.
c41250n
12-24-2008, 12:06 PM
because itz a HONDA
lolz
chancejat
12-24-2008, 12:09 PM
yep...thx
exsequor
12-24-2008, 04:41 PM
why are we even comparing these cars?
why can a 96 integra type r redline at 8k? how can it run the same times as an 8 with a 1.8l and 130 tq at 7500 rpm??
same type of question right?..
kersh4w
12-24-2008, 05:31 PM
here is a 2000 honda accord ex coupe. im actually pretty impressed, kudos to honda for the pretty flat torque curve. (also for not lying about hp numbers, unlike mazda. we all know the rx8 has 215hp, not 232hp.)
http://www.dragtimes.com/images_dyno/6214-2000-Honda-Accord-Dyno.jpg
from: http://www.dragtimes.com/Honda-Accord-Timeslip-6214.html
and actually, the 2000 accord coupe only weighs 2900lbs. so it gets a bonus here.
gearing is also very important. i bet you (for the ease of driveability) that the transmission of this honda goes out to about 20mph in standard driving for first gear. what do we get? 12-14mph for standard driving. that means we'll accelerate faster, but we'll run out of first gear faster too.
honda makes people movers.
gearing makes a lot of difference in acceleration. if you put the rx7 transmission (which has slightly longer gears) into the rx8, your 1/4 mile time will drop .3 seconds. why? because you dont have to shift into 4th right before the finishline. but in the 1000', the rx8 transmission will beat the rx7 transmission.
but we're talking 0-60. and i know we can hit 60mph in 2nd gear. if the accord can hit 60mph in 2nd gear, it wont lose anything with a gear change. but it will suffer from the longer gears. so it will have longer acceleration times.
acceleration really comes down to gearing and vehicle weight.
edit: also read this
http://www.yawpower.com/tqvshp.html
ShinkaTeen
12-24-2008, 06:33 PM
better question:
i like this guy's style.
greg985
12-24-2008, 07:45 PM
torque=the power and engine has
HP=How well the engine can put the torque to work
if 2 cars with the same amout of torque but one has more HP the one with more HP will "win"
mysql
12-24-2008, 07:51 PM
torque is twisting power. or acceleration.
horsepower is how much power is put down over a length of time, or distance.
they are directly tied together, and if you pay attention to them (and I don't mean peak numbers) you can get an idea of a car's acceleration and how fast it is. If you look at only peak numbers, you can easily be deceived. Having a lot of one without the other isn't cool. e.g; 600 lbs/tq and 120 hp = teh suq.
I think the analogy is something like:
Torque is how hard you can smash a car into a wall
Horse power is how fast you're going when you hit the wall.
or something like that :)
kersh4w
12-24-2008, 08:54 PM
Horsepower is how fast you hit the wall. Torque is how far you push the wall.
but yeah. haha. funny quote.
(although that still doesnt seem right, i dunno..)
Marklar
12-24-2008, 10:08 PM
Horsepower is the arm, torque is the lever. If you want to remove a stuck bolt, is it better to have a strong arm, or a long wrench? It's best to have both, too little of either is limiting.
Piston engines generally have more leverage than rotaries, because of how they convert reciprocating motion into rotational motion. But rotaries produce much more power for their size than piston engines.
kersh4w
12-25-2008, 03:11 AM
torque is a direct result of the length of the combustion chamber. i.e. displacement.
more displacement = more torque.
9291150
12-27-2008, 11:13 AM
tubingchamp
Wikipedia strike again! Wrong, the early 2.0L redlined at 8900, the 2.2L redlines at 8000rpm.
9291150
12-27-2008, 11:14 AM
such wit...
tsxmidship
12-27-2008, 11:29 AM
torque is this...horsepower is that....this thread is elite
chancejat
12-27-2008, 11:38 AM
your not allowed to post anymore....:squint:
Renesis07
12-27-2008, 01:49 PM
Power to wieght ratio combined with a manual trans and different gear ratios and RWD = 4 seconds off of a 0-60 time.
04RX8man
12-28-2008, 10:06 AM
You stopped coming to forums yet he has over 1200 posts huh Yeah i stopped too!
jndiii
12-31-2008, 01:19 AM
Nope, it doesn't. It's reasonably close, but the physics is a bit off.
Velocity is how fast you hit the wall. Torque is how HARD you push the wall, assuming the car isn't totaled.
Horsepower is energy output per unit of time. It is roughly proportional to force times velocity (work = force * distance, power = work/time = force * distance / time = force * velocity ... these simple expressions quickly break down if the force isn't constant).
Horsepower is a primary factor determining the car's maximum cruising speed, so, yes, it's how fast you hit the wall. (The force is constant at that point, so the simple math works mostly right.)
The torque part of the expression is definitely off, though, because if you stop pushing the wall after a certain distance, the torque at that point is zero. Torque is as most others have posted: it's force times a lever arm. That's useful because then you can just take the torque value, change your gearing/levers, and have whatever amount of force (pushing) you want for the occasion: high force in low gear, low force in high gear.
Another way to look at it is that tractors don't care about horsepower so much as torque: they don't need to go fast, they just need to be able to go at all, pulling a heavy load. An interesting side note in this regard is that John Deere looked into using rotary engines a long while back (http://cp_www.tripod.com/rotary/pg11.htm): seems they didn't have enough torque.
MazdaManiac
12-31-2008, 01:33 AM
The expression is:
Torque is how hard you hit the wall.
Horsepower is how far you push it.
staticlag
12-31-2008, 01:35 AM
If you can put that power to the ground, I had 245 azenis rt615s on my 307 hp rx8 with the feed 4.77 gears. Both first and second gear had no traction if I gave it more than 50% throttle.
Capt. Silvia
09-18-2009, 12:12 AM
This car may accelerate better with traction control turned all the way off, as in the idiot light illuminating that shows the car skiding after holding the button for a few seconds. I wonder if this car is just held back all the time? I would assume most don't know about that "secret" ability.
Brettus
09-18-2009, 12:31 AM
The most important factors here are
weight & area under the HP/torque curve in the rpm range you will operate .
If you are changing gear at 9000 and it drops down to say 5500 when you change into 2nd ,
you need to find the area under the curve in the 5500 to 9000rpm range then compare that against the other car .
reaper1
09-18-2009, 05:57 AM
Why are we going thru this again ............. this is old ............
renesisgenesis
09-18-2009, 11:17 AM
imagine you have a motor sitting on a mount, and it's running, flywheel exposed.
Then take some clamps, or brake calipers or whatever, and squeeze the flywheel. The force required to slow it down shows you the actual rotational force, independent of rpm,(Although different at every rpm) being offered by the motor.
Now, take what you get from that and factor in the speed (RPM) of the flywheel. The faster it's spinning, the better. That is your horsepower. Torque X RPM.
You can imagine, that for a given amount of rotational force being offered, the faster it is spinning, the better. This allows for engines with identical torque to perform very differently, since you can gear a car twice as low and reach the same speeds in each gear if you have twice the RPM available.
So here you can see how torque and horsepower numbers work.
RufusVonStorm
09-18-2009, 11:53 AM
Frontier + Chance = Good answer guys!
YaXMaNGTO
09-18-2009, 11:59 AM
^^^ that's a good way to think about it, rengen
Marklar
09-18-2009, 06:37 PM
I think you're confusing displacement with the length of the stroke. A longer stroke gives more torque, but I believe that's due to increased leverage rather than the displacement.
A larger displacement does mean more power though, that's true. But torque involves leverage, and so a longer stroke can give you more torque even if the displacement remains the same.
