wire off battery question
Old Dec 23, 2008 | 12:52 PM
bumblebeerx8's Avatar
Rear Mount GT35R
moving the barrery and wondered where the white wire with the quick connect into the fuse holder on the battery terminal ran to. i plan on fusing at the batterys new location just wondering if it would be ok to run together with other wires or should i fuse this wire seperatly
Old Dec 23, 2008 | 01:15 PM
StealthTL's Avatar
Metatron
If I read the diagram properly, there is no white wire at the battery, must be aftermarket - stereo/alarm etc..
S
Old Dec 23, 2008 | 05:07 PM
Rear Mount GT35R
at the positive battery terminal there is a 60a fuse under that there is a quick connect with a white wire
Old Dec 23, 2008 | 06:10 PM
That's the power steering power wire
Old Dec 23, 2008 | 08:28 PM
Rear Mount GT35R
seems a bt extreme for power steering
Old Dec 23, 2008 | 08:31 PM
Whatever....it is electric you do know that right ??
Old Dec 23, 2008 | 10:01 PM
Rear Mount GT35R
yeah i fused it there and at the battery so it should all be good
projectr13b
Mar 1, 2019 09:00 AM
Shinka84
Aug 19, 2015 04:55 PM
cschoeps
Aug 6, 2015 12:44 PM
stickmantijuana
Jul 19, 2015 10:33 AM
