my 8 won't run right and the engine is humming while off HELP
Old Dec 23, 2008 | 11:44 AM
jbk's Avatar
jbk
so this morning I woke up turned on my cat an let I idol cause it's cold here in ny and went in to my house to get ready. I came back to the car 15 mins later and the pitch of my car sounded different, especially when I reved it. I didn't think much of it till I saw the engine light blinking. Usually it stays on cause of my agencypower exhiast but this time it was blinking. I tried getting out my parking spot and after moving 5 ft it stalled out. I turned the car back on but the engine died on me in seconds. Now 2 hours later, same thing. It startedand stayed on but again after stalling out trying to move it the engine gave up again after turning it back on. I opened the hood and there's a humming constant beeeeeeeeeep sound. What is wrong with this? I was driving fine all last night. Help please
Old Dec 23, 2008 | 11:45 AM
hakuna matata!
sounds like your coils/plugs might be shot.
the humming sound is probably because you left the key in the 'ON' position when you opened the hood.. or the fans
Old Dec 23, 2008 | 01:30 PM
Brettus's Avatar
Boosted Kiwi
Stop leaving your car idling for so long - that is the absolute worst way to warm up your engine .
Old Dec 23, 2008 | 02:45 PM
jbk's Avatar
jbk
ok so i refused to pay for a tow to get it checked out so i drove the car.. at first as it was, it was acting up and required alota gas to move in gear, it would jerk a little and even backfire, but after goin about 2-3 blocks soemoen cleared out and my car was back to normal... lol wtf?
Old Dec 23, 2008 | 04:04 PM
CyberPitz's Avatar
Huge hole is huge
I would say your plugs or coils are going down the *******. They aren't sparking the fuel enough, so when you are going to drive, the backfire is caused from the more gas flying into the exhaust. Get those replaced, and you shouldn't have this happen again.
If you're serious about it being fine after driving...uhh...bad gas?
Old Dec 23, 2008 | 04:50 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
After you replace the coils and plugs............Listen to Brettus. You should let it idle about 30 seconds at MOST and that's plenty. I know you went back inside because it was cold, but that's just too damn long. Will most likely do more harm than good to the CAT. Just keep the rpm's under about 3500 until it's fully warmed up.
Old Dec 23, 2008 | 05:19 PM
zoom44's Avatar
your cat died.
you were in limp mode from allowing the car to idle so long
Old Dec 24, 2008 | 01:32 AM
hakuna matata!
i dont think he has a CAT but i did recommend he get his coils/plugs changed asap as well.
Audio Concepts ATL
Sep 26, 2021 01:59 PM
vapor2
Nov 3, 2020 03:38 PM
Ajmurphy85
Jul 30, 2015 07:51 AM
Davey's RX-8
Jul 28, 2015 12:13 PM
dbarber
Jul 25, 2015 01:34 PM
