View Full Version : Anyone have a remote start installed on their RX8?
JCX
12-09-2003, 09:33 PM
Has Anyone had a remote start alarm installed on an RX8 Automatic trans?
I spoke with my installer and he said he would get back with me on installing a remote start alarm (Viper 550) he doesn't know if possible due to the Rotary engine, previously had one on my Eclipse AT. Just wondering if anyone had had this done yet?
my10ae
12-09-2003, 09:34 PM
JCX:
I have not done this yet but want too. Let us all know how you make out.
Thanks...
matt
12-10-2003, 08:18 AM
http://www.rx8club.com/showthread.php?s=&threadid=3844
RotorMotor
12-10-2003, 04:45 PM
It's very possible. I have a Viper 790VX installed. I love it. I just hit the button while I'm brushing my teeth in the morning and by the time I get out to the car, it's all warmed up and ready to go.
(and my car's a manual as well....)
huhsler
12-11-2003, 11:12 AM
I'm having the 790VX installed on Saturday. Aren't those awesome?!
Bankotsu
12-11-2003, 03:33 PM
Where can I buy Viper 790VX?
harwax
12-11-2003, 09:51 PM
What is the cost of Viper 790VX plus installation?
Is it installed by dealer, if not, any warranty concerns?
RotorMotor
12-12-2003, 10:29 AM
No it's not dealer installed. Yes there are warranty concerns, but only if you're careless and try to remote start your car while it's in gear. You can get it installed at just about any alarm shop that sells Viper alarms. Mine was about $650 installed. It's sweet because it's also got the 2-way paging system that alerts you up to a mile away if your alarm goes off, a door opens, the trunk opens, etc.
As far as the remote start is concerned, I had a switch wired down near the fusebox that allows me to disable the remote start (when a friend is driving the car or it's in for service or something). The remote start will shut the car down after 10 minutes unless you put the key in the ignition. For theft prevention after remote starting it will shut it down the car when the clutch is disengaged, the accelerator is revved over 3k RMP or the brake is tapped without the key being in the ignition.
Sputnik
12-12-2003, 11:40 AM
As far as the remote start is concerned, I had a switch wired down near the fusebox that allows me to disable the remote start (when a friend is driving the car or it's in for service or something). The remote start will shut the car down after 10 minutes unless you put the key in the ignition. For theft prevention after remote starting it will shut it down the car when the clutch is disengaged, the accelerator is revved over 3k RMP or the brake is tapped without the key being in the ignition. Does it shut down if the parking brake is released too?
---jps
RX8FanMan
12-12-2003, 11:59 AM
man this is awesome. i want one!!!
RX8FanMan
12-12-2003, 12:08 PM
rotormotor where did you get it? you get it online?
RotorMotor
12-13-2003, 01:46 PM
---jps
I wasn't sure so I had to go check... Nope. It doesn't.
No, I just bought it and had it installed at a local alarm shop but I'm sure you could find it on eBay....
Sputnik
12-14-2003, 12:04 PM
Well, one should be able to use a relay and connect it to the brake pedal wire so that both scenarios will cause the engine to stop if the key is not inserted.
---jps
rotarygod
12-14-2003, 12:41 PM
On a vehicle that has remote start, if you start the car and get in and try to drive off, when you hit the gas pedal or try to put the car into gear, the engine dies. You have to have the key installed to keep it running. Don't worry about someone walking up to your car when you aren't looing and driving off. Unless they stole your key, they can't.
If an installer tells you he isn't sure if he can install it because of the rotary engine, tell him he can't because he is an idiot and then go elsewhere. An engine is an engine.
This is obviously a mod intended only for an automatic car. Anyone who wants to do it to a standard will probably have a hard time getting it done unless they know someone or can do it themselves. Shops don't do it for liability reasons. We did many years ago but too many stories would come back about how they left the car in gear when parked (which you should do anyways!) and the started it. Many other cars and garage doors have been hurt this way. The way this country works is they would probably try to sue the installer for their issues. It was just safer to not install them on standards anymore and I don't recommend it regardless. Trust me, EVERYONE who has one installed on a standard car will forget at least once that the car is in gear. Whether or not the car lurches forward into anything is a different story. I highly recommend against it on a standard. Remember tha I was an installer for many years. I got to see all kinds of horror stories.
RotorMotor
12-14-2003, 02:17 PM
Yes, if you do install this on a manual, you absolutely must make sure that you do not leave the car in gear when you plan to remote start it. That said, there are very few cases that I use the remote start and am always very conscious of how I left the car. If you're not absolutely sure you left it in neutral, don't start it, period.
There are relays that can be wired into the remote start to detect the state of the gearbox (in gear, in neutral) and enable/disable the remote start accordingly. I got the alarm installed 2 weeks after the car came out in the US and there weren't any relays/wiring diagrams available yet. If available now, the peace of mind would be well worth an additional $50 to get this wired up as well.
slavearm
12-14-2003, 03:27 PM
I am using a compustar 2WSS system. http://www.compustar.org Man this thing is a beauty. We spent about 8 hours because my 8 was the first that Compustar knew of to get remote start (and mine is a manual). Call Auto Sound & Security in Chino, CA they will hook you up. And they only charged me around 570 installed!
909-364-0494
Install was super clean, and the guys were extremely careful and took the extra time to get everything working EXACTLY as it should.
Slavearm
Sputnik
12-15-2003, 12:32 PM
Originally posted by rotarygod
...Trust me, EVERYONE who has one installed on a standard car will forget at least once that the car is in gear. Whether or not the car lurches forward into anything is a different story. I highly recommend against it on a standard... I would agree if the system relies on the driver to leave the car in neutral, especially if there are multiple drivers using the car ("Honey, did you leave the car in neutral?" "I always do, don't bother asking me again!").
But there are versions out there that use one of a couple of methods for ensuring that the manual tranny is in neutral before starting the car. There is also a good chance that the manual tranny in the RX8 has a lead that will indicate whether the tranny is in neutral or not, negating the need for other means.
---jps
RotorMotor
12-15-2003, 12:58 PM
Hence the kill switch in case anybody but me will be driving the car. Is it dangerous? Yes. Is remote starting while in gear completely avoidable? Yes. Like I said, if I'm not 100% absolutely sure that I left the car in neutral, I don't do it. I did that this morning in fact and ran out to peek through the window in my bathrobe just to be sure....
huhsler
12-15-2003, 01:00 PM
slavearm - I was told that it's very easy to hit one button and accidentally start your car with Compustar. Is that true? I'm trying to decide between the Viper VX790 and the Compustar. Any help is appreciated. Thanks much!
joseh
12-15-2003, 02:47 PM
Hey, guess what.
Our 8's have a NEUTRAL SWITCH!!! YAY!!!
I have not visually checked this out yet (tonight!) but it goes into the PCM in the engine compartment behind pasenger headlight.
Enjoy!
RotorMotor
12-15-2003, 02:55 PM
Yeah, the switch is there, I just wasn't able to take advantage of it at the time of installation. Viper = hold 2 buttons down for 2 seconds to remote start.
huhsler
12-15-2003, 03:39 PM
Thanks RotorMotor. I knew about the Viper and I think it's a very solid method.
I was told that, on the other hand, the Compustar is a single button for 2 seconds. I'm trying to get confirmation.
Thanks though. :-)
slavearm
12-17-2003, 08:58 AM
Yah its hold 1 button for around 3-5 seconds. I have had a compustar for the last couple of years (on my integra before my 8) and have yet to get an accidental start. The buttons are pretty firm, and don't get pressed accidentaly. That's my 2 cents anyways.
huhsler
12-17-2003, 11:12 AM
Got it. Thanks.
One last question, I know that both the Viper and Compustar have a timer, such that after the engine is remote started that it will shut down again after some time. Can you manually shut it down from the remote?
My buddy just got the full Viper 791 + GPS installed on his Audi TT for $1300 and he loves it. Big $$$ though.
I wish the Compustar had a GPS/locator service like that. Ah well...
RotorMotor
12-17-2003, 11:16 AM
You can with the Viper....
huhsler
12-17-2003, 12:25 PM
Sold! After selling 1 kidney, I'll get the Viper package! lol.
LiL BenNy
12-14-2004, 03:47 PM
so we established the viper 790 can be in stalled but what about the newer one viper 791 chcek this out..
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=48611&item=5738139218&rd=1
under features and specs its say "REMOTE START SYSTEMS ARE INTENDED FOR FUEL-INJECTED, AUTOMATIC TRANSMISSION VEHICLES ONLY." is this true or is this guy just retarted?
thanks
Stone
12-14-2004, 04:03 PM
I am with Rotorygod sounds like a bad idea for a stick shifter. All you have to keep your baby from rolling is a parking break which only sets one set of wheels and dosn't set them that darn hard to begin with, after time with brake wear and the parking break cable streachig your car might roll away on you. Think about it is it worth the risk to your 8? To others? To your bank account is you get sued for your wayward 8?
Stone
12-14-2004, 04:07 PM
thanks
You could wire up the remote start to a car with a carb but the system couldn't pump the gas pedal to prim the carb or set the choke (it is is a manual choke)
Anda remote start on a stick shift is a foolish risky idea.
gcar76
12-14-2004, 04:55 PM
get the clifford one the remote is better then the one Viper has.
PHA RX-8
12-14-2004, 05:36 PM
This really sucks. I have been calling around today to find a compustar dealer as well as other DEI installers who have any experience with the RX8. The compustar installer doesn't know anything about the RX8 and really didn't want to talk to me and other places only recommend non 2way DEI products to install.
Kel Rx8
12-14-2004, 10:32 PM
when i 1st got my car in march 04 1st thing i wanted was remote start for my companies
parking lot. but after talking to a local dealer and a mutual friend they recommended
me not to do it.for one reason the key9valet key has to be left in the car.hidden of course
but physically in the car for the sensor in the keyfob.now im not sure if this is a fact some can clarify this if they still have there valet key ?
huhsler
12-15-2004, 09:45 AM
On top of everything else, the Compustar's tranponder bypass is disabled by the brake pedal, so the security of the key chip remains intact (unless the would-be thief decides to drive the car away using only the e-brake...).
I love my Compustar! It was installed courtesy of Rolling Thunder of Richmond, VA.
LiL BenNy
12-15-2004, 11:40 PM
im confussed... so the viper sytem is a bad and unsafe idea but the compstar is? can some one explain the difference in lower terms lol
huhsler
12-16-2004, 07:06 AM
Nah. I think the point is that either system will work great if it's put in my a competent installer. DEI's installer website has now been somewhat updated with RX-8 wiring data and the few Compustar owners here seem to have no problems.
Find a good installer and you can't really make a bad choice on aftermarket alarms these days. Good luck!
flex351
12-16-2004, 12:22 PM
Has this ever happened because it sometimes happens to my bro's supra on really cold mornings. He'll try to start it and it will start but shut down again then it wil restart again. Wouldn't this be a problem on our 8 and possibly cause flooding issues? Has this ever happened to any of you guys with the remote start?
PHA RX-8
12-16-2004, 01:05 PM
Now I'm really pissed. I have called over 10 installers on the KC metro area and no one and i mean no one will install a remore start system on my manual RX8. I am think of going out of state to get the work done but from a support stand point I would be taking a risk. Any thoughts?
Gambit
12-16-2004, 01:23 PM
awesome.
[/QUOTE=rotarygod]....how they left the car in gear when parked (which you should do anyways!)[/QUOTE]
Why should you do this?
LiL BenNy
12-17-2004, 02:26 AM
i just recently heard this too but i believe its safer and prevents the car from rolling? but im prally wrong.. its like safey wise...
Gambit
12-17-2004, 07:19 AM
Rolling was the only thing I could think of too. But I always park on flat surfaces and use my E brake
huhsler
12-17-2004, 09:49 AM
PHA RX-8, you are correct about the risk. Although under DEI's new warranty, service SHOULD be provided by any DEI service tech, regardless of location or type of installation, it largely seems dependent on the whim of the service people.
If you do get it installed out of state, make sure it is by a DEI certified shop, rather than a fly-by-night. Good luck!
EMart11b
08-20-2009, 08:36 PM
Holy bump batman!
Anybody know if this will work with a credit card key?
kosoku
10-23-2009, 11:24 PM
Bump for an answer to EMart
jaydawgx7
10-25-2009, 10:29 PM
I am using the compustar system on my 2006 manual trans. I also have the credit card keys (which they did not have to install in the car like the older systems, there is now a module). I couldn't be happier with the system. The best part is probably that I can program a time into the remote start and it will start up on its own in the morning, that way, I just get up, shower, and get into a warm car.
