Rim Question
holla if u hear me
Rim Question
please do not take me not knowing as ignorance........found some rims and need to know if they will fit on my 8........what do i look for on the rim so i will know. that they will fir my car .....on th inside of the rim it said 18/7 .......these are some nice rims and i would be getting a steal on these.....any help is appreciated....thanks
Check out the Will it fit thread
https://www.rx8club.com/series-i-wheels-tires-brakes-suspension-55/will-fit-thread-133500/
But 18x7 will fit no problem as long as there 5x114.3 bolt pattern
Also whats the offset? 18x7 +?
holla if u hear me
https://www.rx8club.com/showthread.php?t=133500
holla if u hear me
5x114.3 is the bolt pattern
as far as proper offset, it depends on the width of the wheel/tire
for example my rims are 18x8.5 with stock sized tires and an offset of +35...the wheels are about flush with the fenders...no more sunken in look like the stockers. BTW the stock wheels offset is +50
the will it fit thread that Ikon posted has a lot of great info, check that for more wheel sizes that work with our car
holla if u hear me
rex
another qustion for you cause you dont talk to me like the noob i am......if i bougth some rims that were 18x7.5 and put a spacer on would that do anything for me.......btw my tires are 225/45/18.....thankx again for bein cool
i would be wary about spacers because they shorten the length of your wheel stud and can make the car unstable (depending on the spacer).....ideally what you want is a wider wheel with a similar or slightly lower offset...the wider the track the more the stability
holla if u hear me
i thought that the stud would be shorter and unstable......im just checking to make sure of diffferent things like this so i can learn.....appreciate the help the chrism
not a problem...with a wider wheel the stud is original length...some terms you might want to educate yourself on before spending big money on wheels are offset, hub bore, width, size, bolt pattern.....weight is also a huge factor for most people because the heavier the wheel the slower your car will accelerate
holla if u hear me
yeah i went to a a local shop and theres a guy there who showed me everything......i ended up deciding when i get new ones to go with 18x8.5 all around so i could rotate my tires......
yankeepicker
Sep 11, 2015 05:42 PM
