Flooded x 3 update
Old Dec 19, 2008 | 03:57 PM
Crowboy's Avatar
Old Skool
Flooded x 3 update
Ok so I got my RX8 back which was flooded due to carbon buildup. Now I am experiencing noticeably weak starts. Car turns over but takes a bit of time. I have a BHR ignition that I'm waiting on so let's get that out of the way. My battery is 6 months old (POS stock) which was replaced the second time it flooded along with spark plugs and wires. What should I do till I get my ignition kit? Will an Optima battery help with my cold starts? Thanks again fellas.
Old Dec 19, 2008 | 03:59 PM
Socket7's Avatar
ಠ_ಠ
Might be time for a compression check.
Old Dec 19, 2008 | 04:06 PM
Compression won't effect the cranking speed...so if it is cranking slowly it is electrical...either a bad connection, bad battery, wire or the starter itself.
Check the connections first...especially the grounds to the engine....and try that...you can easily test the battery to check the voltage and output ( take it to Autozone or the like )
Old Dec 19, 2008 | 04:18 PM
Socket7's Avatar
ಠ_ಠ
I thought that by weak start he meant it would crank but not turn over. Having had previous issues with carbon buildup, it seems possible he might have low compression.
Old Dec 19, 2008 | 04:30 PM
Sorry..I wasn't questioning you...just that if it was cranking slow.....
Compression check would be warranted too, especially if it cranks OK..but doesn't start
Old Dec 19, 2008 | 11:10 PM
Crowboy's Avatar
Old Skool
No the car turns over, but it's a long crank...will check out the electrical. I also had a compression test done on the second flood and my engine passed at that time of service. I may go to another dealer and have an additional test performed.
Old Dec 20, 2008 | 04:05 PM
RotaryResurrection's Avatar
kevin@rotaryresurrection
Have you had the upgraded "fast" starter installed? The old 04 starters turned the engine REALLY slowly. Like 200rpm. I put on an upgraded "fast" starter and that little SOB spins the engine a **** load faster...probably closer to 275-300rpm. Makes the thing start in about 1 second versus 2-4 that it used to take.
Old Dec 20, 2008 | 05:36 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeah make sure u have the updated starter
Old Dec 21, 2008 | 12:26 AM
run a can of b&g 44k through it.. it does help..
then get a second compression test.
Old Dec 21, 2008 | 01:08 AM
Brettus's Avatar
Boosted Kiwi
/\ good idea
92trbolzr
May 18, 2025 09:04 AM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Evan Gray
Sep 26, 2015 12:30 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
