how the F... do i take the tires out...
Old Dec 18, 2008 | 04:24 PM
mikeman's Avatar
I am so frustrated i was trying to take the tires out i took the bolts out and it still wont come off i put the car in neutral and put the second brake down it still wont come off is there a DIY with pics plz help
Old Dec 18, 2008 | 04:26 PM
alfy28's Avatar
sure, its called pull harder.
did you jack the car off the ground?
but jokes aside, gl to you
Old Dec 18, 2008 | 04:29 PM
deadphoenix52's Avatar
meh.
jack the car up
Silver06's Avatar
Zoom Zoom....
If you've removed the wheel bolts, and the wheels still won't come off...
Most likely due to some galvanic corrosion between the steel hubs and the aluminum wheels. How long has it been since your wheels were off?
Like alfy said, pull harder, or gently kick the tire in a couple places.
Good luck.
CyberPitz's Avatar
Huge hole is huge
Nothing different about these cars when it comes to taking the wheels off than any other. Might need to stop pulling in a diagonal path?
*EDIT*
Geez, 3 posts at the same minute!!
Old Dec 18, 2008 | 04:30 PM
chancejat's Avatar
Drive it like u stole it!
kick it
Old Dec 18, 2008 | 04:31 PM
mikeman's Avatar
omg i pulled as hard as i could turned the wheels around its so f..king hard it looks like its stuck or something...
Old Dec 18, 2008 | 04:32 PM
mikeman's Avatar
I don't know how long it hasn't been off
Old Dec 18, 2008 | 04:33 PM
chancejat's Avatar
kick it!
CyberPitz's Avatar
Huge hole is huge
Use your foot and kick it a bit...might 'unstick' it, like everybody is saying.
Old Dec 18, 2008 | 04:34 PM
Silver06's Avatar
Zoom Zoom....
Look, be careful here.
If you aren't absolutely sure what you are doing, there is a real chance of you hurting yourself or your car....
If you really are stuck (LOL), just put the nuts back on the studs (as tight as you can with the tools that came with the car), and take it to a garage.
No offense meant - just don't want your next post to be "I pulled my car off the jackstands"
Old Dec 18, 2008 | 04:35 PM
Renesis07's Avatar
Vtak just kicked in yo!!
Kick it like a dog
Old Dec 18, 2008 | 04:36 PM
CyberPitz's Avatar
Huge hole is huge
We haven't even made sure he has a jack/jackstands under it..
J/K man.
Old Dec 18, 2008 | 04:38 PM
Silver06's Avatar
Zoom Zoom....
J/K man.
I had the same thought.
OEM Jack, soft ground... the O/P reefing on the wheel...
mikeman's Avatar
yes its standing on jack stand i dont want to kick it of the stand lol..
Old Dec 18, 2008 | 04:40 PM
416to212's Avatar
Utopia Taco Bell
After you have jacked it onto jack stands, sit down on your *** in front of the tire and kick one side of the tire (rubber) - I usually kick the side closest to the brake caliper.
Kick the tire with your foot flat and when I say kick, I mean kick it F'ing hard if it won't budge. I'm Asian so my kicks are full of Ki but I have faith that non-Asians can master the craft with dedicated training and rice eating.
Old Dec 18, 2008 | 04:42 PM
chancejat's Avatar
just kick it....
Silver06's Avatar
Zoom Zoom....
Us non-Asians have been known to tap the back of the wheel with a hammer handle. 2 or 3 places should break the stiction.
we're not talking about the jack to lift up the car. Do you have actual STANDS underneath it?
If so, sit in front and kick it. Don't BRUCE LEE the freaking tire, just kick the sidewall on one side and then the other. (not too hard, work up in force)
Old Dec 18, 2008 | 04:44 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeah kick it hard sometimes a sledge hammer works(but only when on a lift in a shop when u can get a swing.) Yeah i'm from the North and it gets BAD in the winter....OP what is ur location?
Old Dec 18, 2008 | 05:00 PM
mikeman's Avatar
i dont have no stands underneath it
Old Dec 18, 2008 | 05:02 PM
JRichter's Avatar
Void Where Prohibited
I wouldn't kick it then....
Old Dec 18, 2008 | 05:03 PM
DO NOT KICK IT!!!!
I'm serious mikeman, never work on a car without jack stands. Floor jacks are prone to failure and could cause severe damage to you or your car. (including death if you're underneath it.
Old Dec 18, 2008 | 05:04 PM
do you have a home depot nearby? I got a set of jack stands there for like $24.
question: why are you trying to take the tire off?
Old Dec 18, 2008 | 05:19 PM
r0tor's Avatar
kick it anyway.... dont be under it though
