DIY Request Badge Removal
Old Dec 17, 2008 | 11:09 PM
VS8's Avatar
VS8
4 Cylinder Rotary
How do I remove the badges on the front bumper and rear bumpers
Old Dec 17, 2008 | 11:12 PM
ShinkaTeen's Avatar
space reserved for shirt
ok.
listen.
Heat with Hair dryer,
Easiest way was to slip something underneath the badges like a
hotel key card. (plastic and wont own your paint)
after that take the glue off with Goo Gone bought at your friendly kragen.
Old Dec 18, 2008 | 04:14 AM
kersh4w's Avatar
Hit & Run Magnet
get leather gloves and 30lb fishing wire.
Old Dec 18, 2008 | 07:38 PM
xsnipersgox's Avatar
One Shot One Kill
just fyi, this is no honda, you are going to have holes everywhere that will need to be filled.
Old Dec 18, 2008 | 07:39 PM
tubingchamp's Avatar
What mawd bug?
1) Get a sledge hammer
2) Swing the sledgehammer at badge you want removed
3) Throw the plastic bits in the garbage.
Old Dec 18, 2008 | 08:43 PM
VS8's Avatar
VS8
4 Cylinder Rotary
i am planning on debadging my car that was the point of it
Old Dec 18, 2008 | 08:45 PM
ShinkaTeen's Avatar
dude... trust me...
Old Dec 18, 2008 | 08:48 PM
RyanX-8's Avatar
2004 Titanium Grey GT
Originally Posted by ShinkaTeen
dude... trust me...
+1 on the advice. Same thing when taking off vinal.
Old Dec 18, 2008 | 08:59 PM
heyarnold69's Avatar
Rotary wanabee
hair dryer?
Old Dec 18, 2008 | 09:48 PM
shadycrew31's Avatar
WENTGERMAN
hair dryer or I prefer a heat gun takes less time.
heat area for 8-10 seconds.
use a card or plastic putty knife.
then get treesap/bug remover to get the stock adhesive off.
I'm planning on blacking mine out soon. not to keen on the delete..
everything is going gloss black on my exterior, well the plastic at least.
Old Dec 18, 2008 | 10:01 PM
05rex8's Avatar
sold the 8... :(
we don't have badges on the rear bumper
Old Dec 18, 2008 | 10:46 PM
Wind Dance's Avatar
Central Valley RX8
Though this works only problem the fact that the mazda and the flying M has holes. Please search there are various thread of this.
Old Dec 18, 2008 | 10:49 PM
ShinkaTeen's Avatar
^^ doesnt matter
once heated they pop off like virgins at a showing of twilight.
Old Dec 19, 2008 | 12:46 AM
04blue8's Avatar
zoom zoom
^^ doesnt matter
lmao. +1 on the description
Old Dec 23, 2008 | 02:29 AM
Jpaul26's Avatar
Full Rotation
I know wat he means. When you take the flying M and the Mazda badges off there are holes there. Doesnt matter how easy they come off. I actually got mine off just by slidin my nails underneath them, but once I saw the holes, I just popped the badges back on..
Old Dec 23, 2008 | 10:33 AM
ShinkaTeen's Avatar
its ok...... you get better ventilation with the holes....
Old Jan 4, 2009 | 03:23 AM
StealthTL's Avatar
Metatron
Front M has two posts, Mazda has three, only the RX-8 on the trunk comes off clean.
S
Old Jan 6, 2009 | 10:47 AM
notorque's Avatar
I bid thee farewell
ive done this many times, for a good temp covering of the holes, once the badge is off and you clean the area inside and out with alcohol, put masking tape, blue painters kind covering the hole on the outside of the car, on the inside of the trunk, when you take the plastic cover off you can see the holes covered with the masking tape,
use a pea size amount of bondo, just enough to fill the hole so it can be popped out later when you find a shop to paint it. once its dried you take the tape off on the outside of the car, it should be flush with the surface, no sanding, DO NOT SAND, leave that to the pro's. if your like me, when you buy a car you buy touchup paint for chips, use the touchup paint and dabble the small area, they are tiny, only about 2mm......ive had them hold up for 4 months through the winter before i got it painted. Im about to do this to my 8 next week, ill post a lil DIY. its easy sh*t
oh yeah, this is ASSUMING, you are ultimitaly going to take your car to the shop to get them to do it right, this is only a TEMP thing, by having the bondo set on macking tape to dry, it acts more as a plug than actual body molding.
Old Mar 29, 2009 | 04:12 PM
xdj_jdx's Avatar
Pew Pew
good thread im subscribing... i debadged the front of mine and now working on getting rid of them pesky holes.....
Old Apr 8, 2009 | 06:00 PM
Semiazas's Avatar
The Dark Carnival
BOBO just black the badges. Looks alot better and still has its name. Just remove the Rx8
Old Apr 8, 2009 | 06:13 PM
myriadshalaks's Avatar
rot8ing
once you take off the flying M and the Mazda, they will pop back into the holes, right?
and you don't need to remove the front bumper to remove the front M, right?
Old Apr 9, 2009 | 12:32 AM
dsire4u's Avatar
SS RX8
is there hole in the front bumper too if you take off the flying M?
Old Apr 9, 2009 | 12:56 AM
What mawd bug?
Yup.
Old Apr 11, 2009 | 06:31 AM
jesterb6ub9's Avatar
4-um Spectator
I'm in the process of doing mine the way Semiazas suggested...blackened. Used the blow-dryer method with the heat set on low and one of those Quickpass plastic keychain cards to get underneath 'em and separate. I've read it before but do be careful on the 'mazda' emblem...it can split 'tween the a-z and the z-d fairly easily so work that one from the top and bottom. Personally, I plan on replacing the 'mazda' piece with the '[I]RX-8[I]' to cover the holes there and just leave the right side blank. It doesn't match the rest of the emblems cuz they just look like block letters. Took about 15 minutes for all to be removed and I used a goo remover to get the excess glue off of the car and emblems. Next I sanded all the shiny off with some 220-grit wet/dry sandpaper and was sure to get every nook and cranny(sp?) so that I won't be doing this again in a few months. I then went ahead and applied some 2-sided weather proof tape to them and went around the edges with a razor to make sure the entire backside was covered to prevent leakage, ensure grip and to just give it a cleaner look overall. The sanding and the taping were tedious and tough on the digits but doing it right, I think, is definitely going to be worth it. I started this at 1 in the p.m. and was able to get a few coats of paint on before I lost sunlight. I used an indoor/outdoor, plastic-bonding spray paint in a flat finish and I believe they look waaay better. Also, all the materials are at your local hardware and shouldn't cost ya more than 20 bucks...mine was 17 and some change.
Attached Thumbnails DIY Request Badge Removal-0411090329.jpg   DIY Request Badge Removal-0411090330.jpg   DIY Request Badge Removal-0411090330a.jpg   DIY Request Badge Removal-0411090331.jpg
Old Apr 11, 2009 | 07:19 PM
4-um Spectator
WA
And done...I decided to keep the 'mazda' on the back because to me, it didn't look balanced with the right side blank but here are the finished results of the two options...
And yes, I know my tabs are due soon...hehe
Attached Thumbnails DIY Request Badge Removal-0411091610.jpg   DIY Request Badge Removal-0411091716.jpg   DIY Request Badge Removal-0411091716a.jpg
