why is this a problem?
Old Dec 17, 2008 | 04:35 PM
LPCOKIE's Avatar
Tip: Do not shift into 1st above 20
mph or clutch failure could occur
out of
RX-8 Quick Tips®
i don't remember seeing that in my 05 manual
Old Dec 17, 2008 | 04:49 PM
it's in there, I'm pretty sure I remember reading it in my '05 manual. That's not nice to the transmission so don't do it.
Old Dec 17, 2008 | 05:29 PM
TheWulf's Avatar
My 8 looks like a Smurf
Tip #2: Always rev-match your shifts. Don't rely on the synchros!
Old Dec 17, 2008 | 05:39 PM
04RX8man's Avatar
Rotary Powered Countryboy
yeha actually my car will not go into 1st till under 10 but i usually put it in at a stop or 5 or lower!!!
Old Dec 17, 2008 | 06:00 PM
mysql's Avatar
Doppelgänger
i buffer overflow my 1st gear and shift into it at a negative speed.
Old Dec 17, 2008 | 06:20 PM
Socket7's Avatar
ಠ_ಠ
Wait, does that mean you go back in time when you shift into second gear? I didn't know that you could get up to 88 mph in first....
I've shifted into first gear at 20 mph. Requires a double clutch to make it work, but it was buttery smooth. In spite of this I can't advise doing it.
Easy_E1's Avatar
I hate that I have to wait till 30 mph to downshift into first gear. I wish it would do it at 35 instead.
Oh wait I have an AT.
Never mind.
Old Dec 17, 2008 | 07:33 PM
kersh4w's Avatar
Hit & Run Magnet
i shift at the top of first every now and again.
whats wrong with it?
in other news, why is my 1-2 shift getting more difficult?
Old Dec 17, 2008 | 09:16 PM
zoom44's Avatar
That must be one WEIRD synchronizer.......
its cut backwards
Old Dec 17, 2008 | 09:29 PM
Easy_E1's Avatar
But you also wait until 120 until you shift into 3rd. Might as well have a Powerglide.
No I don't. I shift into 3rd at about 90mph. Into 4th is 125.
Old Dec 18, 2008 | 12:14 PM
at what speed do you shift into 6th?
Old Dec 18, 2008 | 12:30 PM
Phil's 8's Avatar
FI by Pettit-BHR-Cobb AP
I thought you had one of those cars that would not go above 125? I hear that there are several out there.
Old Dec 18, 2008 | 01:58 PM
mazdaverx7's Avatar
RX-Heaven
shifting into 3rd at 90mph??? i would say not too much more than 70mph in 3rd... i'm shifting out of 2nd and into 3rd around 63mph...
Old Dec 18, 2008 | 02:03 PM
they've got A/T's.
Old Dec 18, 2008 | 11:18 PM
kersh4w's Avatar
Hit & Run Magnet
i believe the correct speed to shift from 3rd into 4th is around 82mph.
Old Dec 19, 2008 | 12:14 AM
83FB7's Avatar
The OP means downshifting into 1st from 2nd, not upshifting from 1st to 2nd.
Old Dec 19, 2008 | 02:32 AM
kersh4w's Avatar
Hit & Run Magnet
ah, well my heel-toeing needs improvement before i can do that.
Old Dec 19, 2008 | 08:47 AM
mazdaverx7's Avatar
RX-Heaven
Thumbs up
they've got A/T's.
that clears things up
Shankapotamus3
Mar 14, 2021 03:53 PM
Zube6115
Sep 30, 2015 12:57 PM
tommy26Germany
Sep 29, 2015 10:33 AM
kody59
Sep 28, 2015 03:43 PM
