ok so who has...Fluorescent Gram Lights 57D Yellow & Orange?
Old Dec 17, 2008 | 03:05 PM
Angelo se3p's Avatar
Arrow ok so who has...Fluorescent Gram Lights 57D Yellow & Orange?
sexy offset! 18x9.5+12
18x9.5+12
Luminous Yellow
Luminous orange
whos got em!
i wanna get the yellows for my car!
Old Dec 17, 2008 | 03:08 PM
imput1234's Avatar
I ♥ Drifting!!!
I've always wanted a set of 57 Max in orange.
Old Dec 17, 2008 | 03:12 PM
yeah there sick huh? ahahah
im gonna get the yellows in spring.
my car should officially be a track car by spring.
STOKED!!!! ahahah
so what are the plans for yer car my friend?
drift?
Old Dec 17, 2008 | 03:15 PM
imput1234's Avatar
I ♥ Drifting!!!
hopefully, I can get in as many events as possible, need to make that $$$.
Old Dec 17, 2008 | 03:17 PM
imput1234's Avatar
I ♥ Drifting!!!
57 Max would look so much more bad *** in those colors.
Old Dec 17, 2008 | 03:23 PM
ehhh theres a guy with a s13 on zilvia that them, with a pretty nice fitment.
but i already have black rims on my car so im gonna change it up.
or maybe ill get the time attack finish as another set :] ahaha
Old Dec 17, 2008 | 03:40 PM
LionZoo's Avatar
road warrior
You're going to run a +12 offset?
Old Dec 17, 2008 | 03:44 PM
imput1234's Avatar
I ♥ Drifting!!!
do it. :drool
Old Dec 17, 2008 | 04:04 PM
ohh yeah! or lower! ;]
Old Dec 17, 2008 | 04:26 PM
c0ldf1ame's Avatar
Old Dec 17, 2008 | 04:46 PM
LOL!!!! epic fail!
Old Dec 17, 2008 | 05:07 PM
StuttgartRX8's Avatar
Nurburgring Camera Whore
Here are my 18x9.5+12 and they do not fit the rx8 very well
Old Dec 17, 2008 | 05:11 PM
then ill just go with a lower offset with the right tire size, (stretched tires)
rolled fenders, maybe some fab work,
and id hate to say it but if i have to.... spacers.
or... 18x9
anything can be done my friend!
Old Dec 17, 2008 | 05:14 PM
or... 18x9
I wasn't to worried about them fitting the RX8 since I put them on the R34
Old Dec 17, 2008 | 05:21 PM
well the r34 has a wider wheel base then the 8, so theres more wheel clearance,
but iv never worked with a r34 so i couldnt make that judgment other then i know you can get 18x10s on there easy with the right offset.
Old Dec 17, 2008 | 06:01 PM
Yeah I've seen most set ups with a 18x10.5 +15 on the R34's, I just didn't want that much of aggressive wheel package. The Car is pushing a little over 500 hp and this set up works fine for now.
Old Dec 17, 2008 | 06:03 PM
very nice!
any pics?
Old Dec 17, 2008 | 06:07 PM
here you go,
Old Dec 17, 2008 | 06:13 PM
very sexy!
id go with out the wing tho, iv got a thing for skylines wingless! ;]
u boostin hks?
Old Dec 17, 2008 | 06:17 PM
very sexy!
u boostin hks?
I have to keep the wing, Every part on and in the car is HKS. But the turbos are still the original N1 turbos that came on the car. I just got the F-con tuned on the Mine's ECU that was in the car so its running top notch and boosting to 1.2 bar.
Old Dec 17, 2008 | 06:20 PM
tight!
Old Dec 17, 2008 | 09:45 PM
the_duke313's Avatar
mmmm yummy r34!!!
i do like wingless gtrs too but that is a sexy wing too.
i pretty much love r34s anyway they come
Old Dec 17, 2008 | 10:37 PM
LionZoo's Avatar
road warrior
At that offset, you'd need to stretch something like a 205 to prevent it from rubbing. Spacers won't help, spacers push the wheel more outward and so you'd get even more rubbing. Generally people run a +45 offset with a 18x9.5 for the RX-8. At +12 offset, you're going to rub even with a 18x8. You can get a widebody kit, but really how much money are you going to try to spend?
The R34 was designed for a lower offset, while the RX-8 was designed for a higher offset. The R34 can fit a +12, but I bet if you try to fit a +50 like on the RX-8, you'd end up rubbing on the inside. Wheelbase has absolutely nothing to do with wheel clearance.
Old Dec 17, 2008 | 11:48 PM
imput1234's Avatar
I ♥ Drifting!!!
18x9.5 +12 will fit on an rx8, run a narrower tire, get fenders flared/pull, negative camber. I'm sure you can run a 245 if you are flared.
Old Dec 18, 2008 | 12:06 AM
If you can move your rear fender lip out an inch they will fit
