Best Non-OEM Replacement Battery for The 8?
Old Dec 16, 2008 | 11:13 PM
RotoRocket's Avatar
Freely Radical
I took my car in to have the dealer check it out for hard cold weather starts a while ago.
The car has always started, but the colder it is, the slower it is to turn over.
Anyways, I was hoping they would upgrade me to the new battery (interstate) and the new starter, as it's a TSB.
They didn't; but they did say come back if I continued to have problems and that they would.
Now that it's really cold, the 8 is slower to turn over - definitely slower.
Anyways, if I take it back and they still refuse to upgrade my battery and/or starter, what is the best non-OEM battery to ensure rapid cold weather starting?
Thanks.
Old Dec 16, 2008 | 11:47 PM
ZoomZoomH's Avatar
Mulligan User
my family's had good experience with Die Hard Gold, however Autozone's Duralast brand is also highly rated
key is get the highest cold cranking amp (CCA) you can get for the battery type for the 8 (type 35 i believe)
Old Dec 16, 2008 | 11:49 PM
ZoomZoomH's Avatar
Mulligan User
and they are suppose to replace the starter under warranty per TSB if owner complains about 'hard to start' condition under cold weather. go to another dealer?
Old Dec 16, 2008 | 11:50 PM
ZoomZoomH's Avatar
Mulligan User
and before anybody says it, i think Optima batteries are a waste for money if you're not running massive sound systems in your 8.
Old Dec 17, 2008 | 12:00 AM
really,
look at the specs..
i would say a red top if you are not running a silly sound system. if you are a yellow top..
but what do i know..
Old Dec 17, 2008 | 12:04 AM
elysium19's Avatar
just bought a red top, $150 shipped (that may not be rock bottom, but it's decent I believe). Working well.....but...it's a battery, what more can you say about it....
Old Dec 17, 2008 | 08:37 AM
Shinka_MJR's Avatar
SHKWAV
Swoop said what i was going to...
Red Top optima's are just fine for the majority of us. The yellow tops are the oens you want to use for car's with the 1.21 gigawatt sound systems.
Die Hard's work great, ran them in my cars up until i got my 8 (simply havent replaced my 8's batt yet) and i put a Duralast in my wife's car, she's had no problems at all with it.
Old Dec 17, 2008 | 08:53 AM
That's for 2004 and 205
He may be out of warrenty.
Main thing is to get a battery with higher CC cold cranking amps.
Brand is subjective unless someone can post a legimate test.
Old Dec 17, 2008 | 09:09 AM
TheWulf's Avatar
My 8 looks like a Smurf
RotoRocket: does this mean you'll be changing your sig?
Old Dec 17, 2008 | 09:55 AM
r0tor's Avatar
I just picked up a 7 year warranty NAPA battery for about $60 with a friendly discount...
Old Dec 17, 2008 | 01:29 PM
Raptor75's Avatar
All batteries are produced by a hand full of manufactures then re branded. The best way to find a good battery is look at tests of their performance as can be found in Consumer Reports for example. What a battery states usually not what you will get. Everything else you will hear is just opinions which could be accurate or not.
Old Dec 17, 2008 | 04:04 PM
RotoRocket's Avatar
Freely Radical
Guys, I'm under warranty for another 12 months.
I think the TSB replacement battery is an Interstate - the OEM was a Panasonic.
If I don't get the dealer to upgrade my starter and throw in a new battery, I will ask to speak with a customer service rep at Mazda NA.
My dealer has been great so far, so I don't think it will be necessary.
Old Dec 17, 2008 | 04:10 PM
04RX8man's Avatar
Rotary Powered Countryboy
DieHard Platinum is the best battery on the market....have tons of CCA (arond 900) but they are about 190 bucks but if not the DieHard Gold is very good too ussally arond 110 or so
Old Dec 17, 2008 | 07:23 PM
ZoomZoomH's Avatar
Mulligan User
wow the ad bars on this forum is smart! I see Optima RED TOP battery ads in it now lol
Old Dec 17, 2008 | 07:24 PM
ZoomZoomH's Avatar
Mulligan User
and yes i still think Optima batteries are a waste of money... until their prices fall to same level as the 'standard' batteries
Old Dec 18, 2008 | 04:29 AM
have an 04. the panasonic battery lasted a year.
never got the starter replaced because i never have had a problem with starting..
got the replacement battery yes it was an interstate.. well it lasted 2.5 years..
optima now.. i am going to give it a go..
Old Dec 19, 2008 | 04:40 PM
Raptor75's Avatar
The replacement starter may help with the life of the battery, you may be spending 2 to 3 times as much spinning the engine to get it to start with the old start then you would with the new one. I'm 3 years with the new set up and it is still turning strong even in Chicago winters.
Old Dec 19, 2008 | 05:00 PM
Georgia8er's Avatar
I put the highest rated Interstate 24F battery in. Yes, a 24F will fit in the battery tray.
Old Dec 19, 2008 | 05:26 PM
jeffe19007's Avatar
Don't forget about the reversed posts when you buy.
I like Optima Red tops as they seemed to be the last battery I had to buy for several cars.
But... the 8 had had its alternator die, and before I got to the dealer ship I had a couple of complete discharges. That seemed to kill the Red top. It was replaced under warranty, but Batteries + had to attempt to charge before testing it and that took a good 24 hours.
So -- Red tops are nice, but don't drain them dry!
Old Dec 19, 2008 | 06:55 PM
ken-x8's Avatar
Does that leave enough fresh air space around the battery, per the service bulletin?
http://www.finishlineperformance.com...19-05-1504.pdf
Ken
Old Dec 21, 2008 | 11:18 PM
RotoRocket's Avatar
Freely Radical
My 8 failed to start tonight in a parking deck after sitting in 4 degree weather (-23 wind chill) for 5 hours.
Turned the key and a slow whir-whir-whir sound. I didn't want to flood it, so I quit. The interior lights and radio and electrical components were working.
I had to get a jump start from some guy in an Explorer, and it turned over.
Time to take it to the dealer tomorrow AM and bitch until they give me the upgraded starter and battery per the TSB.
Old Dec 22, 2008 | 02:06 AM
kersh4w's Avatar
Hit & Run Magnet
you can add 1 problem to your eight. haha.
i want that 9lb racing battery. :D
Old Dec 22, 2008 | 09:29 PM
Jon_99_RX-8's Avatar
If you belong to Costco, you can get a replacement Interstate battery for like $53.
Old Dec 22, 2008 | 09:51 PM
G3tR3DDY2GR3DDY's Avatar
get the oddysey pc680 i love it
Old Dec 23, 2008 | 10:15 AM
RotoRocket's Avatar
Freely Radical
Update: My dealer (a newly opened one) is fantastic. They kept the car overnight, left it outside, and tried to start it this morning and had some trouble.
They are replacing the starter motor and battery per the TSB under warranty.
The fact they did what they did shows their good faith at trying (and succeeding) at duplicating the problem.
I could not be happier with a dealership experience.
