Oil Pressure Gauge
Old Dec 16, 2008 | 08:47 PM
Jab's Avatar
Jab
Oil Pressure Gauge
So I'm new the rx8 but I do know that the oil pressure gauge is a "dummy" switch. It was about 25 degrees out today and I noticed when I started the car, it was already up to pressure instantly. Is that usual? Maybe I'm just confused...but I thought it should take some time to move.
Old Dec 16, 2008 | 08:56 PM
simplyphp's Avatar
Oil Pressure != Oil Temperature
Old Dec 16, 2008 | 09:04 PM
05rex8's Avatar
sold the 8... :(
normal
Old Dec 16, 2008 | 09:09 PM
Marklar's Avatar
The gauge has two readings: normal and jack squat. There's nothing in between.
Old Dec 16, 2008 | 09:12 PM
simplyphp's Avatar
The gauge variation of the viscous oil pressure may or may not inherently exceed the design purposes, except in various cases of incomplete studies where the car was started cold without having proper time to warm up to an equilibrium temp for the exhaust and headers.
Old Dec 16, 2008 | 09:15 PM
Jab's Avatar
Jab
Thanks guys!
Old Dec 16, 2008 | 09:17 PM
simplyphp's Avatar
Anytime, glad to assist.
Old Dec 16, 2008 | 09:34 PM
LionZoo's Avatar
road warrior
I think the gauge might be purely cosmetic and doesn't read anything. The 2009s deleted it.
Old Dec 16, 2008 | 09:37 PM
mysql's Avatar
Doppelgänger
they also deleted the fuel gauge. it makes me feel better now
Old Dec 16, 2008 | 09:39 PM
simplyphp's Avatar
They actually deleted the RPM rev cluster all together, they want you to know your car by the sound it makes so you shift when you "feel" and "hear" the right moment.
Old Dec 16, 2008 | 09:40 PM
mysql's Avatar
Doppelgänger
it's got voice recognition. You say "5000 rpm" and the PCM will adjust the throttle accordingly.
Old Dec 16, 2008 | 09:44 PM
simplyphp's Avatar
Only if its reached 5000 rpm, because it has adaptive voice reconnaissance which checks your current RPM and if its <= your spoken RPM, it will alert you that the action cannot be performed and prompt you to either downshift or cancel command.
tubingchamp's Avatar
What mawd bug?
That would be intense driving.
"9000 rpm....FIRST GEAR!!.......SECOND GEAR!! 9000 rpm! THIRD GEAR! 9000RPM!!!! FOURTH GEAR!!! 9000 RPM!! THIRD GEA..
OH SH.."
Old Dec 16, 2008 | 09:50 PM
simplyphp's Avatar
Read my post tubing, you would have to affirmative it due to the advanced technology.
Old Dec 16, 2008 | 09:59 PM
05rex8's Avatar
sold the 8... :(
OH SH.."
I don't think it will recognize "oh ****"
the rx8 pcm is good, but not that good
Old Dec 16, 2008 | 10:30 PM
Marklar's Avatar
Sure it would. That would be the voice command for DSC.
Old Dec 16, 2008 | 10:48 PM
05rex8's Avatar
sold the 8... :(
ah, I stand corrected
Old Dec 16, 2008 | 10:49 PM
RK's Avatar
RK
It's Not Easy Being Green
Pretty sure that's Japanese for "Apply Braking Procedure' so the PCM should manage.
The only flaw I know of with the Voice Recognition software in the '09s is that when Mr. Roboto comes on the radio the system gets stuck in an endless praise loop which eventually causes it to forget to continue the normal oil rate causing apex seal failure and a total engine failure.
Check TSBs for more info...
Old Dec 16, 2008 | 10:52 PM
05rex8's Avatar
sold the 8... :(
good stuff going on in this thread
Old Dec 16, 2008 | 11:01 PM
DarkLord7854's Avatar
Software Engineer
Psh, best feature of the 09s is the flux capacitor
Old Dec 16, 2008 | 11:02 PM
DOMINION's Avatar
I don't buy Kool-Aid
How about just WOT!
Old Dec 16, 2008 | 11:03 PM
DOMINION's Avatar
Well that and its got motors/engines in the wheels so now you can wack 2 and fit the bodies one in the front one in the back
Old Dec 16, 2008 | 11:16 PM
zoom44's Avatar
I can totally fit 3 in the trunk of the 04 i have, making the extra space in the 09s rather superfluous.
RevMeHarder
Jun 1, 2026 02:30 PM
WranglerFan
May 31, 2022 07:51 AM
RXFEVER
Sep 11, 2016 02:51 PM
RX8mzda
Oct 14, 2015 05:12 PM
